HELP! Autodimming Mirrors Stuck on Dim
    Results 1 to 2 of 2
      Feb 2014
      Central Mass.
      Our 2015 XC60 T6 has developed a new problem, just after i replaced the front brake pads (see post:https://forums.swedespeed.com/showth...ont-Brake-Pads), but likely unrelated. All 3 mirrors are fully dimming, even at night. It's as if there is a car with high beams behind, but there isn't. I believe that this is a safety issue, especially at night. After the ignition is turned off, they slowly return to a non-dimmed state. I searched swede speed and found one instance of this problem in an XC90, but there was no conclusion. Any help will be appreciated. Specifically,
      1. Will my Steinngold extended warranty cover this problem?
      2. Has anyone seen this problem?
      3. What was the cause and solution?
      4. Is there a way to turn off autodimming until it is fixed? (perhaps a setting or even pulling a fuse?)
      Thanks in advance.
      I posted it here rather than in the XC60 sub thread because there is likely commonality across models.
      2015 XC60 DRIVE-E T6, Platinum, Heated F. Seats, Crystal White Met, Xenon, Tech, BLIS
      Custom: Valentine mount/City Safety IR filter, Dog Seat, Superchager ind., REAL dipstick
      2002 Acura RSX Type-S 6 speed
      2020 Tesla Model 3 Performance
      Feb 2014
      Central Mass.
      Fixed already! A connector that I had added to power a dash cam had slipped down and was covering the rear-view mirror's forward ambient light sensor. If only all problems were that simple to solve!
    4. Remove Advertisements
    1. No DIM communication with the car after upgrade to LED DIM
      By mountainbikert in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-05-2018, 07:21 PM
    2. Dim DIM (instrument cluster brightness)
      By pgoes in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 06-27-2017, 04:40 PM
    3. headlights locking Pin is stuck stuck stuck!
      By garrett in forum S40 & V50 (2005-2012)
      Last Post: 05-29-2013, 04:56 AM
    4. Auto dim mirror not so dim
      By jamman in forum S60 (2001-2010)
      Last Post: 02-07-2005, 10:06 PM
    5. Dim DIM...
      By R-Car in forum R Forum (2004-2007)
      Last Post: 11-21-2003, 03:23 AM
