2009 xc70 Fuse diagram
    Results 1 to 9 of 9
      Feb 2020
      The owners manual that I have doesn't match the fuse block under my glove box. I'm trying to locate the fuse for the cigar lighter in the passenger compartment on the back of the center console. Also, I can't find an explanation on what the usb in the center console does. Half the books in my set are Swedish.
      2009 XC70 82K my first Volvo
      Jul 2013
      Georgia
      Quote Originally Posted by stiksave View Post
      The fuse for the 2 12v outlets on the center console (same fuse for both) is in the B fusebox. Under the hood in front of the driver. It's #25.
      Feb 2020
      So both outlets in the center console operate on the same fuse, front and rear. The front one has power, the rear doesn't. I'll have to pull apart the console to check the wiring. Any explanation on the usb, this also doesn't seem to seem to power my phone when plugged into it. Used car gremlins. Something to work on during virus thing. Thanks for the quick reply.
      SwedeSpeed.com
      Feb 2020
      So after further review, the usb is alive, next problem, I found the plug is off of the back of the rear cigar outlet. I don't have the dexterity in order to reinstall it. Is there a way to dislodge the socket and push it out allowing me to reinstall the plug and pushing it back in. Also, Volvo used cheap friction type tape, on the wiring, that is like digging by hand in a tar pit. Yuk. Had to use gasoline on a rag to get the sticky black gooh off.
    7. #5
      Feb 2020
      I removed the cigar lighter from the armrest. Plugged it in free of the mount hole, blew the fuse. Dead shorted, why it was unplugged, into the trash. I ordered a replacement that is led illuminated and has two usb receptacles. I'l post after it arrives and I instal it.
    8. #6
      Feb 2020
      This is my answer to the shorted cigar lighter.
      Sent from my SM-G950U using Tapatalk
    9. #7
      Junior Member Rrrracer's Avatar
      Nov 2019
      Indianoplace
      Nice... and custom
      09 XC70 T6 "Maximoose"
      Many, many Miatas
    10. #8
      Nov 2016
      Wash. County, Oregon, USA
      Kinda has a Polestar look to it. Does the car run better?
      2016 XC70 2.5L T5 AWD, Platinum, Seashell/black, ipd rear bar, Curt hitch and wiring
      Previous Volvos: '16 V60CC, ours; '6? 145DL & '7? 245DL, hers; '68 122S Wagon, his.
      Non-Volvos previously owned: waaay too many to list here.
      "Teacher fired for drinking on the job. Two students expelled for fighting and insubordination. Other than that, the first week of homeschooling went great! "
    11. #9
      Feb 2020
      Quote Originally Posted by halfast3 View Post
      Gained 1 mpg.
      Corona 19 bored I guess. Tinker with the small stuff, the big things are fixed. I won't print the list here, it's partially in my what did you do to your xc today thread. I'm 6 months from turning 70, I do all my own work,"yet". Here's an example of what I can handle, http://www.thegsresources.com/botm.p...r=2015&month=4, It's parked next to the xc70 in the garage. Next thing is replacing the mirror glass in the auto dim wit rear view mirror. First Volvo, last three cars, two Saab 9 5s, and a Passat GLX 4motion wagon.
    12. Remove Advertisements
    Similar Threads
    1. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    2. Replies: 0
      Last Post: 04-17-2014, 10:39 AM
    3. Fuse Panel Diagram?
      By vLGrok in forum R Forum (2004-2007)
      Last Post: 11-16-2012, 12:30 AM
    4. Fuse #14 in front driver side fuse box...
      By MyJules in forum R Forum (2004-2007)
      Last Post: 05-26-2008, 08:53 PM
    5. Fuse diagram?
      By LordJax in forum 740 & 760 (1982-1992)
      Last Post: 03-12-2005, 02:46 PM
