Fixed ABS / DSTC Service Required but a couple of codes persist
    Results 1 to 2 of 2
      Sep 2019
      Not new to Volvo (I’ve had a C30 for about a year) but new to the XC60. Purchased one last week and drove it back home a few hundred miles. It’s a 2012 3.2 FWD with 82k miles. A few hundred miles into the drive the cruise disengaged and I got the message ABS / DSTC Service Required. Looked online (https://forums.swedespeed.com/showth...Volvo-31423572) did a bit of troubleshooting (cables looked good) and ordered the front right ABS sensor. The code from VIDA was BCM-C003407 and the sensor part number I ordered 31423572. Replaced the sensor this afternoon and the ABS / DSTC message went away, shifting is smoother and the various symptoms people list associated from this issue are gone.
      Now I went back to VIDA to check the codes, and also “erase all”, however two persist with a yellow circle (previously they were red):
      BCM-C00344A Right Front Wheel Speed Sensor – System Internal Failures – Incorrect component installed
      CVM-U041568 Lost Communication With Brake Control Module
      So, is this just a question of driving the vehicle for a few miles and things will reset or do I need to troubleshoot further? Thanks in advance for any insights.
      Sep 2019
      I wanted to follow up and report that after driving around, probably 100 miles or so, I was able to reset the codes with VIDA.
    4. Remove Advertisements
    Similar Threads
    1. Replies: 7
      Last Post: 02-12-2018, 08:18 AM
    2. ABS/Anti-skid service & Brake assist service required & ABS light
      By colin2211 in forum R Forum (2004-2007)
      Last Post: 04-07-2015, 04:15 PM
    3. ABS Brake Service Required and STC Service Required
      By SethMarshallAllen in forum S60 (2001-2010)
      Last Post: 06-10-2014, 10:21 AM
    4. Replies: 15
      Last Post: 10-29-2012, 09:55 AM
    5. Replies: 2
      Last Post: 07-06-2007, 11:13 PM
