@Volvbro's 2007 S60 T5M Thread - Page 3
    Page 3 of 3 FirstFirst 1 2 3
    Results 71 to 77 of 77
    1. #71
      Junior Member rundy's Avatar
      Jun 2016
      MASSACHUSETTS
      Quote Originally Posted by ScottishBrick View Post
      No theyíre super cheap and readily available cause itís a TD04 and the downpipe is the same all angle flange turbos.
      Oh cool. I wonder why Volvo didnít just go with a 19T on the Rís if it outflows the K24 anyways?
      Current: 2007.5 Volvo S60 T5 M66 Magic Blue on 2-Tone // 1992 Volvo 240 N/A M47 Silver on Charcoal // 1991 Toyota MR2 w/ 1993 5spd 3S-GTE swap Red on Charcoal
      Past: 1999 Volvo S70 N/A M56 Nautic Blue on Charcoal (Kaputt) // 1988 Volvo 240 N/A M47 Grey on Charcoal (Totalled) // 1998 V70 T5 M56 Black on Charcoal (Kaputt)
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Quote Originally Posted by rundy View Post
      Cause Ford is cheap and had a deal with kkk-borgwerner. Kinda like how the ďrĒ manifold saves supply chain money but thatís all itís good for.
      2003 V70 T5 - Mystic/Graphite - M56LK - 211k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 305k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 246k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    4. #73
      Sep 2015
      Southern PA
      I keep seeing conflicting stuff on japanifold vs r manifold, some people say japan flows better, some people say it only sounds better and r flows better. Any objective data on it?
      Me: 2007 VR gt Slicktop Titanium Grey/Nordkap Wife: 2015 XC60 T6 AWD Ocean Race Past: 2006 V70 2.5T Willow Green/Oak, 2005 S60 2.5T AWD Silver/Black, 1991 745 White, 1982 242 GL Silver
      Past: 2006 V70 2.5T Willow Green/Oak, 2005 S60 2.5T Silver/Black, 1991 745 White auto, 1982 244 Silver 4spd w/od
      SwedeSpeed.com
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      Quote Originally Posted by tabormeister View Post
      Dougy bench tested one years ago. There was discussion about another bench test happening. But it's also pretty obvious just visually.
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 297k.
      1997 850R Estate. B5234T9/M66D. Bright Red/Graphite. 280k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 141k.
      Instagram: Jared's Volvo Page
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: 1999 S70 GLT Pewter/Oak. 101k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k. Sold to markj
    7. #75
      Dec 2014
      Connecticut
      Based on the firing order of Volvo 5 cylinder engines which is 1-2-4-5-3, the 2.5t manifold cannot out perform the Japanifold in the higher rpm range.
      With an 2.5t manifold the exhaust from cylinders 1, 2 & 3 is all routed through one runner. With a japanifold its cylinder 1 into 4 and cylinder 2 & 3 together, relatively separated exhaust pulses in firing order at that. The runners in the japanifold are better proportioned for 1 & 4 and 2 & 3 size wise. Japanifold is a 2-2-1 manifold, 2.5t is a 3-1-1 manifold. Interestingly volvo chose a 2-2-1 design for the RNC 5 cyl manifolds as well and ditched the 2.5t design.
      2.5 manifold was designed to save Ford money...2 lbs 1 oz of 304 stianless. Even at todays scrap prices thats a buck, the kind of "fat" that supply chain managers looooove to take credit for trimming.
      Now, real numbers.
      Japanifold is 10mm larger in diameter than a 2.5t manifold at the manifold to turbo transition, a constriction that simply does not make sense with the larger TD04HL housings and K24. IPD claims they found the "r" aka 2.5t manifold to spool 100 rpm faster. Considering ive never seen that test referenced in anything other than forum banter and its all of a 100 rpm that could be too easily manipulated by minute adjustments in wastegate preload, engine load ect.
      Of all the japanifolds ive harvested and sold, the worst warp we ever found was slightly less than 0.001". The average 2.5t manifold is about 0.015" and a lot of the ones from R cars and T5s are 0.030" or worse up to the point of not being able to be shaved flat again. Cyl 5 loves to lift off the head.
      Internal volume is obviously larger in the japanifold, I do not currently have a volumetric number on that but i should quantify it in the future.
    8. #76
      Sep 2015
      Southern PA
      Damn, ok sold. On my list.
    9. #77
      Jul 2012
      Europe
      And a japanifold makes the 5 cylinders sound much better also
      V70 2.4T5 M66 Summum
      Stage 2+ by contrast
    10. Remove Advertisements
    Similar Threads
    1. 2001 Volvo S60 T5M or 1998 S70 T5M?
      By JPS60T5 in forum S60 (2001-2010)
      Last Post: 05-24-2012, 08:11 PM
    2. Build Thread: cmurphy2266 S60 T5M
      By cmurphy2266 in forum S60 (2001-2010)
      Last Post: 05-20-2012, 02:24 AM
    3. Build Thread...2005 S60 T5M
      By diablo2828 in forum S60 (2001-2010)
      Last Post: 01-10-2012, 04:31 PM
    4. v70rm, v50 t5m or s40 t5m?
      By imhereftw in forum R Forum (2004-2007)
      Last Post: 03-30-2010, 04:12 PM
    5. which to keep? 98 s70 t5m- 99 v70 t5m?
      By baggerben in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-12-2009, 07:16 PM
