Rock Chips and Suggestions on Headlight Restoration Product
    Results 1 to 19 of 19
      15.5 S60 with 69,000 miles on it. I'm under no delusion vehicles stay new forever. Car isn't ceramic wrapped so nature's worked its magic on headlights and hood with usual rock chipping. Headlights have some pitting as to be expected (see pictures). Any good product for smoothing out and restoring headlights with rock chips to improve visibility?
      Thanks.
      Sep 2015
      Iím in the same boat as you. My whole hood needs a repaint taking it down to bare metal. Front bumper need replacing as itís cheaper to replace than repaint. Headlights look the same as yours. May go down the road of replacing with used ones just in better condition
      Quote Originally Posted by limey View Post
      My hood has pitting, but I couldn't justify a repaint. I have one spot that could use touchup paint because it did hit with enough force to take away paint. It's probably about the size of a BB. Other chips you can see when sun shines off vehicle but aren't glaringly bad. I'd say a few dozen. If I were anal enough I might purchase one of these and fill in those small chips. Though it might do more harm and come out looking worse than it is now.
      Pretty much, if you're going to shell out for a repaint, I'd wrap the repainted hood. That'll be a nice $1000+ investment if not more.
      Far as headlights, I'm sure those rock chips affect the clarity and brightness of my headlights at night, which is why I am asking for potential remedies. Hate to think how much Volvo would charge to do a restoration. Probably isn't cheap! - Has anyone paid a dealer in U.S. and what is price?
      SwedeSpeed.com
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      You should search the internet for headlight refinishing how-to's - there are a ton of them. Go through various sandpapers then polishers and finally a finish coating. Probably best to just remove the headlights first before doing anything because they pop out in like 10 seconds. I may take this project on with my 105k mile XC70.
      Other option like was suggested would be to just get a set of low mile used ones from a recycler. Yours are just the regular headlights so they shouldn't be that expensive.
      Here's one for $120.
      https://www.ebay.com/itm/2014-2018-V...ry!44072!US!-1
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
    7. #5
      Junior Member rallyr32's Avatar
      Jul 2015
      Winston-Salem, NC
      My $0.02: I've head great success with polishing up headlights that were mostly flat. The P3 ones are a bit more tricky to get right because of the curved edges so just be patient and use caution. My indy charges $59 for a restoration; Dealership I *think* was $99. Walmart is $29. I tried WM on a vehicle from work and they did a surprisingly decent job. YMMV.
      2017 S60 T6 R-Design (His) - do88 FMIC | 2013 XC60 T6 (Hers) - IPD skidplate | 2012 S60 T6 R-Design - mods galore | 2006 XC90 2.5T AWD | 2000 S40 1.9T
    8. #6
      Member spiked60's Avatar
      Jul 2008
      Seattle
      I am in a similar boat, I've done 3m restore before and it was an improvement (on an older Subaru)
      I can say though, once you get them clean, I recommend lamin-x (or any other brand), but the thick protective layer is great for stopping any new damage, will be doing this to my lights next.
      The classic cruiser, 1972 164E, Alpine Blue Metallic.
      The new daily, 2011 XC60 T6 AWD, Terra Bronze Metallic.
      Previous:
      2009 S60 2.5T AWD, Ice White, Shark Stage 1
      2001 S60 fwd
      For the most current photos of the day, find me on Instagram
    9. #7
      Quote Originally Posted by Wayne T5 View Post
      Rock chipping on those but I get the general idea on replacement. Used Set might be around same cost as a restoration. I have googled restoration and it says average price is $80-150 though not sure what dealer charges.
      I was hoping for feedback from people here on the Volvo forum who have done the process and had good results. Versus a general google.
    10. #8
      Member beachnut's Avatar
      Jan 2004
      SW Florida
      First off I don't think you'll be able to restore your headlights with the expectation that they'll be like new with that amount of sandblasting/pitting. That would require new lenses (if you can buy them, then it's a pain to break the sonic weld), or used headlights like Wayne suggested. I know that's probably not your expectation but just saying. The factory UV coating is very thin. It looks like your damage is past that coating and into the polycarbonate. I could be wrong as I have never had to restore a set in that condition before. Maybe you can get them "better", maybe not. If those were mine I'd grab a good used set, polish them up and film them.
