Battery post deforming?
    Results 1 to 5 of 5
      Aug 2017
      I have a 2017 S60 and my battery posts are not deformed. Maybe this is more of a car battery question. My wife has a 2016 Acura RDX and the negative battery post looks like someone hit the post with a hammer making the post look somewhat like a mushroom. Calling the Acura dealer they said, that this can be normal due to the soft lead metal post. Is that true? I have never had this experience before. The problem with this situation is that I can't take off the negative terminal.
      2017 S60i T5
      Member
      Jun 2012
      Pittsburgh, PA
      I never had this issue with any of my cars including this Volvo S60.
      This is strange.
      Sent from my ASUS_Z017DA using Tapatalk
      2012 S60 T5 Savile Gray/Beachwood
      Nov 2015
      Victoria, BC Canada
      If the "mushrooming" is all above the clamp could you cut off the top edge of the post with a hacksaw? Have your shop vac nozzle sucking beside where you're cutting so the lead shavings don't fall everywhere. If it's a common Acura problem you might find a better solution on an Acura site.
      2015 V60 T6 AWD Sport Suspension, ipd rear sway bar, 19 inch Bor wheels, Polestar Optimization, Premium Plus, Silver
      Previous: 2003 Passat 1.8T wagon, 1989 MX-6 GT 4WS, 1979 GS-1000E
      SwedeSpeed.com
      Junior Member meade18's Avatar
      Mar 2018
      pic?
      2015.5 Volvo V60 Premier T5 (2.0T Drive-E) FWD (with a new engine)
    7. #5
      Aug 2017
      There is not enough of it to cut. But there is enough to cause a problem in removing the battery. Calling Acura they said, it has happened before. Based on owning other batteries and cars I have never had this experience before.
      2017 S60i T5
    8. Remove Advertisements
    Similar Threads
    1. Replies: 18
      Last Post: 01-04-2018, 07:48 PM
    2. '97 960 drains battery - alternator test is fine and new battery?
      By gar598 in forum 940, 960, S90 & V90 (1990-1998)
      Last Post: 04-27-2010, 09:58 PM
    3. Corrosion on battery and battery cable
      By graphicd in forum S40 & V50 (2005-2012)
      Last Post: 04-13-2010, 03:44 PM
    4. S40 Battery question - lightweight battery?
      By jhw in forum S40 & V50 (2005-2012)
      Last Post: 08-26-2008, 02:08 PM
    5. Replies: 4
      Last Post: 12-20-2005, 01:23 PM
