2016 S60 Inscription dimming side mirrors
    Results 1 to 13 of 13
      Sep 2016
      Does anyone know if the side mirrors on 2016 S60 dim? My wife has 2015.5 V60 with dimming side windows and mine look exactly the same (connectors from the back side are also the same).
      Looking at the brochures online I found that V60 has the dimming of exterior mirrors as an options but S60 doesn't mention this.
      Member KCCM's Avatar
      Aug 2011
      Toronto, Canada
      If you could get self-dimming rear-view mirrors they are packaged with the side view. There is a major difference in the price for the mirrors, which come with the electronics attached to the mirror and plug/clip in as normal. (Bought and is installed a UK left mirror that is curved and first one, at 1/3 price, didn’t dim.)
      Don’t know if you need a software upgrade.
      KECA Kombi - Now '16 V60 T6 AWD R-Design - Just a K&N filter so far, but love the PoleStar tune.
      Dec 2019
      Netherlands
      If you have mirrors with memory you might be able to fix it by upgrading with the dimmable rear view mirror.
      W/o memory side mirrors, you probably need additional door modules too.. And need to check if wiring is present. That was not the case for me.
      Verstuurd vanaf mijn SM-G975F met Tapatalk
      SwedeSpeed.com
      Sep 2016
      The thing is that I think everything is in place. I was at a dealer two weeks back with something not related and asked about this but they told me my car probably doesn't have it. I believe the mirrors dimmed and then stopped working (I have the car just 2 months) but I wasn't 100% sure to press on the dealer further.
      Below is a picture of the inside. Can you confirm that I have the dimming side mirrors from this?
      Also, any fuses I should check?
    7. #5
      Aug 2011
      Toronto, Canada
      Yes, relevant electronics package on the right with wiring leading to it along the bottom.
    8. #6
      Sep 2016
      Hmm, so now just figure out why they don't dim or take it to dealer once corona virus is gone :-/
    9. #7
      Junior Member RobertK's Avatar
      May 2016
      Virginia
      My 2016 S60 Inscription had the same mirror as shown in your picture until I swapped it out for the European aspheric mirror. I still have the original and it looks exactly like yours. The auto-dim feature works well with all mirrors. When I'm in my garage I can see most of the outside mirrors dim, but a small ring around the edge of the mirror will not dim. That will tell you if they are working properly.
      Does your interior mirror dim? I think all of the mirrors work from the sensors located in the interior mirror assembly, but I could be wrong about that.
      Current Volvo: 2016 S60 T5 Inscription w/Platinum package
      Previous Volvos: 1993 850 GLT (sold in 2016), 1984 240 DL Diesel (sold in 1993)
    10. #8
      Sep 2016
      The interior mirror dims when I cover the front sensor by my hand but the outside mirrors don't. I tried to look into VIDA for an activation but didn't find anything.
      The only think I can think of trying is to check for 12V in the cables behind the side mirrors.
      My wife has 2015 V60 Platinum that has dimmed outside mirrors so I could theoretically swap them but I don't think it's going to be a hardware issue.
    11. #9
      Dec 2019
      Netherlands
      Quote Originally Posted by zjev View Post
      If the interior mirror was installed without the official software in VIDA your side mirrors will never get a signal on the CANbus, that the doormodules will read and process. The interior mirror will work in this case, however independent and not connected to the CEM and therefore the door modules never get the signal..
      You can check this, in Sensus menu. Are you able to manage the settings light to dark for the mirror, that case the software was also loaded.
    12. #10
      Sep 2016
      Quote Originally Posted by GruttePier View Post
      I'm not sure if the interior mirror was replaced but the outside mirror was (from the CarFax). Maybe I can try to run identification of CANbus devices through VIDA.
      I wasn't aware of such settings in Sensus. I know there is one in VIDA but not Sensus. Can you take a picture where is it? I don't have it in mine S60 and neither my wife's V60.
    13. #11
      Sep 2016
      Thanks to everyone! I did the following in VIDA:
      - Calibrating the Climate Control Module (CCM)
      - Identifying components on the LIN network that belong to the climate control system (CCM)
      - Programming the climate control module (CCM)
      and the side mirrors work! Although I'm not sure what was the problem, I'll be watching them closely in the next few weeks/months.
    14. #12
      Dec 2019
      Netherlands
      Nice, looks good
      Could you clarify "programming CCM"? What action did you take?
    15. #13
      Sep 2016
      Nice, looks good
      GruttePier, where is this from? I don't have such settings in my Sensus...
      The calibrations I did are from VIDA:
    16. Remove Advertisements
    Similar Threads
    1. 2020 S60 - Auto-dimming mirrors, not dimming
      By IvanR in forum S60 & V60, V60CC (SPA: 2019- )
      Last Post: 01-06-2020, 09:05 AM
    2. Does the 2011 T6 come with auto-dimming side view mirrors?
      By marvinmartian in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-03-2017, 09:03 PM
    3. Auto-Dimming Side Mirrors on a '10
      By Edvard_Grieg in forum XC60 (2010 - 2017)
      Last Post: 10-12-2013, 05:39 PM
    4. auto dimming rear-view mirror/ side mirrors
      By frankybotz87 in forum R Forum (2004-2007)
      Last Post: 11-27-2008, 03:35 PM
    5. Auto dimming side mirrors
      By biotek in forum S40 & V50 (2005-2012)
      Last Post: 10-16-2006, 06:41 PM
