ESSR Message won't go away...
    Results 1 to 6 of 6
      Jun 2020
      Florida
      Engine Service System Required message will not go away. I tried the reset procedure multiple times (key position 1, hold trip button, position two, blink then release, hear tone).
      Why might this be?
      Member
      Aug 2017
      United States
      First, that isn't the reset procedure. That's for the service light. You have a fault that needs to be diagnosed and repaired. You need the codes read to have a clue where to start.
      Jun 2020
      Florida
      Gochya, thank you for clarifying.
      What does the service light look like? (The one that can be reset with the mentioned in the original post.)
      SwedeSpeed.com
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      There is the ! light in the center of the dash, most important. It can change (red, yellow and can flash) according to the severity of the problem, will also give a message in the info display.
      "Check Engine" is what you have? Most likely an emissions fault that needs a code reader to check it. Last one I had was faulty throttle, I have a cheapy code reader from Harbor.
      http://new.volvocars.com/ownersdocs/.../04s60_02a.htm
    7. #5
      Jun 2020
      Florida
      Orange ! light is on, and the message reads "Engine System Service Required".
    8. #6
      Member esmith813's Avatar
      May 2012
      Poconos, PA
      Quote Originally Posted by RKing93 View Post
      This message can be accompanied by a CEL (Check Engine Light) or come up by itself. I got it once when my MAF was acting up and never got a CEL, but as stated, it could be a bunch of different things. You'll need to codes pulled from here.
      The service light is exactly the same (Orange ! light, plus a message that I forget exactly what it says "Time for regular maintenance" or something similar), and is reset with the procedure you've done.
      2006 S60R MT Sonic Blue with Atacama - Garage Queen
      2008 XC90 V8 Sport Passion Red with Off Black - Hers
      2015 VW Golf Sportwagen TDI MT, 2001 Jeep Wrangler 4.0L MT 60th Anniversary Edition
      Previously: 2010 S80 V8, 2006 V70R MT, 2004 S60R MT, 1993 245 NA, 2006 XC90 V8, 2002 Dakota V8 MT
    9. Remove Advertisements
    Similar Threads
    1. Replies: 22
      Last Post: 09-13-2010, 03:10 PM
    2. Engine rebuild project 56k don't go away mad, just go away!
      By gdogg16 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 05-23-2007, 11:20 AM
    3. On Call Plus deactivated message - make it go away!
      By tray in forum R Forum (2004-2007)
      Last Post: 08-12-2006, 09:57 PM
    4. "Check Engine" Message Won't Go Away
      By rtrusty in forum R Forum (2004-2007)
      Last Post: 08-11-2005, 12:08 PM
    5. Will the service message go away?
      By aenea in forum S40 & V50 (2005-2012)
      Last Post: 08-07-2005, 09:56 PM
