Reduced Engine Performance
    Results 1 to 7 of 7
      I replaced a fuel pressure sensor and cleaned my CEM but this info alert will not leave. How exactly do I clear this message? There are NO codes for my OBD scanner.
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      No codes is strange. Do you have a T5? If so then I would suspect the TCV.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
      Yes it is a t5
      This is a video of the symptoms https://imgur.com/gallery/GtiezS7
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      A bad reading from the accelerator pedal can cause this message. There are many others.
      OBD scanners don't read the codes you're interested in. You'll need VIDA or a decent pro scan tool.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
      If you're interested in cheaper handhelds that can do the job for a volvo - get a volvo specific scan tool - Some of us have the Autophix ES610 which is about $80-100 USD but can do all your module reading by itself and clear lights through the ODB2 port in the compact size of a cheaper handheld.
      1996 HD Electra Glide - Big Bertha - 10:1 Wisecos; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
    10. Remove Advertisements
    1. Engine System Reduced Performance with blinking engine
      By dealcatcher in forum XC90 (SPA: 2016 - )
      Last Post: 07-02-2018, 09:06 PM
    2. Reduced Engine Performance Message and Engine Light On
      By mikep17 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 12-29-2016, 04:46 PM
    3. Replies: 8
      Last Post: 05-19-2014, 03:44 PM
    4. Replies: 3
      Last Post: 03-31-2011, 02:06 PM
