how do you remove engine cover on xc70 2012 T6
    Results 1 to 4 of 4
      Aug 2016
      pennsylvania
      Hi Everyone,
      The manual doesn't even discuss this, and I didn't want to break any clips trying to remove it. Can someone explain/show where all the clips are?
      Reg
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      You just tug on it and it will pop off. It's held on by several round detentes maybe, not sure what they're technically called.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
      Sep 2018
      One at a time, pull straight up on each of the 4 corners of the cover. When it's off, you'll see the 4 spherical ball-posts it locks onto. When replacing the cover, I get the rear posts lined up first, then press down on all 4 corners. You also can use the oil cap cutout to get things lined up.
    5. #4
      Aug 2016
      pennsylvania
      Thanks Guys. It was as easy as you both made it out to be. I needed to access a piece of metal as ground when I jump-start the vehicle.
    6. Remove Advertisements
    Similar Threads
    1. Replies: 1
      Last Post: 10-22-2018, 05:01 PM
    2. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    3. Replies: 1
      Last Post: 05-24-2015, 06:12 PM
    4. Replies: 1
      Last Post: 06-24-2009, 09:41 PM
    5. how do you remove the torque converter from the engine?
      By jordanvw in forum 850 (1993-1997)
      Last Post: 07-06-2007, 12:28 AM
