850R track car transformation - Page 4
    Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 106 to 140 of 169
    1. #106
      Junior Member RBoy8's Avatar
      May 2006
      Mt. Haruna, Gunma, Eastern Honshu, Japan
      My goodness, knowing that there are actually P80s in North America being driven in grassroots motorsports makes me so happy.
      [1995 Volvo 854 T5R - Cream Yellow]
      [2005 Volvo XC70 2.5T AWD - Black Stone]
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by fortis621 View Post
      The next big battle is oil pressure. I used a baffle before, however, a small screw used to secure the baffle to the oil pan came loose while on track and resulted in a creation of a nice sized hole on the side of my block.
      I think you値l like what I知 doing with the oil pan. It should be complete
      next week and I知 pretty confident it will relieve the oil starvation issue and any risk of stray fasteners. I知 extremely concerned about both possibilities.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
    4. #108
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by RBoy8 View Post
      Gets better! I just made a NA throttle body/960 plate for this guy:
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      SwedeSpeed.com
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Is that the guy in Ohio who also had the 99 T5a we were looking into?
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 140k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    7. #110
      Nov 2008
      Laguna Niguel, CA
      Quote Originally Posted by Austin V70R View Post
      It looks like your installation is much more robust. You don't have anything that can come loose. I wish someone could develop a baffle using aluminum. It will be nice if the baffle can be welded to the oil pan.
    8. #111
      Jan 2012
      Santa Cruz, Ca
      I hope it痴 robust! The screws are aluminum and will be TIG weld sealed to the pan, and the stainless nuts will be tack welded to the baffle cage. I believe it will work well.
    9. #112
      Dec 2014
      Connecticut
      Quote Originally Posted by JaredR View Post
      No this is who bought it
    10. #113
      Jan 2012
      Santa Cruz, Ca
      Picked up the new CHRA today.... pretty excited to check the turbo off the 鍍o do list this weekend.
    11. #114
      Jan 2012
      Santa Cruz, Ca
      ECU from Aaron arrived today. Still quite a bit to do before we start tuning though!
    12. #115
      Jan 2012
      Santa Cruz, Ca
      TD04 turbos weren稚 designed for high boost, so Mitsubishi didn稚 push the limits of manufacturing process during that time. Fast forward 20 years and we池e now tuning these cars to 20 PSI and trying to achieve accurate and consistent boost control.
      Unfortunately the wastegate is heavily shrouded and blocked from the exhaust outlet causing slow and somewhat unpredictable boost control and difficulties during tuning.
      Fortunately it just takes a couple hours on the bench to remove the excess casting material to directly expose the wastegate to exhaust pressure and enhance boost control
      This is before and after of the same TD04 7cm^2 turbine. There are various versions of the 7cm^2 turbine housing and the 760 is thought to be the best. I own a damaged 760 and this housing will be better.
    13. #116
      Jan 2012
      Santa Cruz, Ca
      Oil pan project is wrapped up. It holds 7 quarts and should be adequate for oil control.
      The Aluminum Ultra-Wide Flanged Button Head screws are TIG welded to the exterior of the pan for sealing, and the SS nuts on the interior are tack welded to the trap door dog house to ensure they stay in place.
    14. #117
      Jan 2012
      Santa Cruz, Ca
      Focusing on the dash swap this week. The 850R and P80 V70R dashboards, air handling, and harnesses are laid out in the garage. I need to decide if a full electrical swap or a hybrid is the best approach.
    15. #118
      Nov 2008
      Laguna Niguel, CA
      Your oil pan project came out great. I'll take one ;-). Keep up the great work.
    16. #119
      Jan 2012
      Santa Cruz, Ca
      Thanks.
    17. #120
      Jan 2012
      Santa Cruz, Ca
      Spent a little time repairing and reinforcing the P80 V70R dash today in preparation for install in the 850. One tab had completely failed and I was fortunate to find bits to rebuild it, one had failed but was in tact and easy to rebuild, and two were totally in tact, so I reinforced them to prevent future failure.
