I feel dumb...
    Results 1 to 26 of 26
    Thread: I feel dumb...
      Oct 2017
      New Hampshire
      I feel dumb...
      My CEL is on. I read the code (P2421), replaced the part, ran the test, it ran clean and the code is no longer current. (There are no current codes). How do I get the CEL to go out? I have an appointment for inspection in 15 hours and it won't pass with the light on. I've driven it about 30 miles since I replaced the part and 5 miles since I re-ran the test.
      If you're answering that question, maybe you can also tell me how I can get information from the tire pressure monitor system...
      John C
      2011 XC90 3.2 175,000 miles and counting...
      Global Moderator GrecianVolvo's Avatar
      Nov 2001
      Southern California
      Quote Originally Posted by John C View Post
      Follow this sequence:
      1.key in I position.
      2.hold trip meter in.
      3.turn ignition to II position.
      4.wait until service icon flashes twice.
      5.release trip odometer button
      I don't understand your question regarding your car's TPMS; it's not like in the newer cars but when low inflation pressure is detected or if a sensor is not functioning properly, TPMS will light up the tire pressure warning light in the instrument panel and will display one of the following messages in the text window: "Tire pressure low or Tire needs air now"
      2001 Volvo V70 T5 M SR, Classic Red/Graphite Lthr, TME Stage II ECU, 3" Downpipe w/ Cat-back exhaust from MTE, Volvo Roadholding & Lowering Kit w/ Nivomats, 17" PEGASUS, Rear Spoiler, Dolby Surround Sound
      2019 V90 Cross Country Osmium Grey metallic w/ Charcoal L, Advance, Retractable Tow Hitch, Polestar, 19" wheels
      2019 S60 T6 AWD Inscription Black w/ Maroon/Brown L, Advanced, Heated Seats/Steering, Charcoal Headliner, Park Assist Pilot, 4C, Ext Styling Kit, 19" wheels, Polestar
      Oct 2017
      New Hampshire
      Thanks, I'll give that a try, but that's the same procedure I use to reset the oil minder. Will it also do the CEL?
      As far as the TPMS goes, I'm getting a message that the TPMS system needs service. I figures VIDA could temm me more, but I don't know where to look.
      John C
      SwedeSpeed.com
      bring it to autozone or the like. have them read the code and then clear it. the only way to clear it would be a scanner or drive cycle. you can let it go through the drive cycle, but you need to perform that to be ready for inspection after a clear anyway.
      2010 XC90 V8 - 140k miles
      2012 S60 T5 - traded with 177k. Lost compression on cyl 5.
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
    7. #5
      Oct 2017
      New Hampshire
      Maybe I'm not understanding everything. I went from the beginnings of ODB I to "way too complicated for me" in one step. Anyhow, I thought if the code was no longer "current" or "active" the CEL should go out by itself. Running the test of the EVAP control system relegated the current code to history. Vida said I had no active codes, yet the CEL was on. Clearing the ECM codes in VIDA did nothing (maybe operator error on my part) and they remained in history, along with a ton of other (non-ECM codes that never set any warnings.
      The "hold the trip odo reset button" trick didn't clear it. Disconnecting he battery and touching the plus and minus together did clear it. Now, I just hope it will pass...
      [soapbox]What really irks me is that, apparently, this code doesn't even indicate a problem with the emissions system; it indicates a problem with the system that checks the emissions system...[/soapbox]
      John C
    8. #6
      Ah. Did you go to the “delivery” tab and erase all codes?
    9. #7
      Oct 2017
      New Hampshire
      Quote Originally Posted by Masscomguru View Post
      Yes, well, all ECU codes. there were three. Two that have been coming and going for years, and this one.
      I now believe I will fail due to monitors not ready. There's a short drive cycle in MVS I'm going to try to accomplish before I go in, but I don't have a lot of hope at this point. Film at 11:00...
      Used to be you could drive in and get tested without an appointment...
      John C
    10. #8
      Sep 2018
      emission readyness trip we use is 10 miles on highway light throttle, stop get out and lock car and wait 5 min and drive back. works 90% of the time and takes about 30 min total
    11. #9
      Oct 2017
      New Hampshire
      Birch999: that would have been easier that what I tried. What I tried didn't work anyhow. It failed because the Evap and O2 monitors weren't ready. I have 60 days to get it to pass.
      So, is there a way in Vida to tell if it is ready?
      John C
    12. #10
      Sep 2018
      im not sure that info is in vida, it might be but im not a tech, just an adviser. the state gave us a readyness monitor that plugs into obd port and turns on green light when tests complete but other than that im not sure how to tell when it is ready other than plug it into inspection machine
    13. #11
      May 2018
      With an ELM OBD-II Bluetooth dongle and Torque Pro on your Android you can check the readiness quickly. You'll need a different set-up for iPhone.
      I've got to imagine that VIDA has this built in somewhere.
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
      1991 Volvo 745 Dog Waggin' 2.0
      1995 Volvo 945 Turbo
      2011 Volvo XC90 3.2 AWD
      2013 Volvo XC60 3.2 AWD (Wife-mobile)
    14. #12
      Quote Originally Posted by RyanR View Post
      Do this. There are other apps that work as well. A good app will show the readiness monitors. Also check your state inspection handbook. It will tell you the Pass/Fail parameters. IIRC, in NJ The CEL can be on as long as it isn't emissions related. You can also have one readiness monitor not green as long as it's not the Cat/O2. The Evap is a common one to not have green because it can reset after getting gas and not having the cap sealed properly. But every state is different.
