Haldex oil change 13mm fill plug stuck
    Results 1 to 6 of 6
      Aug 2019
      Ontario, Canada
      Today I tried to do my Haldex filter + fluid change. I couldn't find many pictures here that still worked, and it seems my 2010 V50 fill plug was slightly different than the older models.
      I was able to locate the filter housing, using a small ratcheting screwdriver set I was able to remove the two screws:
      I left the filter in-place while I figured out the fill port. In some pictures, it shows the Diff/Haldex fill ports closer together and on the same surface. Mine seemed a bit different, but basically it is in the same position. Above the rear sway bar, closer to the front of the car than the rear differential.
      I tried a 45 degree offfset wrench, a crow foot + ratchet and just a straight wrench but was unable to get the damn thing off.
      Any further suggestions here?
      Thanks
      2010 V50 T5 AWD M66
      More torque.
      Honestly that's all any of used, found ways to use bars and tools and make more torque on the bolt.
      Good luck. Even people like me NOT in the rust belt had to take some satisfaction in the CRACK that you hear when it finally breaks loose.
      1996 HD Electra Glide - Big Bertha - 10:1 Wisecos; EV13 Cam: Ultima Digital Ignition; Buell Head Conversion; E85 Carb Tuned;
      Member mgm7890's Avatar
      Nov 2013
      USA
      Put your 13mm socket on it, let the ratchet or breaker bar hang down, and give it a good kick with your foot. You'll get it.
      2005 S40 2.4i
      SwedeSpeed.com
      Jan 2018
      And make sure you are using a six point socket
    7. #5
      Aug 2019
      Ontario, Canada
      Thanks for all the tips and words of encouragement.
      It ended up snowing/raining today but tomorrow looks like it will be nice and I'll attempt it again.
      Thanks again!
      2010 V50 T5 AWD M66
    8. #6
      Jan 2012
      Chicago area
      I used a set of offset wrenches I bought at the old hazard-frought (Harbor Freight). They're longer than a typical 13mm wrench to get a little more leverage and the offset is just enough to get in there.
    9. Remove Advertisements
    Similar Threads
    1. Damaged / Rounded Tranmission Fill Plug - Alternative Fill Methods?
      By SpitzeStrom_Terp in forum XC90 (2003 - 2014)
      Last Post: 04-19-2019, 08:55 AM
    2. Plug wires stuck, oil in spark plug well
      By sventastic in forum 850 (1993-1997)
      Last Post: 05-26-2017, 04:28 PM
    3. M41 J-type Oil Fill plug stuck and rounded
      By goin440 in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 05-09-2014, 01:16 PM
    4. need definitive answer on 13mm spacing w/ stock springs
      By kenhoeve in forum R Forum (2004-2007)
      Last Post: 08-28-2007, 10:57 AM
    5. Does 1989(1988manufactured) B230FT have 13mm conrod - like 1990s?
      By Darknessph1 in forum 740 & 760 (1982-1992)
      Last Post: 06-27-2006, 05:12 PM
