2007 V70R Disappearing Re-appearing Coolant, Misfire 1 & Sleeve Anxiety
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 57
      Feb 2010
      Howdy,2007 V70r here with 120K miles. I had a coolant hose let go the other day--violently. Shut off the motor immediately and had it towed.
      Dealer replaced: hose, but I had leaks
      Dealer then replaced: radiator / water-pump / new timing belt...the low coolant alarm would go off when driving, but no visible leaks
      Dealer redid the water-pump... same as above
      Dealer replaced a plug in the rear of the engine...same as above
      At some point, I realized that if I pull over and open the expansion tank, coolant would quickly flow back into the reservoir... FULL! Dealer insists that it had been bled multiple times and that they have pressure tested the $__t out of the cooling system
      Now, this has all happened in the last 5K miles, and at one point I started to get a pretty bad misfire at start-up and while driving, alongside hesitation and rough idel. I opened the deck-lid, only to find that my ignition harness was COMPLETELY thrashed. Ordered a new wiring harness, boots, and plugs. Got it all buttoned up and picked up a Vida....
      I still have a misfire on cylinder one upon starting the car, but no white smoke. If the engine was parked overnight, Vida will record about 50 misfires on cyl 1, and maybe 10-15 on cyl 2. If engine is warm, then start-up will trigger maybe 2-8 misfires on 1 and then no misfires. I can live with that... but what drives me up the wall is the fact that I still go from full coolant, to literally nothing in the expansion reservoir when driving--I literally find myself pulling over once every 60 miles to open the reservoir.
      Any ideas or next steps? Should I start looking for bottom ends?
      Many thanks 🙏🙏🙏
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by lav70r View Post
      Many thanks
      Sorry man.... start looking for a new short block and shim it with a freshly surfaced head before installation.
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
      Member BaxtR's Avatar
      May 2014
      Tampa,FL
      Yup. you need a block my friend
      2007 S60R Nordkap & Black Sapphire Metallic. Auto. Holset HY35, 2.3 Block shimmed, Forged pistons, H-Beam Rods. 3" DP, Meth Inj.
      SwedeSpeed.com
      Feb 2010
      Understood. Two follow-ups:
      Would a compression test confirm the crack? (the dealer has been very sympathetic, I'm essentially asking how to convince them of this)
      Not looking for any modifications (brand new Volvo turbo installed 6 months ago), is it better to source a used bottom-end, repair this one (sleeves?), or source a new one from Volvo is available?
      PS: I never heard of a cyl 1 crack...
    7. #5
      Jan 2012
      Santa Cruz, Ca
      It’s generally 3/4 or 4/5, but can happen on any.
      Sleeved approach is great If you want to spend $4K plus on just a bottom end. Sourcing an 80K - 90K used 4T4 bottom and and installing shims will be just as reliable for your intended use and you can find them for $750. Both will require head surfacing, gaskets, and timing belt, so the difference is cost will be >$3K.
      Up to you.
    8. #6
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      Mine was between 3/4, same symptoms. If you REALLY want to be sure have the shop pull the head, it is possible to have a blown head gasket but not likely from what I have read. They might work with you on labor if you do a replacement motor if it is indeed cracked.
      I went with a 2.4 donor motor and it runs great.
    9. #7
      Feb 2010
      I'm sorry I was a piston head in my youth (building and racing rice-burners), bought the Volvo so that I would not mod 2.4 block...?
      Thanks to both of you for answering my questions!
    10. #8
      Jan 2012
      Santa Cruz, Ca
      Ha! Good luck with that.
    11. #9
      Aug 2018
      Idaho
      The 2.4 T5 (B5244T5)
      https://forums.swedespeed.com/showth...559-2-4-vs-2-5
    12. #10
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by kTaLgsTo View Post
      Lots out there on the B5244T5. I built one for my VR that put down 487WHP and 513WTQ, but they are very hard to find and expensive. I’ve also run 30PSI through a shimmed 4T4 and it’s still on the road with more than 150k miles on the completely stock bottom end including rings.
      I would not run either engine without shims.
