2015 S60 Polestar-Modifications?
    Results 1 to 7 of 7
      Junior Member StealthPolestar's Avatar
      Sep 2019
      Australia
      Hi All,
      I am thinking of starting to slowly modify my Polestar and wanted to know where I should start. Is there an engine tune available?
      What would the 1st few steps be in modifying this vehicle if it's worth modifying at all?
      Thanks
      2015 S60 Polestar Owner
      Junior Member mtnpolestar's Avatar
      Jun 2016
      Colorado Mtns
      I would suggest checking out the Polestar Owners FB page as there is a lot of discussions on mods there. Just search "mods" or "modification" or "tuning" and you will see many discussions. There are a few fellow Aussies on it that may also help you out.
      Jan 2019
      Quote Originally Posted by StealthPolestar View Post
      Hi All,
      Thanks
      Downpipe for a start. GFB turbo diverter valve. Intake manifold. Uprated intercooler and a Snabb intake kit or Resonator delete from Elevate. TDI tuning box
      SwedeSpeed.com
      Junior Member khoanni's Avatar
      Feb 2013
      Melbourne, Australia
      Downpipe would be a good start +1, from pass experiences with Volvo.
      Good to see another Polestar from Australia, Im in Melbourne.
      2015 S60 Polestar
      2003 S60 AWD 2.5T|Snabb Intake |Pierburg TCV |BC BR Racing Coilovers |Ultra-Racing Rear Strut | Upper engine / Lower transmission Polyurethane |
    7. #5
      Awaiting Approval
      Feb 2020
      Hi All,
      Thanks
      I'd be keen to understand how much extra the gearbox can take before I spent any real dollars on upgrades...
      Rob (Perth)
      MY14 S60
    8. #6
      Jan 2019
      Quote Originally Posted by Slocs View Post
      Rob (Perth)
      MY14 S60
      The Aisin AW TF-8# SC series is a 6-speed automatic transmission designed for use in transverse engine applications and produced by Aisin Seiki. It is designed to handle a maximum of 440 N⋅m (324.5 ft⋅lbf) of torque.[citation needed] It is built in Anjō, Japan.[1] It is also called the TF-80SC[2] (AWF21, AF40-6, AM6,[3] AW6A-EL) and TF-81SC (AF21).[4]
      The design team set out to create a 6 speed automatic that fits in the same space as a manual gearbox. It measures 358 mm (14.1 in) in length and weighs 90 kg (198 lb). Its combined use of a conventional 5-pinion planetary gearset and a compound Ravigneaux gearset makes it incredibly light and compact. This combination is known as a Lepelletier arrangement. The shifting of gears is managed by a sophisticated computer programme which oversees a clutch-to-clutch actuation. Gear changes are accomplished by one clutch engaging the instant the clutch from the previous gear disengages. The transmission control module (TCM) is located inside the transmission housing, instead of being located outside it. The advantage of this is to reduce external wiring as well as to provide a constant environment for TCM operation which encourages longevity. One aspect of the advanced nature of the electronics is at idle (along with required foot brake depression on e.g. Opel Astra), it automatically selects neutral gear to reduce internal temperatures and improve fuel economy.
      It is a sealed for life unit, using proprietary transmission fluid which is labelled as being maintenance free. However, for vehicles used primarily for towing, taxi or in mountainous environments transmission fluid change every 60,000 km is recommended. Transmissions made before year 2011 (generation 1) use JWS 3309 standard oil, while transmissions made from year 2011 (generation 2) use JWS 3324 standard oil.
    9. #7
      Jun 2016
      Colorado Mtns
      Quote Originally Posted by The Flute View Post
      Above it states it can handle a maximum of 440nm or torque....but our cars are rated at 500nm/torque (3.0L). So maybe it handles a bit more than the stated above?
    10. Remove Advertisements
    Similar Threads
    1. What's the difference between 2015 Polestar and R-design Polestar in US?
      By teaberry in forum Polestar Model Forum (2015+ )
      Last Post: 06-10-2019, 07:10 PM
    2. 2015.5 V60 Polestar (the full Polestar)
      By Marc Collins in forum FWD & AWD Cars For Sale
      Last Post: 02-16-2018, 03:46 PM
    3. 2015 / 2015.5 T6 R-Design - Polestar standard or optional
      By Slvrscoobie in forum XC60 (2010 - 2017)
      Last Post: 12-02-2017, 07:29 AM
    4. Polestar questions 2015-vs 2015.5
      By bludool in forum Polestar Model Forum (2015+ )
      Last Post: 10-25-2014, 11:42 AM
    5. S60 Modifications
      By s60potenza in forum General Volvo Discussions
      Last Post: 12-24-2003, 02:18 PM
