Rallying a 240
    Results 1 to 3 of 3
    Thread: Rallying a 240
      Jun 2020
      Rallying a 240
      Hi all, I know this has probably been asked before, but all the threads I found seemed to be old. So...what needs to be done to a 240 to turn it into a decent rally car?
      Junior Member smoothdurban's Avatar
      Apr 2011
      LaSalle Ont.
      You may get better response over at turbobricks. But I would search first. Best of Luck!
      1983 Volvo 242 Turbo - Daily Driver 142,000 kms and counting
      1991 Volvo 245 - Ski Wagon 445,000 kms and counting
      2005 Volvo s40i - Spring / Fall Daily Driver 142,000 kms and counting
      Junior Member scaramoucheii's Avatar
      Feb 2016
      Florida, USA
      Quote Originally Posted by cocranfill View Post
      What type of Rally? Where?
      Depending on the rally and class your entering there may not be much more that you can do to the car performance wise. Other than a few minor tweaks.
      And there WILL be some safety things that ARE required. Check with the Club organizing and the rules for your class
      Really all you need to do is
      •Sump Guard
      •LSD Rear end
      •Roll cage,
      •Timing and Navigation instruments
      •Fire Extinguisher
      •Mud Flaps (so faster cars can pass you in the rain easier, Some clubs require them)
      THEN, with out altering the "performance" outside of the rules,
      • installing a free flowing exhaust
      • stiffer springs (rate depending on type of rally/road surface)
      •Koni or Bilstien shocks.
      •Remove any weight you don't need (Interior)
      •Move anything heavy (Battery, Tools, Spares) towards the middle of the car and low down.(With no interior back seat area is good for this)
      That with the LSD and you can drive fast enough to then only have your courage and skill the limitations
      Currently: 2016 XC90 T8, 1973 1800ES Original D-Jet, 1973 142 B20B, 1977 242 B230FT
      Previously: 1974 144 B20B, 1974 142 B20F, 1989 740, 1981 242 GLT, 1996 740, 1999 V70
    Similar Threads
    1. Wanted: 240 *** 240 *** 240 *** 240 *** 240 *** 240
      By lovemyvolvo in forum Want Ads
      Last Post: 02-19-2014, 09:08 PM
    2. rallying uk
      By big s in forum Europe
      Last Post: 08-21-2007, 08:51 AM
    3. Technical info needed to modify my 740 for rallying
      By boumboum in forum 740 & 760 (1982-1992)
      Last Post: 08-18-2004, 06:59 PM
    4. Rallying
      By Renix in forum General RWD
      Last Post: 10-06-2003, 08:06 AM