      All tabs have four layers of repair; two local repairs per side of tab and then larger contiguous layers (2 layers of each interwoven, smaller / larger). The epoxy is marine grade, high strength, medium cure with a structural fastener additive.
      I had to reshape the tab that had totally failed and am really happy with the result. I absolutely hate dash rattles.
    18. #121
      Jan 2012
      Santa Cruz, Ca
      Going to steal this idea Including the dash flock from another build. Will. Probably add oil pressure and water temp in the 2 DIN audio area later.
    19. #122
      Junior Member Zoinks's Avatar
      Jul 2018
      Milwaukee, WI
      Nice dash repair! And that's a good looking ABS module too
      I'm assuming the VR dash come with a center speaker? That's what the tri-pod looks like it mounts too. But I'm sure you already have ideas for mounting them so they look decent lol
      1998 V70R Mystic Silver/Graphite
      1996 RN Swapped 854R Bright Red/Graphite
      Family Fleet:
      2000 S40 1.9T White/Cloth
      COMING SOON: 2009 C30 T5 R-Design M66 Silver/Two-Tone
      Past:
      1998 V70 NA/m Classic Red/Light Gray
    20. #123
      Jan 2012
      Santa Cruz, Ca
      Dash repair is complete and ready for flocking. Ortiz Custom Pods is going to make the three gauge modification to the dash speaker grill.
      Cycle time for Ortiz is a couple weeks and the dash should be flocked as an assembly, so I have a little time to get the 98 V70R electrical and air handling back in the car.
    21. #124
      Jan 2012
      Santa Cruz, Ca
      The car is prepped for the V70R dash, air handing, fuse boxes , and electrical harnesses. Really glad I had a complete donor car because the extent of conversion necessary wasn稚 obvious at project start because I couldn稚 find a full swap write-up.
      I致e decided to relocate the battery to the back of the car and I might also incorporate a ballast box to help F/R bias.
      [IMG]https://uploads.tapatalk-cdn.com/
    22. #125
      Nov 2008
      Laguna Niguel, CA
      ... I致e decided to relocate the battery to the back of the car and I might also incorporate a ballast box to help F/R bias.
      Good move. I've been thinking about this too. I think battery relocation will definitely help with the balance. With increased length of the battery cable, you may marginally gain weight; however, it should be worth it. You can always offset the weight gain with removal of the sound deadening materials ;-).
    23. #126
      Jan 2012
      Santa Cruz, Ca
      Sound deadening material? What痴 that?
    24. #127
      Jan 2014
      Boston, MA
      That's for GT car builds LOL
    25. #128
      Jan 2012
      Santa Cruz, Ca
      Makes a world of difference with a good audio system. I知 this case it will be 5 cylinder music.
      My P2 VR probably had 50 lbs Of dynamat in it.
    26. #129
      Jan 2014
      Boston, MA
      Yup, and this car is definitely gonna have good sound. Can't wait
      Well.....I guess both of our 850Rs are gonna have good sound!
    27. #130
      Jan 2012
      Santa Cruz, Ca
      Indeed!
    28. #131
      Jan 2012
      Santa Cruz, Ca
      Happy to be wrapping up some of the smaller bits. The 1 bar Kinugawa wastegate actuator and IPD HD CBV with 14 lb spring arrived today, so the turbo is done.
    29. #132
      Member
      Oct 2003
      Alameda, CA
      The wagons area already nearly a perfect 50/50 weight distribution, so the gain if any will be negligible.
    30. #133
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by 300+_T5R_855 View Post
      I can see that with an AWD car CJ, but I find it hard to believe with the 855. I would think that moving just a little weight from in front the front axle to the far rear would have to make a difference.
    31. #134
      Dec 2014
      Connecticut
      My experience with weighing a fwd 99 t5a wagon (pewter) was that it had 67% front axle weight, semi biased towards the passenger front without driver in the car. That痴 with full interior and 斗ight cargo aka toolbox ect and I believe that it was a half tank of gas for some reason. I remember the whole car was 3200 lbs. I didn稚 write down the corner weights or bias across the diagonal. This was 4 years ago. Probably time to do it again.