      I've been doing my own headlight restoration for several years now and trying different approaches/products. They are so many trains of thought it can be dizzying. Most agree that when the UV coating is shot it's time to take it off, through sanding typically. There's the 3M kit that a lot of people like, including me, but lately I've been wanting more steps than just 500/800/Trizact 3000, and I don't like their rubbing compound. Recently I've been using these Mirka discs https://www.autogeek.net/mirka-3-inch-variety-pack.html , although for tougher jobs I still break out the 3M 500 & 800 discs and do the rest with Mirka. These are all 3" discs and I use a hand sander like this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 . After sanding I like to use this Wolfgang kit with a 3" wheel on my DA polisher at 4000rpm https://www.autogeek.net/plastik-lens-cleaning.html . After that you have two choices (actually 3 if you feel like 2K clear), either film the lights or use a coating , otherwise the lights will yellow again, and the "protectant" in most kits doesn't last long at all. I've been using Opti-Lens, but it's spendy: https://www.opticoat.com/product/opt...coating-10-cc/ , now I'm getting ready to try this newer product from McKee's 37: https://www.mckees37.com/headlight-coating.html as it should be more economical. Finally, my opinion on film ... stick to the thinner stuff, like 8mil. Lamin-x was mentioned and I hate it. I have tried it twice but at 12+mil thickness I find it too hard for the newer curved lights, like our '15 XC60. Perhaps I'm not very patient ...
      2015.5 XC60 T6 Flamenco Red/Sand, Platinum, Tech, Blis - wifemobile
      2010 S80 T6 Silver/Anthracite, Dynaudio/Nav, Climate, Blis - my dd
      2005 S40 T5 Passion Red/Quartz, Dynamic Package, E46 bixenon retro - garage queen
      2005 S60 2.5T Black/Graphite, Premium, Sport, Climate - son
      Previous: '05 S60 T5, '04 S80 2.5T, '98 V70 T5, '96 854 Platinum
    11. #9
      May 2020
      https://www.youtube.com/watch?v=iDB5U4QUdD0
      This is one of the best videos I've seen on debunking bad products. I believe he concludes 3M and Maguire's(?) to be the best. The results for both of those are great. No help on the hood, though. My best advice is touch-up paint and then some of that scratch clear coat to smooth out the lines.
    12. #10
      Junior Member ckmack's Avatar
      Mar 2015
      Southern Maine
      In my opinion, if you try to polish those headlights you will not see any noticeable improvement to the clarity of light to the naked eye. Instead, you would be ruining the UV protection coating that is on the headlights and they will degrade faster than normal.
      Daily Driver: 2017 V60 T6 R-Design Bursting Blue / Black, 41k, "Bertie"
      Garage Queen: 1995 850 T-5R sedan Cream Yellow / Black, 97k, "Daisy"
      Garage Queen: 1995 850 T-5R estate Cream Yellow / Black, 287k, "Daisy2"
      Past: 2005 V70R Flash Green / Nordkap, 86k, "Flash"
      Past: 2005 S60R Black Sapphire / Nordkap, 88k, "Peggy"
      Past: 2000 V70R Laser Blue / Black, 174k, "Vicky"
      Past: 2000 S70 GLT SE Moondust / Beige, 175k, "Sandy"
      Past: 2013 S60 T6 R-Design Rebel Blue / Black, 88k, "Roxy"
      Past :2006 XC70 AWD Willow Green / Beige, 148k, "XC"
    13. #11
      Feb 2020
      For the head light restoration, Project Farm on youtube just did a couple comparisons in a video a few days ago. He found that the Sylvania kit was really really good, and not expensive.
      Edit: Looks like anticus already posted the video. I can't since I am at work.
    14. #12
      Dec 2019
      Quote Originally Posted by ckmack View Post
      That's why if you are doing it properly, you use some UV protection after you are finished cleaning the lens, plenty of different products out there either spray on or film.
      Best method I have found is various grits of sandpaper, a bucket of water and a bunch of elbow grease. Sand horizontally first, then when you have a nice even finish move onto the next grade of sandpaper and sand vertically, that way you can see where you need to pay attention to until you again get a nice even finish. Onto the next grade, go back to horizontal. I think I started with 800 grit on some I did a while back and went to 2,000 or 2,200 with 3 or 4 different grits in between. A good amount of work, but when you get to the 2,000+ grit and start to polish the headlights lens it's pretty satisfying.
    15. #13
      Oct 2018
      San Diego, CA.
      Quote Originally Posted by abcdefghii View Post
      +1. That's the way to do it. Patience is the key, and don't skip grades.
      I put the plastic film from ebay on mine. Works great.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
    16. #14
      1. I want to ask a few questions, so if I venture to try this on my own, I don't f*ck things up to put it bluntly. Do you use a wooden block or what do you wrap the sandpaper around for best results?
