AW55 GT Versus Non-GT
    Results 1 to 6 of 6
      Member Exocet's Avatar
      Southern Tier NY
      Are there any mechanical differences between an AW55 with Geartronic vs. a non-Geartronic? I thought the differences might only be in the TCM.
      Sent from my SM-G950U using Tapatalk
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
      Southern Tier NY
      Also, what's the difference between an AW55-50SN and an AW55-51SN? Based on a small sample, the 51 appears to be the GT and the 50 is non-GT. Correct?
      Oct 2014
      Boston
      51 is 50 with all/most of major hardware problems fixed. 51 is more beefy and is considered as one of the best transmissions in its class.
      Geartronic is a function of TCM, not hardware.
      Southern Tier NY
      Quote Originally Posted by vtl View Post
      Thanks. In that case, I'll look for a 51. Any idea when the change was made? 05s look to be 50s and 07+ seems to be 51s. I thought the Geartronic function was strictly in the TCM.
      Oct 2014
      Boston
      Quote Originally Posted by Exocet View Post
      You need to split both gearboxes and swap differential from your 50 to 51, I think. Otherwise you'll get a gear ratio mismatch error.
      MY05 XC70 is 51 for sure, I have 2 of them. MY02 V70 FWD was 50.
      Southern Tier NY
      I have a 51. As long as I get another 51, I should be set.
    9. Remove Advertisements
    1. ***HELP***Driver Side High Beam not activating >>>>>>>>
      By JDELUNA in forum R Forum (2004-2007)
      Last Post: 11-18-2015, 06:33 PM
    2. Replies: 8
      Last Post: 02-07-2014, 05:23 PM
    3. Replies: 1
      Last Post: 04-23-2010, 09:48 AM
    4. ORANGE >>>>>>>>>>>>>>>>>
      By Chilled Man in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-04-2009, 02:45 PM
