Cooling fan replacement ideas for 850.
    Results 1 to 8 of 8
      Oct 2014
      Hey everyone. Started to pull everything out to replace my radiator in my 1995 850. Been having some cooling fan issues for sometime now too. Tested the cooling fan before I pull it out and it is not working anymore. Need to purchase one now.
      A.New factory ones range from $350 and up.
      B.Junk yards around me don't have any 850's.
      C. Doesn't look like 98 and up, 70 series are the same part. And those fans are $175 new, also my junkyard does have a few 70 series models.
      D. Anyone Try a Mishimoto slim fan 16 inch from FCPEuro for $86?
      If you'd like a -98 fan I have one you can have for free.
      2003 V70 T5 - Mystic/Graphite - M56LK - 205k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 298k - Daily/Work Wagon
      I have a 04 c70 fan in my 850 they will work
      Oct 2014
      Yeah. Would like it. Was is the difference between the 850 and 70 series fans?.
      Quote Originally Posted by Jaydiesel View Post
      Shroud has different attachments for the relays and evap.
      Oct 2014
      Thanks for that information. Sending you a pm now for the pre 98 fan..
      Nov 2015
      Another confirmation. The fan in my 850R is out of a 98 XC70. Fit just fine.
      The relays are there for safety. I’ve had my fan short out on my car and smoke in the middle of traffic from the fan and caused my car to almost overheat. These relays/fuses will pop when the fan shorts out cutting power off to the fans so your car don’t burn to the ground. Worth the install. Plug and play
    11. Remove Advertisements
    1. Electric Cooling Fan not working
      By volvoman13 in forum 850 (1993-1997)
      Last Post: 05-01-2010, 06:55 PM
    2. electric cooling fan won't turn off on S80
      By SO73 in forum S80 (1998-2006)
      Last Post: 10-19-2005, 10:42 PM
    3. Afterblow/cooling fan question
      By ramoslip in forum S40 & V40 (1995-2004)
      Last Post: 10-25-2004, 08:40 PM
    4. Odd sound when cooling fan is on.
      By Twinturbonium1212 in forum XC90 (2003 - 2014)
      Last Post: 08-24-2003, 10:18 AM
    5. Cooling fan is always on
      By Papa_Kirlo in forum S70, V70 & V70XC (1998-2000)
      Last Post: 07-28-2003, 10:29 AM
