Engine Mount Thoughts
    Results 1 to 7 of 7
      Apr 2014
      Long Island, NY
      As I'm in the process of replacing the worn out components on my 850, I know the engine mounts are well overdue for a replacement. I've read pretty poor things about most aftermarket replacement brands, but many sites list Lemforder as OEM quality. Does anyone have any experience with the Lemforder engine mount kits? Or should I just stick with OEM Volvo?
      For reference, I am trying to work on a bit of a budget, but it's not worth putting in aftermarket parts if they're just going to fail in a few months.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Corteco rear /Hutchinson front hydraulic are the OE mounts.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      Apr 2014
      Long Island, NY
      Quote Originally Posted by ScottishBrick View Post
      Awesome, good to know, thanks! Any thoughts on the below kit?
      https://www.fcpeuro.com/products/vol...434435#fitment
      SwedeSpeed.com
      Dec 2014
      Connecticut
      Quote Originally Posted by dafuture 111 View Post
      It’s more expensive and not the oe part?
      You linked the Lemforder mount.
      As for the rest of them, the correct lower torque mount dog bone is the Hutchinson stiff which is (annoyingly) only sold bt eeuroparts
    7. #5
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      I used a Lemforder mount for the lower right (front of engine technically) and it's worked fine thus far. I would skip the really cheap mounts because you'll be doing them again.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    8. #6
      Apr 2014
      Long Island, NY
      Whoops, didn't mean to link just the Lemforder mount. I ended up grabbing a kit from FCP after doing some research.
      Is it necessary to do the lower torque mount as well?
    9. #7
      Nov 2019
      N. Arizona
      I would do all mounts, inc the lower torque. My feeling is that if everything is new and tight, then you will get the most life out of everything. If some parts are worn, then that might cause premature wear on your new ones. Upper and lower torques are easy compared to the rear mount closest to the driver. Don't raise the engine any more than is absolutely necessary to wedge that one in.
      All and all, not a hard job if you take your time.
    10. Remove Advertisements
    Similar Threads
    1. Replies: 0
      Last Post: 01-19-2012, 08:56 AM
    2. Replies: 0
      Last Post: 09-05-2011, 04:31 PM
    3. Thoughts on my initial thoughts
      By gjabo178 in forum S40 & V50 (2005-2012)
      Last Post: 04-05-2008, 01:23 AM
    4. Replies: 8
      Last Post: 06-29-2007, 07:42 PM
    5. RE: anybody looking for a custom phone mount,pda mount, or gps mount look here?
      By phanton5.9 in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 08-24-2005, 09:46 PM
