Rear Hatch foot sensor reset?
    Results 1 to 5 of 5
      May 2014
      Queens, NY
      Is there such a thing? My rear hatch doesn't respond to my foot wave any longer ...
      Is there a way to reset it? Can't find anything in the forum.
      Thanks!
      Sep 2019
      So Cal, USA
      I'm not aware of any owner-controlled function to reset the foot wave function alone -- only the method to change max height the hatch opens to.
      FWIW, I think the whole foot wave design is overly touchy... The first few days after delivery I could almost never get it to work, then I went through a period when it worked fairly consistently once I thought I had found the secret spot and secret speed required for the foot wave (too long under there and it won't go off). For the past month it's not worked once the few times I've tried to use it. I have relegated it to being a novelty I try when I want a chuckle and perhaps a surprise if it works for me, but mainly just use the button above the license plate to open the hatch from the rear. Some other owners here appear to have figured-out the trick a lot better than I have -- and I remain envious, but then again, I never was very good at most sports.
      Bert
      Present: ‘20 XC60 T8 Inscription
      Past: ‘15 Tesla S90D; ‘14 SLK250; '13 RX450h; ‘09 335i; ‘06 RX400h; ‘02 SC430; ‘99 RX300; ‘95 SC300; ‘91 Legend...
      Apr 2011
      Boston
      I could never get mine to work consistently until I read a tip about proximity to the rear of the car. If you stand too close to the hatch when you do your kick, it won't open lest it hit you on the way up. Take a step back from your normal position and try it again and see if it works. It's more about how close you are to the rear than the timing of the kick. Good luck.
      Current
      OSD 2018 XC60 T8 | Onyx Black | Blonde/Blonde Int | Heated Fr Seats & Steering Wheel | Convenience-Vision-Advanced Packages | Air Suspension | 20" Wheels
      OSD 2011 C70 | Flamenco Red
      SwedeSpeed.com
      Sep 2014
      Toronto, Canada
      Mine works consistently and then some. There's times where I walk around the back of the car in my garage and it triggers.
      2018 XC60 T5 Momentum
    7. #5
      Dec 2019
      Bay Area, CA
      I have the aero kit and I have to physically kick the driver side rear tire.
    8. Remove Advertisements
    Similar Threads
    1. Trunk hatch can't close-and-lock, and can't open with foot
      By FusionRedXC60 in forum XC60 (SPA: 2018- )
      Last Post: 06-03-2018, 07:58 PM
    2. Foot activated rear hatch and door locks
      By MASSxc90 in forum XC90 (SPA: 2016 - )
      Last Post: 05-11-2018, 08:42 AM
    3. Foot activated rear hatch opening?
      By RussJ in forum XC60 (2010 - 2017)
      Last Post: 05-18-2015, 06:59 AM
    4. Replies: 4
      Last Post: 06-01-2014, 09:47 AM
    5. Heico Aluminum Foot Pedals/Foot Rest
      By SirSteak in forum S40 & V50 (2005-2012)
      Last Post: 02-14-2005, 11:36 AM
