Downpipe flange and gaskets?
    Results 1 to 10 of 10
      Feb 2019
      The Netherlands
      Hello ya'll
      Im busy building a new 3" downpipe for my '05 V50 T5 AWD. The rest of the exhaust is already down
      Problem that im facing right now is the downpipe to turbo flange. Cant find any, and with a lockdown coming up it would probably take very long to order a custom one somewhere
      Now i found out they offer 2 different kind of gaskets. One like mine is some sort of paper gasket wich sits in a groove in the downpipe flange
      But i also found they offer a full metal gasket. Whatsup with this one? Is this one for the later models? Is it also better? Would be easier to make a flange for it instead of making milling a groove etc
      Found one for the K24 turbo, wich looks to be the same? Same say it will fit the S40 and V70
      Volvo V50 T5 AWD 2005
      Volvo V70 2.5T 1998
      Mazda MX-5 1.8 Turbo
      Mar 2012
      Charlottesville VA
      Here's a flange: https://www.atpturbo.com/mm5/merchan...gory_Code=VC30
      My plan for my AWD is to buy a cheapo eBay FWD downpipe and modify it. Less work for me, and for $100 it seems like a good starting point.
      Feb 2019
      The Netherlands
      Yeah problem is that im from the netherlands. Shipping would take long. And the car is without downpipe at the moment. Maybe ill put the oem downpipe back for a moment.
      Volvo V70 2.5T 1998
      SwedeSpeed.com
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      Is that really the right flange though? It looks flat like for the p2. The one Elevate uses is the same as OEM designed for the gasket that sits in this groove as pictured. Keeps the gasket from actually burning away.
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
    7. #5
      Mar 2011
      The cheap pipes use a basic flat flags like this and a gasket just sandwiches between and eventually that gasket burns away.
    8. #6
      Mar 2012
      Charlottesville VA
      I've noticed that the cheapo pipes use a different flange, but does it actually cause problems? If it does, maybe I'm looking for a good flange too.
      How does the groove keep the gasket from burning away?
    9. #7
      Mar 2011
      The groove the OEM design has the gasket is not directly exposed to the exhaust gas
    10. #8
      Mar 2011
      I have a KT4 1st gen downpipe...it's got the flat flanges...they didn't know...I didn't know... I'm not actually running a gasket at all it's just bolted right to the turbo outlet. Probably leaks a little. I'm not *that* worried about it but I would have more piece of mind if it was correct.
    11. #9
      Feb 2019
      The Netherlands
      I have not decided yet. Not much response from some companys over the flange with the virus thing now. Maybe order some somewhere in the us Downside is it would take very long
      Volvo V70 2.5T 1998
    12. #10
      Mar 2012
      Charlottesville VA
      Quote Originally Posted by thefisch33 View Post
      Does the turbo/dp connection have a step to it? Fwiw that's what my 240 has and it doesn't leak
    13. Remove Advertisements
    Similar Threads
    1. For sale: S60R downpipe, hardware, gaskets. all new
      By Jarren_b in forum R Forum (2004-2007)
      Last Post: 06-29-2015, 12:29 PM
    2. 3 Inch Angle Flange Downpipe W Wideband Bung/Dump Flange-Ferrita 850/870's
      By brettborders in forum FWD & AWD Parts For Sale
      Last Post: 02-06-2013, 10:22 AM
    3. BNIB 19T with angled flange AND new OBX angled flange 3" downpipe.
      By yellow95 in forum FWD & AWD Parts For Sale
      Last Post: 01-25-2012, 08:04 PM
    4. 18t angle flange and angle flange downpipe upgrade
      By thunderbirdsc in forum S70, V70 & V70XC (1998-2000)
      Last Post: 10-24-2011, 08:09 PM
