Valve cover replacement
    Results 1 to 7 of 7
      May 2019
      Well guys it finally happened need to replace valve gaskets planning to diy it. Question is has anyone else done this job? 2005 v8xc90. Need all help can get. If anyone has instructions please sent them to me. Have never did any work on this one first. Have a few other thing need to be done but will start on this first.thanks everyone.
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2006 & 2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
      Oct 2016
      Bellevue, WA USA
      Good video, not a lot of fun. 12 hour job
      SwedeSpeed.com
      Apr 2015
      Pittsburgh, PA
      Quote Originally Posted by Thommykent View Post
      I added that to the sticky. Thanks!
      2006 & 2007 XC70
      Previous: 2006 S60R
    7. #5
      Oct 2016
      Bellevue, WA USA
      Quote Originally Posted by hames icu View Post
      well guys it finally happened need to replace valve gaskets planning to diy it. Question is has anyone else done this job? 2005 v8xc90. Need all help can get. If anyone has instructions please sent them to me. Have never did any work on this one first. Have a few other thing need to be done but will start on this first.thanks everyone.
      you`re welcome
    8. #6
      Mar 2014
      Should this have the drain hole drilled for the counter balance shaft as part of this job? Replacement of the shaft bearing there?
      2004 XC90 2.5T FWD + 2006 XC90 2.5T
    9. #7
      Oct 2016
      Bellevue, WA USA
      That`s a way more involved process and most have been done or destroyed themselves by now. Apparently all V8`s will need this someday, although my 07 S80 with 77k miles is still dry. A couple years ago I gave each valve cover nut ¼ turn, maybe that helped.
    10. Remove Advertisements
    Similar Threads
    1. Replies: 4
      Last Post: 02-10-2016, 08:58 PM
    2. Valve Cover Gasket Replacement Questions
      By BrotherMatt in forum R Forum (2004-2007)
      Last Post: 03-03-2015, 08:04 PM
    3. 2004 V70 Shift flare--B4 valve cover replacement experience
      By plheureux in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 11-08-2014, 04:53 PM
    4. Valve cover gasket replacement - no leaks!
      By Ross Johansson in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 09-12-2011, 09:25 PM
    5. Plastic valve cover replacement?
      By jamesd in forum S60 (2001-2010)
      Last Post: 07-05-2010, 06:04 PM
