looking for some help with D5
    Results 1 to 2 of 2
      Junior Member mick's Avatar
      Nov 2004
      hi all, i have a 2006 v70 d5 s, with 123k. having a cold start problem with it. starts then just dies immediately, almost like ive switched the key off again, after 2 or 3 attempts it will start as normal and run fine. any ideas?
      Oct 2017
      Australia
      Possibly bleeding fuel pressure back to the tank from the rail. Then when you try start it a couple of times the pressure is built back up. Could be something stuck in the fuel pressure regulator or it is worn. Or a worn check valve on the supply side. I'm 5000k from mine so can't look at the engine to describe the actual components or fuel system, so I'm just going on basic common rail diesel systems.
      2001 V70 - 2000 miles from the nearest dealer and 3000 miles from home, used as my DD for work and storage when I go home for a couple of weeks.
      2009 XC70 D5 - bought because it was ridiculously cheap, cheapest on the planet, after the first drive the wife claimed it before we got home.
    4. Remove Advertisements
    1. Replies: 5
      Last Post: 07-28-2017, 01:44 PM
    2. XC90 MY2017 D5 - a direct comparison to XC90 MY2016 D5
      By Ivos in forum XC90 (SPA: 2016 - )
      Last Post: 05-29-2017, 11:08 AM
    3. volvo v50 d5 '06 engine in a volvo v70 d5 '02
      By waldo1957 in forum D5 Engine Forum
      Last Post: 02-09-2010, 10:38 AM
    4. 2001 S80-T6 Needs some help... Some major help.
      By car6694 in forum S80 (1998-2006)
      Last Post: 08-19-2007, 05:11 PM