    32. #135
      Member
      Oct 2003
      Alameda, CA
      Well with the interior completely removed, possibly, but look it up an 850 in factory dress has a nearly 50/50 weight distribution.
      I've tried to find the article, but can't seem to find it. I'll keep looking.
    33. #136
      Jan 2012
      Santa Cruz, Ca
      CJ - I think this is the first time I致e ever been in disagreement with you! While you can never truly believe what you read on a forum, this seems more in line with what I壇 expect from a long car without a rear transaxle or even differential
      http://volvospeed.com/vs_forum/topic...-distribution/
    34. #137
      Jan 2014
      Boston, MA
      http://new.volvocars.com/ownersdocs/...release_2.html
      "Mounting the alloy engine transversely produced a desirable 60/40 weight distribution"
    35. #138
      Member
      Oct 2003
      Alameda, CA
      That's pretty close Jared according to this spec sheet. Not as close as I recall reading.
      Wheelbase 2660 mm 104.7 inches
      Track/tread (front) 1520 mm 59.8 inches
      Track/tread (rear) 1470 mm 57.9 inches
      Length 4720 mm 185.8 inches
      Width 1760 mm 69.3 inches
      Height 1415 mm 55.7 inches
      Ground clearance
      length:wheelbase ratio 1.77
      Kerb weight 1545 kg 3406 lb
      Weight distribution 57% front
      fuel tank capacity 73 litres 16.1 [19.3] UK [US] gal.
    36. #139
      Member sventastic's Avatar
      Nov 2013
      British Columbia
      It's possible that the 60/40 is for dry weight and 57/43 is wet weight. 73 litres of fuel weighs 57kg/125lbs, and 8L of coolant + 6L of oil would weigh about 13kg/29lbs, so an additional 44kg/96lbs to the rear. I haven't checked the math but it seems ballpark.
      Looks like Jaryd's article is about an N/A model, so the turbo'd models are probably a bit more front-biased than 60/40 from the additional turbo-associated weight
      1996 854R | M56H | 16T | 268k
    37. #140
      Jan 2012
      Santa Cruz, Ca
      I致e been really fortunate to find the right mix of parts for this build so I知 going to capture it and hope it helps someone with a future swap.
      Starting with the 2000 RN (1999 - 2000 engines only) engine that uses a hybrid cooling pipe that works with the TD04 water lines, and accepts the N accessory bracket, which is a big deal for AC delete.
      Secondly, finding a 1998 MY was huge for the dash swap and I didn稚 realize how important it was as the time. I bought the donor car specifically for the dash, so it could have been any P80, 1998 or later. As I got deeper into the project I decided to swap the fuse box(s) and engine harness also because this was the easiest way to ensure functionality and keep the project clean. A 98MY donor was critical and fortunate because it痴 the only P80 facelift year with Motronic 4.4 (99 and later are ME7) and the ECM / TCM box is integral to the fuse boxes and engine harness.
      This is the 1998 V70R engine harness all cleaned up and ready for new sheathing.
    38. Remove Advertisements
    Similar Threads
    1. S40 facelift or prefacelift transformation to R-design
      By t34mkill3r in forum S40 & V50 (2005-2012)
      Last Post: 06-13-2013, 09:29 PM
    2. S60 R-Design transformation progress
      By Shiryu in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 11-15-2011, 08:30 PM
    3. Transformation of my former R
      By flybynight in forum R Forum (2004-2007)
      Last Post: 06-14-2010, 08:41 PM
    4. Getting ready for a major transformation by Ford
      By stevectsai in forum Car Lounge
      Last Post: 08-04-2006, 01:33 PM
    5. An S70 Transformation
      By dragon17 in forum Car Lounge
      Last Post: 11-09-2005, 08:59 AM
