850R track car transformation - Page 2
    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 36 to 70 of 169
    1. #36
      Junior Member RBoy8's Avatar
      May 2006
      Mt. Haruna, Gunma, Eastern Honshu, Japan
      Quote Originally Posted by Austin V70R View Post
      Sway bars - weíll see how the car turns in and exits during the first track day. My boys wonít be driving during the first event so Iíll have a chance to shake it down and make necessary bar changes. The car will have big brakes and great exit speed, so stability with 200TW fires will be very different than a street setup. I want my boys to experience severe understeer, so we wonít go to 100TW too early.
      100%!
      Which 200tw tire are you going with? I've heard longevity wise, the RS4s are fantastic. Slightly slower than the RE-71R but can go lapping for days.
      Yoko just released the the A052, and Falken with the RT660 too but I don't know much about them yet.
      [1995 Volvo 854 T5R - Cream Yellow]
      [2005 Volvo XC70 2.5T AWD - Black Stone]
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by RBoy8 View Post
      100%!
      I donít know yet actually. Iíve run RE-71Rís on the ZL1 for AutoX, but they get pretty slippery without many heat cycles.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
    4. #38
      May 2006
      Also, if you're going to be sticking with the stock seat for a bit, I highly recommend a CG Lock to help keep you in place.
      SwedeSpeed.com
      May 2006
      That's true. I've heard on track you can go about 4-5 laps before they get greasy. I ended up getting a set to try at time attack this year so I'll see how well they last on a stock alignment for an 850.
    7. #40
      Jan 2012
      Santa Cruz, Ca
      Good suggestion on the CG lock. Iíll check it out.
    8. #41
      Jan 2012
      Santa Cruz, Ca
      Had a little time to mess around in the garage tonight and the turbo internals are going out for balancing tomorrow.
      Heard back from Aaron and decided against COP. Want to keep it looking mostly stock and the VVT solenoid means rerouting fuel lines.
      Now that thatís deuces I can move forward drilling the cams and getting it back together.
    9. #42
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      No need to drill the cams; take a look at my thread for a cleaner solution.
      I ran my CoP wiring in the main harness.....you would have no idea it's not factory if you didn't know. I'm not sure what that has to do with VVT but regardless you can use a RN fuel line/rail which solves the aesthetic and routing issues of fuel lines going over the top of a RN engine.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    10. #43
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      Quote Originally Posted by JaredR View Post
      Same, VVT wiring in the main harness and impossible to see. Fuel lines can be persuaded around and over or next to the VVT, Iíve seen a couple different solutions that all look pretty clean. Replacing the fuel lines with braided flexible line is another option. There was an RN swap thread from 6-7 years ago that had a few different options for fuel lines laid out with photos- Iíll dig and see if I can find those images for reference.
      Would *highly* recommend COP- it cleans up the engine bay so much and also creates some room over on the left side of the engine for intake, etc should you decide to get rid of factory air filter housing.
      1998 V70R, M58 AWD manual, Built B5244T5 (Wiseco 81.5, RSI Rods), Garrett GTX3071R gen 2 .82ar (IWG), VAST custom tubular exhaust manifold and downpipe, Sachs 707pp/ R clutch,VAST COP E85 tune with dual VVT control, 3.25Ē ID MAF housing and custom intake, na TB, DW300, DW 950ccís, ipd diverter, ipd intercooler, DO88 aluminum radiator, Magnaflow exhaust, Kaplhenke dbl adjustable front&rear coilovers, Kaplehenke delrin subframe bushings, ipd sways/strut brace, Porsche BBK front, rear '00 VR rotors/calipers, 17Ē BBS RGRís, Jewels.
      485awhp, 598awtq on Mustang dyno
    11. #44
      Jan 2014
      Boston, MA
      Quote Originally Posted by Saffron-R View Post
      Are you talking about the guy in CA with the black 850R? I looked at that and was concerned with the vaccum line all the way to the fuel tank being a problem and Aaron said the same. Fortunately the 97-98 x70s have the FPR at the base of the firewall so that setup can be easily adapted to a 850.
    12. #45
      Aug 2008
      Portland, Oregon
      Are you taking about CJís car? I donít think he has an RN motor in his car? Maybe youíre talking about Calvinís car?
      Anyhow, I suppose it comes down to running the later returnless style or not, also wondering if youíre running the VVT, or if you are just unplugging. A block off plate would clear up some room if youíre not using the VVT, in which case you could notch the timing cover and run them up and over.
    13. #46
      Jan 2014
      Boston, MA
      No not CJ's car. There was a guy on VS maybe 5 or so years ago who had a 99 T5M that got totaled and used it to manual swap a black 850R estate he got to replace it. Pics are all broken now but he swapped over everything in the fuel system. Not that I am endorsing that idea because Aaron and I had the same concerns with the idea of a 12' or so vacuum line. I think the 98 FPR setup is a better way to solve the same problem and requires minimal adaptation.
    14. #47
      Jan 2012
      Santa Cruz, Ca
      Iím running a return style with a 4bar regulator. No VVT and planning to notch the cover.
    15. #48
      Aug 2008
      Portland, Oregon
      In Neal I trust!
    16. #49
      Jan 2012
      Santa Cruz, Ca
      In Neal I trust!
      Thanks!
    17. #50
      Jan 2012
      Santa Cruz, Ca
      Something Iím trying to figure out being new to P80 mods.... why is there a vacuum line going back to the tank for the FPR? On my car the FPR is mounted to the rail.