      2. Do you use a spray to moisten the lights or what is the preferred method to wet sand. After sanding with 800 and going up to 2000, what did you do in between? Did you wipe it off with soapy water or do you continue to move up grit without doing anything in between? I .E. Do you polish in between say 800 --- > 1000 etc or just use the 800. Go to 1000 and when all finished polish it up?
      3. Do you use horizontal motions on all grits in same direction?
    17. #15
      Dec 2019
      1. No wooden block, just hand, makes it easier to follow the contours of the headlight. I think some people do use a block, but as I mentioned, I prefer to feel the contour of the lens and with a block would be afraid of flat spots.
      2. No spray, I kept a bucket of water and just soaked the sand paper in there for about 15-20 seconds. In between grits I just wiped it with a paper towel to make sure I had not missed any areas, with it dry you can see that you have a uniform haze across the lens, then onto the next grit. You can spray the headlight if you wanted, it's personal preference really, the important piece is making sure to keep it wet. Depending on how bad yours are, you may be able to start with 1000 or 1500 grit, the ones I worked on had a scratch that I wanted to get out of the lens.
      3. I am not 100% sure what you are asking here, but I just did a back and forth / up and down, not just a single direction.
      Trying to find the video I watched as it was definitely helpful, but coming up blank on the exact one I followed. Searching headlight lens restore brings a ton of results, just see if you can find one where they are using sandpaper. I'd definitely watch a couple first though, just to get a good idea of what you should be looking for when sanding, I probably watched half a dozen different ones or so.
    18. #16
      Oct 2018
      San Diego, CA.
      A flexible backing material that helps to spread the finger pressure is ideal. A stiff block will flatten and distort the lens. It needs to allow the paper to conform to the lens. Be sure to avoid sanding-in any uneven spots, as it will distort focus of the lens. I bought the 3M kit, mostly for the polishing pad. After I read the directions, I set the dry sanding discs aside and went to the hand-held wet/dry. Too great an opportunity to sand in a lot of unevenness with a spinning disc.
      When wet sanding, there is no such thing as too much water. I've used spray bottles, the bucket method, and also flooded from the garden hose. If using too little water, a pasty sluff will develop, which is kind of satisfying, but not productive. Better to keep it rinsed away so the paper doesn't slide around on top of a layer of plastic paste. A little dish soap in the water helps, as it reduces the surface tension of the water. I read that about the soap, somewhere, and may even be true, but I know it doesn't hurt, Just be sure to do a very even sanding at each grit of wet/dry. Rinse well between grits and dry it off and inspect. At some point you may have to decide to let some chips remain, if there are bad ones.
      Some people say to sand in a linear mode at 90 degrees at grit change to better see the effectiveness of each grit. You're looking for a very even appearance at each grit, and don't be alarmed at the milky opaque look of the lens at the beginning. It will be crystal clear when the process is complete.
      Like abcdefghii says, watch some YouTube videos. You'll soon figure out which ones are good. You can skip the ones about coating the lights with weird household products, but be sure to search for "clear wrap headlights". I bought the film cheap on eBay, and it works great. The best chemical treatment only last 6 months. My clear vinyl headlight wrap is still crystal clear at over a year, parked outside, facing South.
    19. #17
      I spoke to my neighbor today and he made an excellent suggestion....Pick up a pair of rock chipped ones from Salvage yard and first practice on those to get the feel for things before moving on to your vehicle. This way, you can see what technique works and then attempt your own car.
      Think I might heed his suggestion to gain a little practice.
    20. #18
      Dec 2019
      That's a great idea, doesn't even need to be a Volvo headlight, just something with a lens to practice on.
    21. #19
      Yep. Told him I never had that epiphany and that he definitely was thinking outside the box. So that's what I'll aim for and see what results I get. And if I'm happy with my abilities and technique, then attempt on my car. Better to make mistakes on a donor pair of headlights than screw up an expensive set on my Volvo!
    22. Remove Advertisements
    Similar Threads
    1. Tons of rock chips on my black 2015 XC70 making me headache
      By sulu_cwru in forum General Volvo Discussions
      Last Post: 04-14-2016, 09:02 PM
    2. Tons of Rock Chips on my 2015 XC70 driving me creazy
      Last Post: 03-16-2016, 10:21 AM
    3. Protection From Rock Chips
      By itoredmond in forum C30 (2007-2013)
      Last Post: 05-08-2013, 12:04 PM
    4. rock chips and grill painting
      By juve021 in forum R Forum (2004-2007)
      Last Post: 04-14-2009, 03:41 PM
    5. rock chips
      By p0cket penguins in forum The Detailing Forum
      Last Post: 11-01-2006, 11:31 PM