      Again, it all depends on what you want and how much $$ you want to spend.
      This is my 4T5.
    13. #11
      Feb 2010
      Just had my wife start it with the expansion cap off... no bubbles, but.... is this the tell/tale sign (or just condensation)? Car sat in cold for about 3 hours
    14. #12
      Aug 2018
      Idaho
      Get one of these...
      https://www.napaonline.com/en/p/BK_7...waAvkwEALw_wcB
      Will tell you almost for sure if it is cracked block. Depending on how cold it is outside, they can all make a little 'white' smoke. But yes your video is a little concerning...
    15. #13
      Jul 2011
      Get one of these...
      Some places (like oreilly) have those to borrow, and all you have to buy is the little jug of fluid for $8 or something like that
      2008 C30 R-Design MT Black
      2007 V70R GT Ti Grey Nordkap
    16. #14
      Jul 2013
      Georgia
      I still have a misfire on cylinder one upon starting the car, but no white smoke. If the engine was parked overnight, Vida will record about 50 misfires on cyl 1, and maybe 10-15 on cyl 2... but what drives me up the wall is the fact that I still go from full coolant, to literally nothing in the expansion reservoir when driving. Any ideas or next steps?
      You have a very slightly blown head gasket. Compression gasses are leaking into the cooling system, forcing the level low. Coolant leaking into #1 and 2 is causing the missfires. Have seen/repaired many blown headgaskets/warped heads due to overheating, but have never seen a "cracked block". (other than the 91 960 block would crack on the exhaust side when head was put back on and leak coolant externally)
      An easy test is to sniff the air above the coolant in the reservoir with an exhaust gas analyzer for hydrocarbons - there should be none. Sometimes the smell of HC in the coolant bottle is obvious just using your nose.
    17. #15
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by hoonk View Post
      B5254T4 experience a very high percentage of failures. Failure is characterized as a collapse of the upper cylinder wall at the .035” wide water passage between cylinders.
      You can find many, many examples with photos on this forum.
    18. #16
      Member Hounddogger's Avatar
      Oct 2014
      Northern Hemisphere
      20% of them crack... I have 2 cracked blocks from Rs (one mine, one bought for parts) sitting in my garage...
      Get a combustion leak tester...
      Exponents kill
      Elsa: 2004 V70R Silver Metallic&Nordkap Back from Valhalla @ 357,098 miles
    19. #17
      Nov 2006
      WI
      Austin , the west coast Dougy ....
      2006 V70R ElectriKap 167k
      2000 V70R Electric silver/Charcol 175K in dry dock being refitted
      1996 850 Platinum Wagon needs a new home (and valve job) - make me a offer
    20. #18
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by opelrick View Post
      Easy now......
    21. #19
      Junior Member rocketscience55's Avatar
      Mar 2017
      Washington D.C.
      Can you pull a spark plug out and look inside the chamber for the presence of coolant? If cylinder 1 is misfiring and the top of the piston head looks like its been recently power washed while the others have burned fuel remnants this can be a pretty good sign of a leak.
      https://www.youtube.com/watch?v=Cu4KGEDq8s8&t=28s
      2005 S40 M66, stock
      2019 XC40 T4 FWD, Momentum with Premium and Vision Package - Hers
      2013 C30 Polestar #141/250, Mototech exhaust, Volvo Skid Plate, RacingBeat RSB, - Sold
      1997 Volvo 850 N/A with 240k, 1 owner, SOLD 2017
      2000 C70 Convertible 5sp HPT, SOLD 2011
    22. #20
      Junior Member Julien's Avatar
      Jun 2018
      Put a coolant pressure tester on it overnight and pull the #1 spark plug. Inspect after 12-24 hours if there is coolant in the cylinder.
    23. #21
      Member
      Feb 2007
      Grosse Pointe Farms, MI
      Quote Originally Posted by Austin V70R View Post
      Easy now......
      Well technically neither one of you have an R now, right?
