TPMS 2016 vs 2013
    Results 1 to 3 of 3
      Dec 2019
      TPMS 2016 vs 2013
      I recently purchased a set of 2016 xc70 wheels and installed them on my 2013. The TPMS system error warning is showing on the dash.
      From what I can tell, the TPMS are the same part numbers. I don’t have any reset tire sensor option under the My Car menu, so from what I have read it will learn the new sensors automatically.
      Is this right? We have driven the car multiple times since the tires were installed.
      Thanks.
      Nov 2016
      Wash. County, Oregon, USA
      Which TPMS system do you have? Our 2016 has ABS-based TPMS with no in-wheel sensors like the older cars have.
      Easy way to tell is the older in-wheel sensors have rigid valve stems where the newer ABS-based system uses standard flexible rubber valve stems.
      2016 XC70 2.5L T5 AWD, Platinum, Seashell/black, ipd rear bar, Curt hitch and wiring
      Previous Volvos: '16 V60CC, ours; 7? 245DL & '6? 145DL, hers; '68 122S Wagon, his.
      Non-Volvos previously owned: waaay too many to list here.
      Dec 2019
      Thanks, that is what I was worried about- new wheels are definitely flexible. I will have to get some tmps at some point...
    Similar Threads
    1. 2016 V60 P* VS 2016 R-Design V60
      By Ridevt in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 03-23-2017, 10:03 AM
    2. Replies: 1
      Last Post: 05-04-2016, 12:31 PM
    3. Stage 3 Tunes: Rica vs Autotech vs MTE vs Shark vs BSR vs???
      By one_happy_hippy in forum S40 & V50 (2005-2012)
      Last Post: 04-05-2014, 02:31 AM
    4. 2013 XC60R vs 2013 XC70 T6
      By 3g3t7i in forum General FWD & AWD
      Last Post: 07-02-2013, 09:29 AM
    5. To TPMS or not to TPMS, that is the question. (New Rims)
      By stealthS60AWD in forum General FWD & AWD
      Last Post: 04-28-2009, 09:27 PM