      The regulator in my fuel rail currently is Bosch 0280160554 and will be replaced by a Bosch 0280160260 in the same location. Vacuum / boost line goes directly to the intake.
      Please let me know if Iím missing something. Lots of experience converting dead-end systems to retune., but I might be missing something here.
      Thanks.
    18. #51
      Jan 2014
      Boston, MA
      Thanks.
      the FPR is at the rail on 850s and at the base of the firewall on -98 x70.
    19. #52
      Jan 2012
      Santa Cruz, Ca
      So whatís the vacuum line routed back to the tank?
    20. #53
      Jan 2014
      Boston, MA
      evap? where's it coming from?
    21. #54
      Jan 2012
      Santa Cruz, Ca
      Sorry JaredR, I guess my question wasnít clear.
      Whatís the advantage / point of going to a 98 - 00 FPR on the firewall?
    22. #55
      Jan 2014
      Boston, MA
      None, unless you want to run a RN fuel rail. If deleting the VVT solves the engine cover/fuel line routing problem, this isn't relevant.
      FPR is only at the firewall on 97-98 x70s. 99+ it's a returnless system.
    23. #56
      Jan 2012
      Santa Cruz, Ca
      got it. Didnít make the connection with the RN fuel rail on these swaps.
      This is how Iíve done the RN rail to a return system on P2Rís, but Iím still learning about P80ís.
      https://forums.swedespeed.com/showth...-System-Design
    24. #57
      Jan 2014
      Boston, MA
      looks pretty similar to the 97-98 x70 setup. Probably not an improvement from the 850 setup from a performance perspective and that is what Aaron will telly you too but I think you'll probably reach maf saturation before the fuel rail becomes a limiting factor
    25. #58
      Jan 2012
      Santa Cruz, Ca
      The DW300 at 55 psi base pressure will be plenty.. not worried about the fuel system. Honestly not worried about the MAF either as it should be capable of flowing 1400kg/s without an issue and I donít think the 19T will push more than 1300kg/s before running out of steam.
    26. #59
      Jan 2014
      Boston, MA
      I hope so too because any bigger and I'll need a completely custom intake setup....but some of my friends in Europe tell me they've seen 19T cars reach saturation with 960 MAF housings.
    27. #60
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Whats the plan to keep the VVT hub from flopping around? They go full retard? under load without control IIRC. You could source a 00 NA exhaust cam, spec are the same but it has no VVT hub yet is set up for a vvt capable head.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    28. #61
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by ScottishBrick View Post
      This was a lot easier. Want to keep the engine factory sealed as possible. Only planning to pull the pan at this point.
      Thereís very little tuning benefit managing exhaust cam timing outside of emissions and reversion managment. It would be worth the work to manage intake cams timing if it was an option, but itís clearly not with my setup.
    29. #62
      Jan 2012
      Santa Cruz, Ca
      They may be seeing the upper voltage limit of the the sensor itself independently of the housing size.
    30. #63
      Dec 2014
      Connecticut
      Oh! Well that certainly works
    31. #64
      Jan 2012
      Santa Cruz, Ca
      [QUOTE=ScottishBrick;7577613]Oh! Well that certainly works
      Itís simple. Trying to keep this build simple and as old school as possible. I got carried away on my V70R and donít want those complexities on this car.
    32. #65
      Jan 2012
      Santa Cruz, Ca
      Well.... good turbo news and bad turbo news... visited Vargas Turbo today I have the rotating assembly balanced, only to find that the shaft and CHRA core were out of spec for bearing surface roughness. Darn.
      Good news, Vargas specializes in TDO4 hybrids for N54 BMWís and offered me a used, but like new 9 blade Garret profile wheel he calls the Stage 2. He also had a brand new CHRA in stock, so Iím back in business.
      Photos of the stock TD04 and Vargas turbine wheels side by side.
    33. #66
      Jan 2012
      Santa Cruz, Ca
      Think Iíve decided what to do for oil supply, but still considering options.
      Iím told these are original spark plugs, but obviously canít confirm. Crankcase looks consistent with 60K miles though.
    34. #67
      Dec 2014
      Connecticut
      Woah thatís a clean crankcase! Nice score
    35. #68
      Jul 2015
      Berkeley, CA
      Just popping in to say this looks awesome!
      I'm curious to see what this thing will do. My "brake pads and tires" P2 V70R was good for ~1:53 at Laguna, but it really felt like it was suffering the whole time. I'm sure a light, FWD P80 will be a much better starting point.
    36. #69
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by afm View Post
      Thanks Albert, Iím hopefully this car will be better under track braking than my V70R was. The V70R was OK with new Hawks on new 2-piece Girodiscís, but I never attempted going deep into 2.
    37. #70
      Dec 2014
      Connecticut
      What did the 19t CHRA run you?
    38. Remove Advertisements
    Similar Threads
    1. S40 facelift or prefacelift transformation to R-design
      By t34mkill3r in forum S40 & V50 (2005-2012)
      Last Post: 06-13-2013, 09:29 PM
    2. S60 R-Design transformation progress
      By Shiryu in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 11-15-2011, 08:30 PM
    3. Transformation of my former R
      By flybynight in forum R Forum (2004-2007)
      Last Post: 06-14-2010, 08:41 PM
    4. Getting ready for a major transformation by Ford
      By stevectsai in forum Car Lounge
      Last Post: 08-04-2006, 01:33 PM
    5. An S70 Transformation
      By dragon17 in forum Car Lounge
      Last Post: 11-09-2005, 08:59 AM
