Looks like there's a new performance air filter on the market.
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 38
      Member
      Aug 2011
      Urbana, IL
      This is pretty awesome. Looks nice. Supposed to be better than K&N.
      Attached Images Attached Images
      05 S60R MT - Catless - Snabb Intake hose - Elevate AMS - Elevate CBV - Custom Quad Exhaust - Custom Diffuser - Not Pegs - PCC Spoiler - CFW Front splitter - Eibach lowering springs - Elevate sways - more...
      Quote Originally Posted by DrBrutal View Post
      Saw this in one of the R groups on Facebook. Looks to be a really well designed piece and dry media to boot. Won't have to worry about coating the MAF in oil!
      SwedeSpeed.com
      Member MN-TURBOR's Avatar
      Jun 2011
      Twin Cities, MN
      love the pattern and its a dry media no oil.
      just placed an order, i'll post up details on fitment and such once i get it.
      2007 S60R - Ti Grey/Atacama M66 - Stage II Shark Tune - 8EightFab downpipe - Custom Magnaflow Exhaust - SNABB FMIC/Intake Pipe - TWM Short Shifter - Forge CBV - UR Front Brace/Rear Brace - IPD 28mm Rear Sway Bar - BC Racing Coilovers
      2007 XC90 V8 Sport - Electric Silver - Muffler/Resonator Delete
      2007 XC70 - Ice White - Stage I Shark Tune - Muffler Delete
    7. #5
      Jul 2014
      Im thinking about ordering one as well.
    8. #6
      Moderator The Driver's Avatar
      Sep 2009
      Huntington, NY
      Quote Originally Posted by MN-TURBOR View Post
      Please do! Looking forward to it!
      06R Custom Electric Blue Silver
      07R Magic Blue - Sold
      04 Bonatti Gray Rover Disco HSE
      09 Iridium Silver SLK55 AMG P30 Edition
    9. #7
      Junior Member TristanScott's Avatar
      Feb 2014
      Milwaukee
      Does it actually flow better than the OEM filter? Seems like it's just an appearance thing.
      2004 S60R M66 Electric Silver Nordkap
      Stage 2 Contrast Tune, Snabb Intercooler/Charge Pipes/Tial Recirc, Snabb Downpipe, IPD Catback
      KW V2s, Kaplhenke Front Strut Mounts with 2.5" springs, PDV Rear Strut Mounts with KW springs, IPD V70R Track Spec Sway Bars, IPD Rear Toe Links, Kaplhenke Delrin Front Subframe Bushings, Powerflex Race Bushings almost everywhere
      TTV SMF with 06/07 Volvo Clutch, IPD SS Brake Lines
      FOR SALE (2/22/20) - Save her from the scrap yard: https://forums.swedespeed.com/showth...ring-Overhaul)
      2004 V70 2.4 NA AW-55 FWD Ruby Red Metallic
    10. #8
      Member
      Aug 2011
      Urbana, IL
      Quote Originally Posted by TristanScott View Post
      I found out that the filters are good for over 600 HP. Apparently it's the same filter material some people use on performance GTRs and the like. It's not just for show. Washable and non-oiled
    11. #9
      Feb 2014
      Milwaukee
      That's good to know.
    12. #10
      Member
      Jun 2011
      Congo
      be careful boyz, that special air-filter could produce whole lot of heep of boost powa that your R might not be able to handle.
      1997 Avalon
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    13. #11
      Sep 2009
      Huntington, NY
      Quote Originally Posted by dougy View Post
      Seems too good to be true!
    14. #12
      Quote Originally Posted by The Driver View Post
      So found out a little more info; The media they use has a 97% cumulative efficiency rating based on ISO 5011 standards per their manufacture and the filter was designed in CAD.
      They also mentioned that its a synthetic non-woven multi-layer structure. So no cotton, paper or foam like most other filters on the market.
      Definitely different than your standard aftermarket approach. Sounds like this one might be a winner. This might give me an excuse to sell my Elevate intake and put the stock airbox back in and end up ahead
    15. #13
      Nov 2011
      Nice filter.
      Performance wise what does it offer and on a boosted vehicle, just how much does it really matter?
    16. #14
      Member
      Jun 2011
      Congo
      Quote Originally Posted by ImportService View Post
      Nice filter.
      Zero... if you're sticking with a stock MAF housing this filter is absolutely useless and inferior filtration wise to stock OEM filter.
      1997 Avalon
      2000 ML320
      2000 ML55 AMG
      2005 XCR90
      2006 C70
      2006 S60R - gone
    17. #15
      Aug 2018
      Idaho
      The only benefit from my point of view is after your 4th filter replacement interval (actually washing this one) You'll start saving yourself money
    18. #16
      I think there are a lot of us running around that have had issues with the Elevate AMS system that are looking to go back to stock airbox. The only decent filter option is K&N, but it destroys MAFs and ends up costing you money.
      This filter seems to bridge the gap of running the factory box with a high flow filter. For a performance minded individual, this is a no brainer. Not trying to ruffle your feathers, just my perspective.
    19. #17
      Feb 2014
      Milwaukee
      But how many of you are running stock airbox and actually need that flow? I'm in the process of having contrast do my stage 2 tune and I'm running a stock OEM filter in the stock OEM box. After my first pull and sending him that log, he noted that everything looked really great on my setup. If I needed more flow, I would make a custom box or buy the one that Snabb sells with the Audi S4 MAF.
