Kw3 coilover suspension setup
    Results 1 to 12 of 12
      Jun 2017
      Maryland
      I need help tunning my kw3 suspension. I keep getting slight wapples in my steering wheel although I have brand new tires. A shop told me that Lower spring might be too compressed and that could lead to steering wheel shake or wapple. How true is this ?
      Feb 2015
      Quote Originally Posted by anewman644 View Post
      Holy crap. Yeah, that bottom spring is not a spring anymore. It's currently infinitely stiff, likely causing a bunch of unwanted harmonics.
      Why do you have the collar cranked up so far? What does your ride height look like?
      Whether or not that's your issue, I cannot say.
      When do you have these wobbles? My steering wheel also does this when I'm in process of moving my steering wheel off center in a higher speed corner. I believe this has more to do with shock tower / strut bearings, though.
      First and foremost, fix that coilover setup, then go from there.
      Sent from my Pixel 2 using Tapatalk
      2015 V60 R-Design - Onyx Black Metallic / Off Black
      2004 Mazda 6s Touring - 3.0 V6 / Manual
      2008 Suzuki SV650 - Pearl Novelty Black
      2002 SVT Focus Turbo - Dead and gone
      Feb 2015
      Actually after thinking about it, your ride height is independently controlled.
      Your ride quality must be just awful.
      Jun 2017
      Maryland
      Quote Originally Posted by emgrock1 View Post
      So the vibration was happening around 60-65 mph. I took it to performance shop and they did road force balance and made it way worse. They told me I needed new tires and that my Michelinís although had thread they were bad. So I went to firestone to get new Bridgestone tires. I requested they do road force balance and also do alignment after installation. The wobble is very little but I just want it gone. After spend whooping 900. Attached pictures should show you the ride height
      Feb 2015
      Definitely not shock related.
      Do your wheels use a hub centric ring?
      Jun 2017
      Maryland
      Yes I have hub rings.
      Feb 2015
      Well, I would try moving the wheel locations and see if you notice any difference. Even one from to the rear.
      Next, adjust those shocks.
      I'm not familiar with the KW coilover setup but I assume the reason you have those cranked down so far is to gain ride height, yes? If you want to maintain your ride height but also properly use the springs I would think KW has a spring perch spacer to achieve that. All I can say is, they shouldn't be compressed like that and could definitely cause some odd behavior.
      Jun 2017
      Maryland
      Yes I want to maintain this ride height. I donít know if by turning or loosing that lower spring will change the ride. also I am taking it back to firestone Tuesday.
      Feb 2015
      I mean, that's what it's intended to do BUT you have it cranked down so far I think you could afford to loose some turns without any impact to ride height. I would suggest it.
      Jun 2017
      Maryland
      Okay will try and see if I can do it myself or find a performance shop to do it.
      Aug 2011
      RI
      I have a similar wobble at that speed that I can feel in the steering wheel only turning my wheel through a curve or changing lanes like mentioned above. It is very minor and goes away when I swap the front wheels to the back, so I assume itís a slightly bent rim. Maybe you should try swapping your wheels front to back and see if that helps.
      2002 S60 T5M
      235K miles
      Black Sapphire Metallic
      Jun 2017
      Maryland
      Quote Originally Posted by Seamus View Post
      Okay will trying bring both rear tires to the front first. Before I start messing with the suspension or I will take it back to firestone and request the check it again. Maybe they did not road force balance it well.
    15. Remove Advertisements
    1. KW3 coilovers
      By anewman644 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 02-23-2019, 02:46 PM
    2. TA technix Rear Coilover setup.
      By CMOD_R in forum FWD & AWD Parts For Sale
      Last Post: 06-07-2015, 09:42 PM
    3. Trade shift boot setup for spaceball setup
      By aReyouin? in forum FWD & AWD Parts For Sale
      Last Post: 10-28-2012, 12:01 PM
    4. Replies: 0
      Last Post: 11-12-2007, 09:40 AM
    5. IPD setup or Evolve setup?
      By Stoobey in forum R Forum (2004-2007)
      Last Post: 01-17-2007, 10:38 PM
