2004 S60 blower problems
    Results 1 to 5 of 5
      Jun 2020
      My dad gave me his old 2004 S60 2.5T as my first car recently, but we've been having problems with the climate control blower. After the car was turned off the blower would keep running until the battery died, so the fuse had to be pulled to make it stop. It sat for a while not running until we began to get it back into working shape. We were trying to diagnose the issue and discovered the fuse had been melted. It hadn't blown, the whole fuse, metal and all, melted into the interior fuse box. We got all of the melted fuse bits out and the fuse box seems unharmed. Now we need to know how to fix it. Thanks
      Nov 2011
      More than likely its its the blower motor resistor. Also called a Power unit. part #8693262
      Aug 2010
      Central NJ
      Yup. ^ It can either be the blower motor resistor or the blower motor itself, or both. I had to replace 2 blower motor resistors before I just replaced the blower motor. I purchased the parts from FCPEuro so they covered the resistor failure 2x.
      2005 S60 T5 M66 (1 of 72). 4C (for now), Sport Kit, Snabb Short Shifter+Bushings, IPD Track Sways F+R, Bi-Xenon Retrofitted R Headlights - custom fuse box/wiring harness, IPD DP + Oval Tube Exhaust, Forge CBV, Snabb intake pipe, R Brembos F+R, FC04A 17x8+35. coming soon: KW V2, Delrin Subframe Bushings, Do88 Intercooler, Stage 2 Tune. HU-650+Bluetooth Grom+PA300+2xFocal ISS165+ACM-1.300+2x6.5" Dayton Rear Door Subwoofers.
      2005 G55k Family hauler
      2007 Formula SAE Racecar - Custom Tube Frame Chassis, Fox Shocks, Pullrod Suspension, , Wilwood Calipers, Hoosier Slicks, Magnesium 2pc wheels... (full auto-x resto)
      NA1 Supercharged NSX someday.
      SwedeSpeed.com
      Apr 2019
      Make sure that the correct fuse is installed while you are troubleshooting other stuff.
    7. #5
      Junior Member JonE1976's Avatar
      Oct 2016
      Garner, NC
      Good news is that both are easy to get to and there are some good youtube videos out there. You found a good first DIY job and congrats on your new to you wheels. I would swap both the blower and resistor. When I did mine I was shocked at how much more air the new blower moved compared to my old one. I wish I had replaced them years ago.
      2005 S60 2.5T AWD
      2014 XC60 T6 AWD
      Didn't learn from the 2005s repair bills and brought home a second. I'm a glutton for punishment I guess
    8. Remove Advertisements
    Similar Threads
    1. A/C Blower problems
      By mnvizb in forum C30 (2007-2013)
      Last Post: 02-14-2017, 07:39 AM
    2. A/C Blower problems
      By mnvizb in forum S40 & V50 (2005-2012)
      Last Post: 02-01-2017, 03:59 PM
    3. Blower or Blower resistor? (ECC fun)
      By burnout8488 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 01-22-2013, 10:53 PM
    4. FS: Blower Motor out of 2004 R
      By sonerick in forum FWD & AWD Parts For Sale
      Last Post: 02-24-2011, 03:37 PM
    5. 2004 V70 Motor Blower Won't Shut Off
      By mmr34747 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 03-02-2009, 05:41 PM