      I'm not trying to discourage anyone from buying this just sharing my point of view.
      Sent from my ONEPLUS A6013 using Tapatalk
    20. #18
      Restriction, Restriction, Restriction. We have forced induction vehicles; Restriction is always the enemy. If I can reduce restriction before the MAF and even add a few HP while getting rid of the issues with the Elevate intake, I'll take it.
    21. #19
      Feb 2014
      Milwaukee
      Quote Originally Posted by 5cylindersymphony View Post
      Sure yeah, I just don't know if it's really worth it at this point. If there is a big difference I'd buy into it. but I'm happy with my OEM filter I bought from fcpeuro and can get unlimited free replacements of haha.
    22. #20
      I get that, lol!
      I just think about all the money that was spent on a stage 2 tune, downpipe, intercooler and airbox set-up for my 05R. For $95.00, even if its only a 2-3% increase in HP, its probably the best bang for your buck as far as power goes.
    23. #21
      Member
      Feb 2003
      There is also this air filter: Jetex T80298 that is the same size as OEM (K&N is not and it comes with an extension and clamps).
      I got it from UK easy and fast. Price with shipping was good: 40 pounds plus 17 shipping.
      There is no direct link to it but select V70 from this page and scroll down on the pages https://jetex.co.uk/air-box-filters-and-induction-kits/
      They also answer the phone and are very nice to deal with (mind the time zone).
      2004 V70R, manual, 4T4
    24. #22
      Quote Originally Posted by doru View Post
      Doesn't come up on their website. Looks like it was discontinued....
    25. #23
      Sep 2009
      Huntington, NY
      It's there, pn T80298
    26. #24
      Jun 2011
      Twin Cities, MN
      its not a dry flow filter, its oiled.
      looks exactly like the one EuroSport Tuning used to sell. the blue faded away within a couple months. you have to oil and redye it to get the blue color back. the rubber ring that sat on the MAF fell apart within 6 months on my R.
      https://jetex.co.uk/product/volvo-s6...rts-filter-11/
    27. #25
      Sep 2009
      Huntington, NY
      Exactly, it is the same one. I didn't get it for that reason, basically, a K&N except I can't get it through FCP so no lifetime replacement.
    28. #26
      Oct 2013
      What are the thoughts on AEM dryflow filters?
    29. #27
      Sep 2009
      Huntington, NY
      I have the AEM Dry flow cover (Water protector). That really does a hell of a job both sediment and water blockage.
    30. #28
      You sir are spot on. Cotton gauze oil based filter per thier website. Same issues as K&N.
    31. #29
      So I ended up inquiring further in regards to size, fitment etc. I received some photos that I thought I would pass along:
      Two major things I noticed from an engineering standpoint:
      1. With the OEM filter, Volvo went with an internal structure reinforcement cage to aid with filter collapse. This is a common issue with forced induction vehicles flowing decent amounts of air. While this helps with maintaining structural integrity, this is absolutely horrible for airflow and restriction.
      2. I am willing to bet you actually loose HP over stock running a K&N filter. Both internal volume and overall size are significantly smaller than OEM. Additionally the inlet diameter looks to be much smaller. Again, huge restriction. I can't believe people actually run this filter on their caRs.
    32. #30
      Jul 2014
      Would there be any concerns about filter collapse with this new design since it does not have any internal reinforcement?
    33. #31
      Quote Originally Posted by MileHighR View Post
      No. The Swedesource filter remedies this with the external hex mesh. It holds the structure of the filter and pleating. This is actually a much better approach as it doesn't disrupt the internal flow.
    34. #32
      Junior Member 3AK47's Avatar
      Nov 2013
      Montreal/Saguenay,QC
      Id be interested in this if it would fit the Audi V8/RS 3.5inch MAF (stock airbox style).
      Any plans? Group buy maybe?
      Im currently running EST airbox with 12inch in height and 3.5inch Inlet diameter AFE oiled filter. While i NEVER had any related issues with the oil in the MAF (even run K&N oiled filter) nor CEL in 7 years owning an R, having this kind of design and all makes me wanna think twice abour purchasing another oiled filter. Just saying ...
    35. #33
      Feb 2014
      New Orleans, LA
      I noticed this years ago, but nobody wants to listen to reason when they're guzzling the cool-aid.
    36. #34
      Junior Member Arch Stanton's Avatar
      Jan 2011
      San Francisco Peninsula
      What exactly is the problem you're trying to address here?
    37. #35
      Jun 2011
      Twin Cities, MN
      installed mine the other day. excellent initial quality and looks nice too.
      https://www.youtube.com/watch?v=AWXa6EdmGfs
    38. Remove Advertisements
    Similar Threads
    1. Looks like there is a Quaife LSD in my future
      By MileHighR in forum R Forum (2004-2007)
      Last Post: 04-15-2019, 06:22 PM
    2. Replies: 12
      Last Post: 06-12-2013, 07:28 AM
    3. Looks like fresh oil above Oil Filter Housing!?
      By TG in forum S40 & V50 (2005-2012)
      Last Post: 09-13-2011, 03:43 PM
    4. Looks like there's no more V70 now..
      By racinrs in forum R Forum (2004-2007)
      Last Post: 03-01-2011, 09:59 PM
    5. Looks like we have another filter option.
      By partridge in forum R Forum (2004-2007)
      Last Post: 12-21-2005, 11:50 PM
