Wheel time! FC04A 18x8 or 18x9?
    Results 1 to 11 of 11
      Sep 2015
      Southern PA
      This has been bandied about, but with no definitive answer I could find.
      EST guys rec'd these wheels if going 17": https://www.eurosporttuning.com/fc04...per-wheel.html
      buuut now I think I'm going with 18's for summer and I'll keep the stock 17" pegs for winters.
      There are three different 18" FC04a wheels available, here:
      Specs for all:
      17x8: 17x8 +35 offset
      Wheel Size Offset
      Stock 17" Pegs 17x8 +46mm
      FC04A 17x8 +35mm
      Stock 18" Pegs 18x8 +46mm
      FC04A 18x8 +30mm
      FC04A 18x8 +40mm
      FC04A 18x9 +30mm
      So question time: +40 vs +30 offset for the FC04A's, 18x8 vs 18x9, which is closer to stock 18" wheels? Would the 18x9s even fit? Has anyone run any of 'em?
      This is the look I'm going for:
      I'm leaning toward the 18x8 +30 FC04A's with 235/40/18 Zlines to avoid rub/keep an accurate speedo bc that's (I think) closest to stockish. Thoughts?
      Me: 2007 VR gt Slicktop Titanium Grey/Nordkap Wife: 2015 XC60 T6 AWD Ocean Race
      Past: 2006 V70 2.5T Willow Green/Oak, 2005 S60 2.5T Silver/Black, 1991 745 White auto, 1982 244 Silver 4spd w/od
      Nov 2019
      Texas
      I have the 19x8.5, I'll have to check the offset but in terms of speed accuracy my speedo has matched the road radars almost perfectly. I would still like the space the rears a little if I felt like dealing with the rolling of fenders
      Sent from my SM-G965U using Tapatalk
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      This is the best write-up I知 aware of on the topic. Greg is a cool guy and I知 sure he値l be happy to answer questions.
      https://forums.swedespeed.com/showthread.php?t=243201
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
      SwedeSpeed.com
      Aug 2010
      Central NJ
      I've been very happy running the FC04A's in 17"x8.0 +35 on my T5. R Brembo swapped so everything fits nicely. I'm in the Central NJ/NYC area, so not far from you, and the roads are just terrible so having more meat on the tires was a must for me. Running 235/45R17 Continental DW tires. I do understand the want to go with 18" wheels though.
      For some measurement numbers:
      For my setup with the 17x8 +35, I think a 5mm spacer would be conservatively flush fit to the P2 body. I have only the slightest rubbing at full lock, but comparing to an 18" wheel+tire combo will be different.
      If you're looking for a good overall fitment with the OE fenders, then 18x8 +30 may be a good choice.
      If you're looking to push the limits of flush fitment or even a tucked look, then 18x8 +40 may be a better choice so you can try different spacers (~10mm to 20mm) to get the desired look. I'm not sure that the 18x8 +40 wheel will fit without spacers though as my 17x8 +35 wheels just barely clear the calipers.
      2005 S60 T5 M66 (1 of 72). 4C, Sport Kit, Snabb Short Shifter+Bushings, IPD Track Sways, Bi-Xenon Retrofitted R headlights, IPD DP + Oval Tube Exhaust, Forge CBV, Snabb intake pipe, R Brembos F+R, FC04A 17x8+35...
      2005 G55k Family hauler
      2007 Formula SAE Racecar (Auto-X Restoration)
      NA1 Supercharged NSX someday.
    7. #5
      Sep 2015
      Southern PA
      Quote Originally Posted by Austin V70R View Post
      Sweet writeup, thanks!
      Sent from my Pixel 4 using Tapatalk
    8. #6
      Sep 2015
      Southern PA
      Quote Originally Posted by broinkrist View Post
      Those 17s honestly look great, that was my plan up until recently....would be cheaper and lighter weight too
    9. #7
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      18x8 with 40mm, no rub and they look great.
    10. #8
      Sep 2015
      Southern PA
      Quote Originally Posted by Rodtheviking View Post
      That's what you're running? Piiics
    11. #9
      Aug 2010
      Central NJ
      Quote Originally Posted by tabormeister View Post
      Tires are also quite a bit cheaper by ~$100/set, but I completely understand the want to go with 18's, especially if you're going to be spending $ on these anyway. If I keep my car long enough for another set of summer tires, I will probably go with the 18" route for the summer set, and keep the FC04A's in 17 for the winter set.
    12. #10
      Sep 2015
      Southern PA
      My only concern is the ride quality since the roads aren't actually that great around me.... But I mean, they're not terrible either
    13. #11
      Jun 2019
      Vancouver, WA
      PM'd you. I cant upload pictures on here, my account is screwed.
    14. Remove Advertisements
    Similar Threads
    1. 18x9 ET40 fronts?
      By mk2glenn in forum S40 & V50 (2005-2012)
      Last Post: 01-07-2015, 09:23 AM
    2. Ronal LZ 18x8 and 18x9.5 two piece wheels
      By thunderbirdsc in forum Wheels & Tires Classifieds
      Last Post: 11-26-2013, 10:53 PM
    3. FS: Gun Metal w/ Polished Lip BBS LM Reps - 18x8.5 18x9.5 - NEW IN BOX
      By xUNiQuE in forum Wheels & Tires Classifieds
      Last Post: 10-03-2013, 03:09 PM
    4. 18" BBS LM 18x8 18x9 5x108
      By tofunin in forum Wheels & Tires Classifieds
      Last Post: 02-26-2013, 01:57 AM
    5. $600 4 18x9 high gloss black privat sekts and Eagle gt tires 245/40
      By ZekeUSMC in forum Wheels & Tires Classifieds
      Last Post: 01-27-2012, 01:58 AM
