04 V70R M66 - Windsor, Ontario
    Results 1 to 2 of 2
      Jan 2018
      (SOLD) 04 V70R M66 - Windsor, Ontario
      04 V70R M66 - currently 337900km, in southwest (Windsor) Ontario, Canada. I am selling because I do not have the time to make this the project car I want. I want it to go to someone who is capable of giving it the love it needs. I'm asking $5000(CAD) OBO. I may have missed some details below, I can try to answer any questions.
      https://photos.app.goo.gl/2RA5zamNmoyS4YUw8
      I am the 3rd owner of this wagon. Purchased @ ~225000km and used as a daily driver up to January 2020. Oil changes every 6000-7000km, 91 or 94 gas depending on the price. 50% of the maintenance was done by me and the other was done by Volvo dealer and one independent mechanic. I have a slew of old (functioning) parts, I pretty much changed many parts proactively and kept anything that could be used in case I needed it in a pinch. Almost every replaced part in the car is OEM see list below. I have all receipts for maintenance and parts purchased.
      Functionally, the car runs great. Turbo has zero play in the shaft. Most importantly, all wheel drive works and 4C is fully functional. Car has been running a stock tune.
      When scanned with VIDA only have errors for the alarm system and cabin HVAC sensor - will demo for anyone seeing the car.
      I have all 3 keys. Switch blade keys both have broken springs, but work 100%.
      Car comes with original pegs wrapped in 235/45R17 94W Firestone indy 500. Car also comes with a set of winter wheels - 17" rims, wrapped in 225/50R17 98T Gislaved Nord Frost 100. Spare tire and tool kit still present.
      Some extras I have are the trunk tunnel cover and roof racks. Additionally, I have (in box) brand new OEM brake pads for all corners.
      I even saved the original down pipe and cat in case I would need to put it back on.
      Interior is about a B+, leather is in reasonable condition, no holes. Everything works - heated seats, power seat adjustment, seat position memory, auto dimming center mirror, radio. I have all the floor mats (summer + winter).
      Exterior has some obvious cosmetic damage on the passenger side that was present when I bought the car from the 2nd owner. Section with missing paint has been sealed with epoxy to keep water out.
      Below is a rough list of maintenance completed with dates and distance;
      Purchased Car Sept 2014 @ ~225,000km
      New 4C controller OEM
      New 4C struts x4 OEM
      New spring seats OEM
      New seat heaters x2 OEM
      New spark plugs OEM
      New fuel filter OEM
      Fuel pump controller moved inside trunk area
      April 2015 - 230,000km
      PCV service
      July 2015 - 235,000km
      New front sway bar end links
      Oct 2015 - 240,000km
      New driver side fog lamp OEM
      IPD TCV
      IPD fog lamp intake mod
      Dec 2016 - 260,000km
      New pads and rotors x4 OEM
      Replaced front control arm bushings
      April 2017 - 268,000km
      New headlight lenses
      July 2017 - 275,000km
      New heated side mirrors
      New Forge turbo bypass valve
      Oct 2017 - 290,000km
      Euro sport exhaust installed (DP + CAT back)
      Exhaust manifold gaskets
      New fuel pressure sensor BOSCH
      New O2 sensors (front and back) BOSCH
      Sept 2018 - 318,000km
      New timing belt OEM
      New water pump OEM
      New serpentine belt OEM
      New tensioner OEM
      New spark plugs OEM
      New coil packs OEM
      Intake manifold gasket OEM
      New MAF OEM
      New AC compressor OEM
      New receiver drier OEM
      Vacuum line replacement
      Charge pipe o-ring OEM
      Dec 2018 - 325,000km
      New upper engine mount
      New clutch kit - installed by Volvo
      Alignment completed by Volvo
      July 2019 - 335,000km
      New thermostat + coolant OEM
      Jul 2018
      PM sent.
    4. Remove Advertisements
    Similar Threads
    1. 99 Volvo V70r for sale in ontario, Canada
      By Nav in forum FWD & AWD Cars For Sale
      Last Post: 04-10-2013, 07:50 PM
    2. 01-04 Volvo S60/V70/XC70 steering wheel (Gray) Toronto, Ontario.
      By mncx in forum FWD & AWD Parts For Sale
      Last Post: 03-28-2010, 10:20 PM
    3. 1998 S70 T5M - Low Mileage 86k, MINT!/Windsor ON; Detroit Metro
      By TBM in forum FWD & AWD Cars For Sale
      Last Post: 03-17-2010, 11:34 PM
    4. Replies: 16
      Last Post: 12-25-2009, 11:27 PM
    5. Replies: 11
      Last Post: 10-31-2007, 08:29 PM