    15. #13
      May 2017
      Chicago & D.C. Metro
      Here is a pic using the Torque (free) app on an Android phone and a cheap Amazon bought Bluetooth OBDII connector. This was for a non-Volvo vehicle, but I was able to get all systems ready except one in a matter of two days of driving doing errands. In my state, one unready system is acceptable.
      You can Google different ways to meet the readiness that different makes use. Some general parameters to meet might be to maintain at ~55mph for 5 mins (no brake), coast down to 15mph without pressing the brake, accelerate to 80mph from (35mph &) 55mph in different light-mid throttle and hold 80mph again for a few mins, etc. Repeat after turning engine off and locking door so systems go to sleep for at least 10-15mins 1-2 times and do another lock doors overnight because the engine has to be completely cooled down so normal warm-up happens again. Etc.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
      Why it's better to use synthetic oil instead of conventional
    16. #14
      Oct 2017
      New Hampshire
      Thought I'd give an update, good for a laugh...
      I haven't had much occasion to drive it lately, so I haven't hooked it up to Vida yet. Yesterday it was pouring rain and I had to run a short errand. The CEL came on early in the trip, maybe at startup. I wasn't pleases, but not to upset as I've always suspected that the converter efficiency code was relates to wet weather. However, what did surprise me was that later in the day, after the rain stopped, it went out. Usually, it doesn't go out for a couple of days.
      Guess I need to plug it in, and (hopefully) get it retested while it's code free.
      John C
    17. #15
      Oct 2017
      New Hampshire
      Still feeling dumb...
      With an E-Bay ELM OBD-II Bluetooth dongle and Torque Pro on your Android you can check the readiness quickly.
      OK, so I ordered an ELM ODB-II adapter and downloaded the free version of Torque. The app went through a lot of connecting gyrations and finally ended up with a message something like "protocol 5 appears to work" but I don't think I ever got anything back from the ECU. Downloaded a different app and it also had issues connecting and never gave me any data. I think I tried "check codes" but never got anything that looks like a response.
      Is there a way to test the device? Or, should I just tell the vendor it's not working? I sort of figured it would either work or not, but it appears to connect up and negotiate a protocol, but nothing else.
      Just noticed Chitown's screen shot. I don't get any data like that, and, I think, the little blue auto on the top blinks all the time.
      John C
    18. #16
      May 2017
      When you use a Bluetooth wireless OBDII adapter, it helps to turn the phone/device to airplane mode, then turn on Bluetooth. There can be interruptions to the app. Also, make sure your phone/device is close to the adapter while it is connecting, like place it on your left lap.
      That is worth a try. If it doesn't work, even for other vehicles, then it could be the BT adapter.
    19. #17
      Oct 2017
      New Hampshire
      Yeah, I had it on my left thigh. I can try airplane mode.
      While you were posting I added this:
      John C
    20. #18
      May 2017
      Did you also set your screens in Torque? You have to go into the menu, choose which gauges you want to add, then the size of gauges. When it is added, you can hold and drag to position. It is a little weird at first, but you can set different screens and swipe between them.
    21. #19
      Oct 2017
      New Hampshire
      No, I think I did put one gauge on there, but I don't think I ever got a reading. All I really care about is reading state of the the monitors, so that's all I paid attention to.
      John C
    22. #20
      May 2017
      Not every gauge will work. Try some others and some basic ones too. Hopefully, you can get this to work for you.
    23. #21
      Oct 2017
      New Hampshire
      News flash - the listing for the adapter I bought has been removed. Also, the CB in the unit does not connect to all the pins, so I'm thinking they got a bunch of fakes. Shipping was delayed, probably while they waited for the container form Shanghai to arrive.
      Do you know what protocol Volvo uses? Not all adapters support all protocols. Or, a link to the one you have.
      John C
    24. #22
      May 2017
      I think I bought this four years ago and it still works with Torque. It has over four thousand reviews/ratings. For reading and clearing codes on an older vehicle, it still works. Some of the updated protocols can connect to more sophisticated apps and trigger ABS and such, but I would use VIDA for that. I did notice my adapter can be loose or tight, depending on the vehicle. In one car, I had to use blue tape to keep some upward force so it connects. I remembered the emissions place said some cars go on loose, so a lightbulb went on when I had trouble connecting.
      https://www.amazon.com/Veepeak-Bluet...148080&sr=8-13
    25. #23
      Oct 2017
      New Hampshire
      Well, I got an instant refund. It's unclear if I have to return it or not; I think not.
      Checked the one you linked to. Of course, they're out of stock. What are the chances the shipment they have coming in on the 30th is also defective?
      John C
    26. #24
      Oct 2017
      New Hampshire
      Well, got another interface and it works correctly. Monitors are not ready, though. I guess I have to get it out on the highway, even though I have nowhere to go...
      John C
    27. #25
      May 2017
      Glad you were able to figure it out! Hmm, do you need a reason to drive the XC90? Haha
    28. #26
      Oct 2017
      New Hampshire
      It's all about the QC...
      John C
    29. Remove Advertisements
    Similar Threads
    1. Replies: 5
      Last Post: 12-20-2011, 04:40 PM
    2. Brake Pedal Travel and Feel; Acceleration and Steering Pedal Feel
      By geokilla in forum S70, V70 & V70XC (1998-2000)
      Last Post: 03-08-2011, 11:00 AM
    3. A couple dumb questions for you
      By VC1125 in forum XC90 (2003 - 2014)
      Last Post: 04-13-2010, 08:23 AM
    4. ok Sort of dumb Question
      By dprem in forum C70 (1998-2004)
      Last Post: 03-15-2010, 11:30 PM
    5. Now, this is just a dumb, dumb move...
      By JRinPR in forum Car Lounge
      Last Post: 07-04-2006, 09:21 AM
