Thoughts on using R134 with leak sealer
    Results 1 to 7 of 7
      Feb 2015
      Near the pimple on Philadelphia's ass
      The S60 now has 140K on it and it has developed a slow leak.Just charged it yesterday and it took about 20oz. Last summer I charged it in May and needed another shot in August. It is leaking somewhere on the compressor.Don't know exactly where on it though. Using a blue light,I can see the florescent telltale green residue on top of the compressor.
      So instead of replacing the comp,I am considering using 134 with sealant. Can I get some opinions on it please?
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Quote Originally Posted by chefricky View Post
      I would avoid it. It can mess up things far harder to replace than the compressor.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Member Oceans60R's Avatar
      May 2008
      Charlotte, NC
      Please don't. Total waste of your money and likely to cost you more having to fix anything gummed up because of the foreign additive.
      Just keep charging it and adding a small amount of AC oil to compensate for the leak until you can replace the compressor or whatever is leaking.
      2011 S60 T6 Ember Black/Off Black, P* Tune, TDI-Tuning Box, DO88 Intercooler, IPD DP, Simons Sport Exhaust, IPD rear sway bar, H&R Springs, Bilstein B8's, 19" Polestar Wheels, 90mm Wheel Studs
      SwedeSpeed.com
      Nov 2011
      Yep, If its a comp, just getcha one from Erie if you want a good used one. Re-shim any used compressors before installing them. But I would stay away from the stop leaks as well.
    7. #5
      Nov 2017
      Southern Tier NY
      My compressor is starting to get noisy, I can hear it cycle when idling. Not loud yet. I'll likely grab a lower mileage used one vs a new cheap aftermarket one.
    8. #6
      Nov 2011
      Dont forget to re-shim the used one ya get before you put it back on...Soo many of these get replaced unnecessarily when all they need is a re-shim.
    9. #7
      Senior Member Chilled Man's Avatar
      Jan 2007
      Backyard of TMI
      NO!
      Your AC system is a fixed orifice device. - a small hole that lets refrigerant expand and do its thing.
      /2006 S60 T5 /K24/R Calipers/17" pegs/OBX/Koni/Eibach/JVC/SNABB/IPDSway,
      /2004 V70 R/M66 /05+ Tails/ 05+ Console/Evolve Intake/IPD Sways/OZ/Kenwood/PHUZZ
      /2005 V70XC -Stock
      /2004 V70XC - Project Truk
      Unquestionable faith is the Epitome of Ignorance. - me
      Quote Originally Posted by Chicago_Wagon View Post
      (Sh!t, did I just agree with Chilled Man?) .
    10. Remove Advertisements
    Similar Threads
    1. Replies: 0
      Last Post: 10-26-2009, 01:02 PM
    2. Wash, Clay,Wax,Sealer
      By S602.4T in forum Photography
      Last Post: 08-05-2007, 10:24 AM
    3. Replies: 17
      Last Post: 06-02-2006, 09:28 PM
    4. Wax or sealer before clear bra installation
      By Helmut Ranff in forum R Forum (2004-2007)
      Last Post: 04-08-2005, 11:46 AM
    5. Leather sealer
      By Our R in forum R Forum (2004-2007)
      Last Post: 10-01-2003, 01:06 PM