      07 S60R Electric Slvr/Nordkap 6MT Darton Sleeved/Rods/Pistons, RaceS60R FMIC, IPD Sways, Spec Stg3+ SMF, PDV Collar Sleeve, EFR7163, PM3, Aeromotive 340 fp, ID1050x, RS4 MAF, Devils Own Meth & Contrast Tune
      01 Audi S4, Tial 605's, built engine, etc
      93 Mustang Cobra, Incon Twin Turbo 347 Dart, etc
    24. #22
      Jan 2012
      Santa Cruz, Ca
      I have an 855R..... doesn’t that count?
    25. #23
      Member
      Feb 2007
      Quote Originally Posted by Julien View Post
      ^Probably best advice here relative to diagnosing the issue. You can try the combustion gas test kit referenced above but it may not be conclusive. If you pressurize the coolant system and inspect #1 for coolant but it's not obvious, try rolling up a piece of white paper towel and inserting into the cylinder. If there's coolant in there it should wick up and be visible when you remove the paper towel.
    26. #24
      Member
      Feb 2007
      R Forum (2004-2007)....nope! LOL, hope all is well Neal.
    27. #25
      Jan 2012
      Santa Cruz, Ca
      Quote Originally Posted by ElementR View Post
      You too Andy.
      How’s the car holding up? Still enjoying the 7163?
    28. #26
      Member
      Feb 2007
      Yes, it's fun but lately I just watch it sit as I have no need to drive it sadly. I took insurance off it a couple weeks ago as I await this madness to pass. I just use the family hauler (Expedition) for grocery runs.
    29. #27
      Feb 2010
      Found one 🙂
      So..... heads are the same, swap oil pans, reuse R factory turbo? (it’s 3 months old) What about cams?
    30. #28
      Jun 2019
      Vancouver, WA
      Found one 🙂
      I had the oil pan, plugs (they were new), coils (fairly new),injectors and two new VVT hubs installed when doing the swap.
      I got my motor from ProlixArgon here on Swedespeed, highly recommended.
    31. #29
      Jan 2012
      Santa Cruz, Ca
      Cams are the same. Only swap the oil pan and go. Lots of confusion about these engines, so ensure it’s a B5244T5
    32. #30
      Feb 2010
      Question: recommenced flash were I to drop the b5244t5 in with R turbo and IC?
    33. #31
      Oct 2014
      Northern Hemisphere
      No need.
      Exponents kill
    34. #32
      Feb 2010
      Quote Originally Posted by Hounddogger View Post
      No need.
      Awesome! Thank you so much! This is a total no brainer then
    35. #33
      Jun 2019
      Vancouver, WA
      2005–2009 Volvo S60 badged as S60 T5
      2005–2007 Volvo V70 II badged as V70 T5
      Very happy with my swap, runs very well.
      Just put in the MotoTech down pipe and IPD cat back, love the sound.
    36. #34
      Feb 2020
      Calgary, Ab
      Is this accurate?
      My cars: '04 S60R, '89 Vanagon Westy, '87 Saab 900, '86 Saab 900, '67 123GT, '66 122S
    37. #35
      Junior Member 4EVA's Avatar
      Jul 2010
      From watching forum threads and the facebook group over the last 2 years I can say that's pretty accurate. Plus, there was a poll here at some point which had similar numbers. :/
      2007 S60R Sonic Blue/Nordkap GT, ~50k miles
      1995 Volvo 850 Turbo Polar White, ~200k miles (previous car)
    38. Remove Advertisements
    Similar Threads
    1. "Drift Assist"?
      By Fmfosnacht in forum XC90 (SPA: 2016 - )
      Last Post: 12-02-2015, 01:47 PM
    2. Replies: 3
      Last Post: 09-16-2015, 05:14 AM
    3. Wet sleeve vs dry sleeve for B5254T4?
      By Red_Angel in forum R Forum (2004-2007)
      Last Post: 09-12-2014, 09:51 AM
    4. anyone ever experience an Anxiety attack?
      By nobbe3728 in forum Off Topic Forum
      Last Post: 11-08-2007, 03:12 PM
    5. check engine code PO455 appearing on the '96 850
      By 1sciroccofahrer in forum 850 (1993-1997)
      Last Post: 08-25-2006, 09:00 PM
