2017 roof rails that much different than the 2018?
    Results 1 to 9 of 9
      May 2020
      I'm on my thirds set of cross bars (load bars) that do not fit. Turns out the most recent one's were for a 2018 XC90 and i have a 2017. The fit was just short by a few millimeters on the front cross bar. The back fit fine which tells me the rails on the 2017 XC90 narrow inwards from front to back (which I recall reading somewhere). Can anyone save my sanity and recommend a set of cross bars for the 2017 flush rails on an inscription model that are THIS style?
      Edit: Meant to add, at a reasonable price (under $300). Not something like Thule where it's $450 per piece and requires 15 pieces.
      May 2020
      Can you give us an idea of which 3 sets of crossbars you tried already?
      I'm assuming the one you linked is adjustable in terms of sliding the bottom foot packs along the bars wider or narrower depending on where you mount it on the rails.
      For those style bars, there really is only 1 length of bar that will go with the car. In Thule's case, it's 53" and that won't change whether it's 2017 or 2018.
      May 2020
      The one i linked is adjustable but the rails on my 2017 seem to be an inch or two, too wide for everything to work. This is what's confusing to me. Are the 2018 rails actually 2-3 inches closer together than the 2017? You commented that the 53" would work for 2017 and 2018 but does that mean if the bars I got were for a 2018 (48" each), they should work for the 2017? The other versions were on me for ordering the wrong ones (not for flush rails).
      I was considering trying to make these work but would rather not have to rig something up
      SwedeSpeed.com
      May 2020
      Update: Brightlines customer service reached out first thing this morning. We chatted about the issue and they've expedited a pair of 53" cross bars to me in exchange for the 48". These should do the trick! Thank you for your help Jaaa regarding the size needed.
    7. #5
      May 2020
      No problem and glad you got it sorted. Eyeballing my own 53" setup, the 48" is too short.
    8. #6
      Feb 2016
      Denver/Frankfurt
      The official Volvo load carrier bars are under $300 and made by Thule, why not just buy them?
      19 Mini Cooper S Countryman ALL4 6MT
      18 BMW X3 M40i
      17 Volvo XC90 T6 Inscription P*
    9. #7
      May 2020
      I'm not a fan of the way the Volvo ones look.
    10. #8
      Feb 2016
      Denver/Frankfurt
      You should only have them on when you're actively using them with a roof box or bikes or whatever, it's not like you're using them as a fashion statement. At least not with "BRIGHTLINES" emblazoned across them.
      18 BMW X3 M40i
    11. #9
      Jul 2019
      Ontario, Canada
      Been using the Volvo cross bars with a Thule Motion XL box and have had no issues. I'll leave the crossbars on if I know I'm going to be using it in a week or two and while it does increase wind noise a little bit, it's not that bad.
    12. Remove Advertisements
    Similar Threads
    1. Roof Rails or No Roof Rails on a P80 Wagon? Letís see your pictures.
      By Saffron-R in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-20-2017, 03:45 PM
    2. Drive modes different for 2016, 2017 and 2018
      By marcmct in forum XC90 (SPA: 2016 - )
      Last Post: 09-02-2017, 08:52 PM
    3. 855/V70 Roof Rails/ Euro Rails and Roof Strips, Hardware etc. ONLY $50
      By gms850r in forum FWD & AWD Parts For Sale
      Last Post: 01-17-2012, 09:13 AM
    4. Replies: 2
      Last Post: 11-26-2009, 03:59 PM
    5. Wanted-1999 volvo V70 Roof Rails/euro rails!
      By missyjosh in forum Want Ads
      Last Post: 08-04-2006, 06:06 PM
