Clunk when engaging transmission
    Results 1 to 16 of 16
      Jun 2015
      I have a 2009 XC90 6cyl. 103k miles
      It has slowly developed a "clunk" of sorts when you put it into gear from park (either reverse or drive...doesn't matter)
      To my knowledge, it has never had a tranny service, and I see no signs of any leak underneath, but could fluid be low? is service suggested? Am I too late and a clunk is a sign of detioation of some kind? Maybe not enough info to answer, but I'd love to get some guidance. Many thanks
      Mar 2014
      You can check/service your transmission like this: https://www.youtube.com/watch?v=EAb9...ture=emb_title
      Easiest place to start otherwise would be the upper torque mount: https://www.fcpeuro.com/products/vol...c90-30680708-1
      and lower engine/transmission torque mount: https://www.fcpeuro.com/products/vol...inson-30793792
      If you can have someone engage the transmission while inspecting these, and look for excessive movement. The lower mount bolts up underneath, where the engine mates with the transmission. The top mount is on the top rear of the engine.
      2004 XC90 2.5T FWD + 2006 XC90 2.5T
      Jan 2017
      Cross Country
      Quote Originally Posted by dswood1 View Post
      Maybe axle ping?
      May 2017
      Chicago & D.C. Metro
      What you are experiencing is kind of normal for your mileage, however, it is a good time to address the maintenance and that might help reduce the occurrence.
      It could be the transmission fluid, transmission valve body, engine mounts, axles/CVs, axle bolt, etc. Some of the Drive-to-Reverse clunk/thump can happen at different temps too. It could be one or a combination of normal wear and maintenance.
      The best thing to do now is first changing your transmission fluid. Then change the engine mounts. If you do a turn when changing from D to R, while backing up into the garage or parking space, then it could also be loose CV joints/axles. The axles might not be broken, but have normal wear. Not to worry as the driveline for the 3.2 is rated for the V8 power, thus with the lower torque, the axles can last longer.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
      Why it's better to use synthetic oil instead of conventional
      May 2014
      Australia
      I have a similar clunk with my V8 with 150,000km.
      I changed fluid and no change.
      I now assume that it is just the valve body doing its job changing into gear. I honestly do not remember if it was there when we bought the car as I stressed out about a leaking power steering pump at the time.
      If someone has a V8 or 3.2 that does not clunk - please advise.
      Given that your 3.2 is clunking same as my V8 - I'd assume its just valve body wear - if its asymptomatic, doesn't need to be replaced.
      Oct 2018
      San Diego, CA.
      '09 XC90 3.2 with 97k miles (not km).
      No kind of clunk at fore-aft shift. Threw a lot of parts at it to renew, rather than repair when I bought it. Axles, port aft motor mount (leaking), upper torque (actually worn), ball joints, control arm bushes, trans oil change, and poly sub-frame inserts.
      Didn't actually have a clunk before, either, come to think of it.
      I'm always apprehensive of the cold start high idle shift-to-gear, and try to wait until it comes down, but that seems to be "muscle memory" rather than a real concern. The smart boxes between engine and trans reduce the engine speed before trans engagement even if high idle is still on. No clunk.
      2009 XC90 FWD 3.2, 2013 S60 T5
      In the past: '89 745, '91 940, '82 242, '67 122S, '67 123GT, '71 142E, '62 PV544.
      Nov 2002
      Russell Twp, OH
      Quote Originally Posted by SwissXC90 View Post
      Maybe axle ping?
      That's what I was going to say. I had the same thing with my XC70 so I re-torqued the axle bolts and it's almost been eliminated. The next step is to get a pair of the anti ping axle bolts.
      Jan 2017
      Cross Country
      Quote Originally Posted by Wayne T5 View Post
      My XC90 had axle ping. Dealer stuffed the axles splines with heavy grease, been good for over 3 years now.
      May 2017
      I posted before about the issues with the iPd anti-ping axle bolts using the newer design longer bolt. For my 2008 XC90 3.2, iPd had the wrong bolts (not enough threads) and the rubber cone that is suppose to give some tension/isolation for the axle is too short. https://forums.swedespeed.com/showth...ipd+axle+bolts
      Nov 2019
      Only had my 2003 xc90 T6 2.9l 270 km since november I think and it started pinging when I would engage the transmission 6 weeks ago. Was wondering what was that sound. Hopefully just something to grease or small bolts to change...
      If it's a rubber mount, depending on where it is, hope not to bad...
      2003 xc90 T6 2.9l 270 000 km 167 000 miles Quebec, Canada
      Member Hong Kong's Avatar
      Aug 2006
      sLOVEnia Country EU
      I will tell you how I solved this clunk on engagement or sometimes when I slow down and use manual mode from higher gears to 2' clonk was present.
      Simply I changed front joint and no more clunk. Before I changed also all engine supports, bevel gear, sleeve, torque limiter, top mount but all this
      didnt solved my clunk on engagement or reverse or slow motion move than clunk. Joint in front on main axle going to rear solved. Happy. See photos.
      Cheap and quick as all joint inside was worn and have lot of space to produce CLONK.
      XC90 2.5T VOR AWD 2006 320.600 km
      Proudly GUINNESS WORLD RECORDS and VOR XC90 2.5t Nr. 615 from 1574 Volvo's 31.03.2019 UK
      + 5704 km longest distance traveled to #Volvo600 UK meeting.
      Nov 2019
      Quote Originally Posted by Hong Kong View Post
      I am checking right now and looking for this part. Can you give me the part number just in case.
      Would this be the part
      on rock auto
      ULTRA-POWER 932501 {#30735027} Info
      AT DRIVESHAFT; FRONT; 4WD/AWD
      or this
      https://www.amazon.ca/Dorman-932-501...1554151&sr=8-1
      On fcp Euro I find this
      Volvo Drive Shaft CV Joint Kit - Genuine Volvo 31216175
      https://www.fcpeuro.com/products/vol...0-s60-31216175
      one part is 200 to 300 the other around 30 to 60 ??
      What do you have to remove to fix this front axle joint or the whole axle ??
      thanks
      Mar 2014
      I recommend this company for the propshaft CV or entire propshaft https://coloradodriveshaft.com/products.htm
      They've been around a while and are used by a lot of members here; including myself. Good quality products.
      Ebay store: https://www.ebay.com/usr/coloradodri...p2047675.l2559
      https://www.volvoxc.com/forums/showt...V-joint-repair
      https://www.youtube.com/watch?v=nR78PTlzXGE
      Oct 2018
      San Diego, CA.
      Hmmmmm... guess I missed where the OP said he has AWD?
      Nov 2019
      Quote Originally Posted by Capndirk View Post
      Yes have a 2003 xc90 AWD T6 2.9l
      Nov 2019
      Quote Originally Posted by wanderdune View Post
      thanks
      I did have the proper item.
      Weird that this item ranges from 45 to $360 on fcp euro
    19. Remove Advertisements
    1. Left Turn Clunk-Clunk-Clunk
      By mgfletcher145 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 09-21-2011, 03:09 AM
    2. Left Turn Clunk-Clunk-Clunk
      Last Post: 09-20-2011, 05:39 AM
    3. BANG! CLUNK clunk clunck clunk OH [email protected]#$$%
      By Thanatos in forum R Forum (2004-2007)
      Last Post: 11-19-2010, 01:58 PM
    4. Replies: 37
      Last Post: 12-26-2009, 08:46 AM
    5. Replies: 8
      Last Post: 08-13-2007, 08:58 PM
