Exhaust diameter question
    Results 1 to 1 of 1
      Sep 2019
      My car is a T5, with Polestar tune, and a BMC air fliter. I'm adding a high flow muffler, and wondering if I should be using a 2.5 inch muffler, or a 3.0 inch muffler. I'll be retaining the factory resonator, and factory mid-pipe, only replacing the muffler/tips.
      I already bought a 2.5" inch (63.5mm) vibrant muffler, thinking that for a 2.0L turbo with about 260hp/300torque, 2.5 inch should be sufficient. But I just found out the factory piping is actually 65.5mm (2.578"). This means a roughly 2mm reduction in pipe diameter, going from factory mid-pipes, into the aftermarket high-flow muffler.
      Would that be ok? or should I actually be using the 3.0" version of the Vibrant muffler? My concern is if that 2mm reduction in pipe diameter going into the muffler could create untended restriction/back-pressure.
      Thanks for any info.
    Similar Threads
    1. Replies: 10
      Last Post: 08-09-2006, 10:21 AM
    2. Question reguarding exhaust diameter
      By Ride R in forum R Forum (2004-2007)
      Last Post: 07-13-2006, 05:08 PM
    3. Replies: 3
      Last Post: 03-28-2006, 10:35 AM
    4. How does ECU learn a new downpipe diameter and larger exhaust
      By Helmut Ranff in forum General FWD & AWD
      Last Post: 02-02-2006, 08:54 AM
    5. exhaust pipe diameter?
      By nyc850 in forum 850 (1993-1997)
      Last Post: 08-25-2004, 07:06 PM
