Shift knob replacement
    Results 1 to 7 of 7
      Dec 2019
      Seeing p.rico shifter retrofit pop up reminds me that I need to swap out my shifter, no clue what the PO did to it, but it has a bunch of weird and annoying scratches all over it. What I am not sure though, and something that may determine how soon I want to try and swap it out, is can the shift knob be replaced without dismantling the entire center console?
      While it comes apart fairly easily, it's a lot of work to simply replace a shift knob. If I need to remove it, then I might go ahead and replace things like the little rubber flaps in the cupholders at the same time (mine are fine, but if I am taking the console apart I may as well refresh those since the majority of the work is done).
      Thanks.
      Member Veefifty T5AWD's Avatar
      Feb 2009
      Lakes Region NH
      I'd bet those are actually hairline cracks - this is a known issue with the knob and mine was the same when I bought my S60. I had the selling dealership replace it under warranty. My new one is now starting to develop a crack, too.
      Logan
      2015 S60 T6 AWD R-Design Polestar
      2008 S40 2.4i - hers
      Former:
      2013 C30 Polestar Limited Edition #87/250 | 2005 V50 T5 AWD | 1995 Yellow 850 T5-R
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      Same here for my new to me XC70. You can get just the replacement knob for around $120 and replace it yourself. I saw instructions somewhere and it didn't look too tough.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
      SwedeSpeed.com
      Dec 2019
      I bet you guys are right, they are cracks, makes sense given the directions of them. I'll see if I can find the instructions to swap it out, although if it will just eventually crack anyway I might not be in that much of a hurry. $120 for a shifter knob, that's a set of IPD front and rear HD end links, I don't know that I need end links, just looking at things that cost a similar amount
    7. #5
      Aug 2017
      I have a 2017 S60i which I have had for 2 yrs and no cracking yet. Does the cracking start on earlier model yrs only? I was concerned because my old S70 GLT had that problem all the time.
      2017 S60i T5
    8. #6
      Member carreragt7's Avatar
      Aug 2008
      NorCal living in UT
      I’d just wet sand it first and see how it turns out. I have the cracks as well, and as they seem superficial to the top layer only at this point I figured I’d wet sand it first to see how it turns out. Worse case scenario would be wrapping that area with a vinyl.
      Current- 15 V60 T6 AWD RD Platinum P* Tuned
      Graveyard/Parts Bin/Projects:
      05 S40 T5 AWD GT Satin Pearl White
      06 V50 T5 AWD GT
      07 V50 T5 AWD M66
    9. #7
      Member p.rico's Avatar
      Aug 2017
      Wilmington, DE
      Check Nickshu's post. He did it without taking it apart fully. He took off the top portion and worked the tabs from the inside of the knob.
      I have it in my thread of getting the knob out only (in the DIY thread in the stickies), but I did it the "hard" way of taking the dash out. It takes all of 30 minutes to do the whole job though...
      2012 S60 T6 AWD - Vibrant Copper - Premium Package - Climate Package - Multimedia Package - BLIS - Polestar Optimization + Mods galore
      Running intro/install/DIY thread: https://forums.swedespeed.com/showthr...w-S60-T6-Owner!
    10. Remove Advertisements
    Similar Threads
    1. Automatic shift knob is NOT manual shift knob!
      By mf70 in forum S40 & V50 (2005-2012)
      Last Post: 11-27-2019, 07:03 AM
    2. Shift knob removal and replacement knob size?
      By wagonfan00 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 07-25-2015, 10:19 PM
    3. S60R GT OEM Shift Knob, Shift Boot, and Aluminum Shift Plate
      By BrotherMatt in forum FWD & AWD Parts For Sale
      Last Post: 01-31-2015, 01:46 PM
    4. 5sp Shift Knob & Shift Boot
      By g00b86 in forum FWD & AWD Parts For Sale
      Last Post: 05-06-2011, 02:38 PM
    5. Replies: 1
      Last Post: 10-07-2009, 04:17 PM
