Colder plugs with a tune
    Results 1 to 3 of 3
      Member thefisch33's Avatar
      Mar 2011
      CASTLE ROCK, COLORADO
      Going to start this topic again
      IKH22 is the correct plug for our P1 T5. What are the other appropriate options besides OEM?
      I have a Shark Stage 3 tune, same as MNIWT and I also used the NGK LFR7AIX which is supposed to be one step colder. After reading through the sticky on this someone indicated that plug is the same as the IKH22.
      Reason being under boost I feel like it's misfiring, even with this LFRAIX plugs, same feeling as my Saab 9-3 (don't worry that was a short ownership) did when it didn't have cold enough plugs with its tune.
      What is the correct cold plug for the T5?
      2010 s40 T5 AWD M66 a tribute to Heico's ODIN HS4
      Member jondevieonS40's Avatar
      Oct 2011
      ABQ New Mexico
      Im using NGK's. are you losing coolant by chance? i changed plugs and coil packs trying to chase a misfire and it turned out to be a mild coolant leak just my 2c
      2008 S40 T5 AWD ("Shadow") |ELEVATE 3" Intake, 2.5" Charge Pipe, Intercooler, Torque Mount, ECU Mount, TCV, Turbosmart CBV, Turbosmart Actuator, stage 3 APC Tune, 3 Stickers (5HP)ea||ClockWorkCalibrations Custom 3" Exhaust||EuroSportTuning 3" downpipe.||CF Cone Filter||De-Badged||custom Mesh Grill||Intercooler Cut out||Porsche 911 Throttle body upgrade||18" Enkie PDC Wheels wrapped in 225/45/18 Sentury UHP||M3 Spoiler|| 8k Morimoto HID Kit|| White LED Fog,City,trunk light|"embody God, then go crazy"
      Mar 2011
      No coolant is fine this is directly related to the tune
    Similar Threads
    1. One step colder plugs w/out tune
      By lotusdoom in forum R Forum (2004-2007)
      Last Post: 08-12-2018, 07:59 PM
    2. Colder spark plug after tune
      By agrant2312 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 07-25-2017, 11:58 AM
    3. What's up with the "colder" plugs?
      By marvinmartian in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-18-2017, 03:15 AM
    4. NGK One Step Colder Plugs... What Gap Is Best?
      By glocksrox18 in forum R Forum (2004-2007)
      Last Post: 08-07-2013, 06:53 AM
    5. Driver's side air much colder than passenger's side
      By M-R in forum S60 (2001-2010)
      Last Post: 03-09-2004, 12:52 PM
