Xc70 4C alternative
    Results 1 to 16 of 16
      Junior Member EricVolvoR's Avatar
      Feb 2017
      North of Montreal
      Xc70 4C alternative
      Hi guys,
      Thats the first time I come to the XC forum.
      May I ask you is there is an alternative to the 4C struts? I have a 2010 XC70 with 4C and I will have to change the struts soon.
      I saw there is Bilstein B4 on IPD but they specify it will not fit XC70 equiped with 4C
      I dont care to have a code, a warning, or the 3 buttons disabled.
      Anyone know if its possiblie to replace the 4C with something?
      Envoyé de mon iPhone en utilisant Tapatalk
      2007 M66 S60R Custom Interior, Custum Piggyback ECU (AEM Infinity). Project not done yet (In Progress)
      2010 M66 AWD S40 R Design
      D088 Intercooler, Viva Catback, Becker Dowpipe, K&N Intake. No Tune yet.
      Ceika BBK and Ceika Coilover
      Member CrossingCountries's Avatar
      Oct 2015
      Crossing many Countries
      Xc70 4C alternative
      Did you ever like the 4C system at all? They say it is awesome!? Or overrated?
      Verzonden vanaf mijn iPhone met Tapatalk Pro
      XC70|D5|AWD|GT6|MY11|Polestar|IPD SWAY|
      Feb 2017
      North of Montreal
      Actually i own a 2007 s60r since 2010 and its better on the s60r beceause it affects the throttle. So on advanced setting the car is really agressive and drasticly get firmer. On the XC, the advanced setting dont affect the throttle and the suspension is not that firm. So on comfort mode the car bounce so much you never use that setting.
      Sport mode is very bouncy too but not as much as comfort
      Honestly, its not that aewsome but ok.
      I think its not worth replacing it due to its high cost
      You see in the s60r forum many would never replace it and other hated it.
      I would fall in between :-)
      SwedeSpeed.com
      Junior Member Rrrracer's Avatar
      Nov 2019
      Indianoplace
      Someone more knowledgeable than I should chime in soon, but I'm pretty sure that the Bilsteins will physically interchange without an issue. I seem to recall that there is some way to trick the ECU into thinking the 4C are still installed so that the car doesn't produce a warning, but I'm not sure of the process.
      09 XC70 T6 "Maxamoose"
      Many, many Miatas
    7. #5
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by Rrrracer View Post
      On the R's I believe it involves tearing the sensor out of the old 4C strut and leaving it connected. That may be applicable here.
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2006 & 2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
    8. #6
      Member
      Dec 2009
      Rustburg VA
      Quote Originally Posted by R-Pow3R3d View Post
      This does work, however, when switching shock types you do need to also change springs. The 4C springs are much softer than a standard spring.
      Questions about rear differentials repairs? Email me here - [email protected]
      Owner of the only P3 V70 T6 in North America
    9. #7
      Feb 2017
      North of Montreal
      Tx a lot for the info!
    10. #8
      Nov 2019
      Indianoplace
      Yo Eric, if you decide to put the Billies on would you be so kind as to report back with your findings? I'm also looking to replace the whipped stock shocks on our 09 with 93K miles on them... I want an upgrade but Mama loves the way the car rides so I don't want to sacrifice too much in that department.
      Many, many Miatas
    11. #9
      Oct 2015
      Most seem to choose B4. B6 not done? Too harsh?
    12. #10
      Feb 2017
      North of Montreal
      Count on me
    13. #11
      Oct 2015
      Quote Originally Posted by EricVolvoR View Post
      Count on me
      This: https://shop.nordicar.com/en-gb/volv...-set-7729.html
      Verzonden vanaf mijn iPad met Tapatalk Pro
    14. #12
      Feb 2011
      Frosty La Salle MB
      All I say below applies to the P2 (2007) XC70!
      There are no rear Bilsteins that fit the XC70 directly (without modification).
      I have a 2007 XC70 on which I disabled the 4C. I cut out the actuators from the 4C struts (angle grinder with cutoff wheel), and sealed them up in waterproof packages made from bicycle inner tubes. Then I strapped the front ones under the hood, and the rears to the body in the rear wheel wells.
      The front sensors are also strapped under the hood. Rears are still attached to the rear suspension.
      There are no codes set since the whole system is still plugged in.
      I used stock XC70 Sachs dampers front and rear.
      I did not swap springs.
      Ride is far superior to the worn out 4C system. It was crashy and uncomfortable regardless of setting, right from new.
      This is the thread I followed:
      https://forums.swedespeed.com/showth...hlight=macnoob
      And this one is probably of interest:
      https://forums.swedespeed.com/showth...R-V70R-AWD-S60
    15. #13
      Feb 2017
      North of Montreal
      Tx a lot for that great info
    16. #14
      Feb 2011
      Frosty La Salle MB
      Whoa whoa whoa there. I got confused between your 2010 (P3 chassis) and your 2007 (P2).
      My 2007 is a P2 and my info is for the P2 chassis.
      I'm sure that the P3 will be different!
    17. #15
      Feb 2017
      North of Montreal
      Your right yours is for the P2 chassis and mine is P3 (2010 XC)
      But that still interesting info :-)
      I have a 2007 s60r with a lot of mod but the car still have the 4C and im not sure if ill keep it or change it.
      The car has a Piggy back AEM infinity so when the fine tuning is done I dont know if the 4c will still work lol
      Here some pics
      That pictures is the custom exhaust manifold the tuner just finished yesterday
      I told him thats Art Worth sharing I think
    18. #16
      Nov 2019
      Indianoplace
      Mmm hmmm.. that is gonna be fun
      Man, sucks about the rear shock situation for you P2 guys... I was surprised by the limited options for the P3 platform, but at least we have a few choices (a few generics, KYB, Sachs, Koni, Bilstein.) I come from the world of Miatas where there are probably 30+
      I was personally thinking B6 because I'm used to cars that handle like they're on rails, but the B4 would likely be a good compromise since she drives the car as much as I do; superior to OEM, @Prolix Argon has used them on at least one of his rides and is happy with them, price is right, and hopefully retains some semblance of the plush ride we are accustomed to in this car.
      Many, many Miatas
    19. Remove Advertisements
    Similar Threads
    1. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    2. Alternative to 4C suspension - or how to get rid of it
      By stokerdog in forum R Forum (2004-2007)
      Last Post: 12-06-2013, 01:52 PM
    3. How to upgrade T5 4C to R 4C ?
      By carson.chang in forum R Forum (2004-2007)
      Last Post: 08-07-2006, 07:58 PM
    4. Alternative-minimal hassle alternative intercoolers
      By Britspeed in forum R Forum (2004-2007)
      Last Post: 11-23-2005, 11:26 PM
