F?$k地 kids....
    Results 1 to 24 of 24
      Junior Member Volvos rock's Avatar
      Feb 2011
      Danielsville PA
      F?$k地 kids....
      Lol, too fast through an intersection, smash...
      She値l learn how much that costs, she is very apologetic. Luckily shut it down within half a block, all the oil was where she stopped so hopefully just the pan.
      Those of you who installed an IPD skid plate, looks to bolt to the back, how does the front attach?
      1996 850 GLT sdn (deceased @ 250k), 2002 V70 XC 120k (traded), 2009 S80 3.2 52k
      2010 VW Croutan 3.8 SE 29k
      1998 Chevrolet K1500 85k(only cause Volvo doesn't make pick ups)
      1965 Pontiac Lemans convertable (the sled)
      2013 Ford Police Interceptor Utility (not that horrible)
      Member inteller's Avatar
      Aug 2009
      Tulsa, OK
      Still probably ran bearing dry. P1s are not forgiving to getting a pan busted.
      Sent from my SM-G973U1 using Tapatalk
      2016 Bright Silver Metallic XC90 T8 Inscription, everything
      2015.5 Rebel Blue S60 Polestar 18/40
      2006 Passion Red S60R
      Packages: Premium, Climate Options: Sport Appearance Package, 18" Pegs, 6Spd Geartronic, Navigation
      Accessories: Sunglasses holder, Sirius Radio, Volvo Digital Jukebox Mods:SS DEM Mod
      "Just say no to LV VIN codes"
      Feb 2011
      Danielsville PA
      Quote Originally Posted by inteller View Post
      Hey, positive thoughts man....lol.
      From reading the related threads, it appears to be opposite that thought. We will see.
      Whatever the case, it値l get fixed. The car is basically at stage 0 now, a lot into it to walk away, @100k miles.
      SwedeSpeed.com
    7. #5
      Feb 2011
      Danielsville PA
      Quote Originally Posted by MyNameIdeasWereTaken View Post
      Skid plates attach to the studs on the radiator support.
      Thank you sir!
    8. #6
      Junior Member LittleRedRidingHood's Avatar
      Nov 2016
      Kingston, Ontario
      There is essentially no oil in the pan to drain out when the car is running.
      It's when you shut it off to take a look that all the oil will fall back into the pan and drain out the crack - at that point restarting the engine would be a bad idea.
      2007 Volvo V50 T5 AWD M66 - Passion Red
      2006 Volvo S40 T5 AWD M66 - Titanium Grey
      Hilton Tuning Stage 2 ~ Mototec 3" Downpipe & Sport Exhaust ~ Do88 Intercooler ~ Snabb Intake Pipe
      RIP - 2007 Volvo S40 T5 AWD Geartronic - Passion Red
    9. #7
      Mar 2018
      Quote Originally Posted by LittleRedRidingHood View Post
      If this is correct, wouldn't engines be constantly sucking up air into the oil, especially if they are running a bit low?
    10. #8
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Just bought a VW Tiguan for my wife. The oil pan is plastic. Plastic may actually be a little more forgiving than cast alloy as it will flex more. However, I wonder about stress cracks from thermal cycling. Euro Sport Tuning has stamped steel replacements.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    11. #9
      Mar 2018
      Have you seen that cash for clunkers video where they try to kill an S80 and it takes like five minutes? I think these engines are pretty tough...
    12. #10
      Jan 2009
      Did the oil light come on while the engine was running? If the engine was shut down before the oil light came on you are for sure good. If the engine was shut down after the oil light came on, the engine has a higher probability of being damaged the longer the engine runs. Glck.
    13. #11
      Member
      Aug 2017
      United States
      If it was shut off in a half block, it will more than likely be fine. I've seen dozens of those pans get smashed. Only a couple seized the motor when the drivers ignored the low oil pressure warning.
      As for there being no oil in the pan when running, that is not correct.
    14. #12
      Feb 2011
      Danielsville PA
      Quote Originally Posted by Tech View Post
      Thanks Tech, that痴 what we are hoping. Time v. Money, it went to the dealer, so we will know tomorrow
    15. #13
      Junior Member TheStillMan's Avatar
      Jun 2017
      Ohio
      What kind of intersection did that??
      2010 XC60 T6 Sapphire Black Metallic (TFT DIM retrofit, DynoMax muffler, Eibach lowering springs & Koni struts, HardRace adjustable rear toe arms)
      2004 Subaru Legacy Outback wagon 2.5 White Frost Pearl (Also mine) | 2011 Chevy Equinox LT1 AWD Olympic White (Hers)
    16. #14
      Nov 2016
      Kingston, Ontario
      Sorry for the misinformation.
      In my experience (cracked front drivers corner of the pan), it only leaked oil when shut off. I drove it home about 10 minutes (never lost oil pressure), and got a tub underneath it before shutting the car off. Drained the oil, repaired the pan, and refilled the engine with the oil I had drained out. It lost so little I didn't even need to add any new oil.
      I've read of others having the same experience. Perhaps related to it only being a crack at the front of the pan, and the engine tilting towards the rear of the car. OP's crack looked to be more of a hole, so that logic may not apply.
      Anyways, sorry about that!
    17. #15
      Feb 2011
      Danielsville PA
      F?$k地 kids....
      Quote Originally Posted by TheStillMan View Post
      Regular kind, too much speed hitting the hump (crown of the cross street) and the corresponding dip/rise on the rebound.
      I could actually locate the impact point, on the roadway.
    18. #16
      Feb 2011
      Danielsville PA
      Same scenario, except she stopped/shut it down within half a block, then the oil pooled.
      And yup about a quarter size hole.
    19. #17
      Feb 2011
      Danielsville PA
      All fixed, no internal damage, thankfully
    20. #18
      Aug 2019
      Ottawa, Ontario
      Great to hear, the car looks very nice. Happy to hear it survived!
      2010 V50 T5 AWD M66
    21. #19
      Feb 2011
      Danielsville PA
      Last piece of the fix!
    22. #20
      Aug 2019
      Ottawa, Ontario
      I sort of wish I had bought that instead of the OEM plastic one. When I bought my car it was missing it.
      I am curious about how much of a pain it is to install/remove vs the plastic ones. If it isn't too bad I may look into one eventually, also the DO88 air intake so I don't have to keep moving the air box/ecu.
      2010 V50 T5 AWD M66
    23. #21
      Jan 2009
      Quote Originally Posted by Volvos rock View Post
      Great to hear! Welcome back to the world running Volvos.
    24. #22
      Feb 2011
      Danielsville PA
      Quote Originally Posted by sirloins View Post
      Put it on, I wouldn稚 want to take it on and off regularly, but the annoying part could be fixed with some different hardware.
    25. #23
      Aug 2019
      Ottawa, Ontario
      Thanks for the update!
      Yeah, I guess I am overestimating how many times I will need to remove it.. realistically it shouldn't be too often.
      2010 V50 T5 AWD M66
    26. #24
      Feb 2018
      PNW
      Install some nutserts for the front hardware and it will be easy to remove as necessary.
    27. Remove Advertisements
    Similar Threads
    1. The Kids OBX DP install
      By VolvokidS60R in forum R Forum (2004-2007)
      Last Post: 10-20-2012, 06:35 AM
    2. How to fix your xbox 360 forever... or your lazy kids.
      By kmagnuss in forum Off Topic Forum
      Last Post: 04-29-2010, 08:08 PM
    3. Kids are awesome!
      By mecky33 in forum R Forum (2004-2007)
      Last Post: 04-26-2010, 10:25 AM
    4. Kids and V70R
      By mattquinley in forum R Forum (2004-2007)
      Last Post: 07-31-2003, 02:58 PM
    5. Got a wagon coming, stuff for the kids
      By vintagemilano in forum R Forum (2004-2007)
      Last Post: 07-09-2003, 05:59 AM
