Possible 4C solution?
    Results 1 to 6 of 6
      Junior Member R_for_Life's Avatar
      Jun 2012
      Raleigh NC
      Hey guys, its been a few years since I've been back onto this forum. I recently got a great deal of a pretty beat up R that I'm using as my Daily. Once I get some pictures uploaded I will do a welcome thread talking about the car and what Volvo's I've head in the time I was gone. After drinking a few too many last night I decided to buy a paid of Monroe front struts to replace my busted 4C's. The pair cost $60 new as they were on wholesale at rockauto. My question here is - Would it be possible for me to take my front 4C's and mount them in the trunk and just wire them through the firewall into the trunk. Leaving them connected in the trunk so it fools the car. It would require adding a lot of wire. However in theory would this work? I know this forum is filled with great minds so i'm curious to know what you guys will think.
      Junior Member Rodtheviking's Avatar
      Jun 2019
      Vancouver, WA
      If they are shot just cut out the old sensors.
      https://forums.swedespeed.com/showthread.php?208080
      Junior Member 4EVA's Avatar
      Jul 2010
      I'm confused. You bought new shocks and want to wire them into the system in the hood by placing them in the trunk but not installed to the car and leave the old junky ones installed?
      The reason your old 4c's are junky is because the oil in them have probably all leaked out, not an electronic issue.
      Sorry, I've read your post multiple times and still don't really understand what you are saying
      2007 S60R Sonic Blue/Nordkap GT, ~50k miles
      1995 Volvo 850 Turbo Polar White, ~200k miles (previous car)
      SwedeSpeed.com
      Member Body Massage's Avatar
      Aug 2008
      Bellingham, MA
      Quote Originally Posted by 4EVA View Post
      I believe his intention is to move the shot 4Cs into the trunk, and use new, non-4C struts.
      2005 V70R
      2010 C30 R-Design
    7. #5
      May 2020
      I believe you can just add a resistor to the connectors and that way you don't need to keep the old 4C Strut / Cut up sensor with you at all.
      I'm pretty sure there was a DIY post with details of all the resistors and things needed.
    8. #6
      Jun 2012
      Raleigh NC
      Quote Originally Posted by Body Massage View Post
      This is correct. I would prefer to not do the resistor modification due to the heat they will produce however i'm sure I could encapsulate the heat if I did decide to go that route. I like Dougy's solution to it. This was just a simple idea where you place the old struts in the trunk and wire them up so the are still connected. Obviously then using new non 4C struts in the front.
    9. Remove Advertisements
    Similar Threads
    1. Possible 4c solution
      By KhaosTactic in forum R Forum (2004-2007)
      Last Post: 11-19-2014, 06:52 PM
    2. Possible solution to OEM Brake Dust.
      By Vash13 in forum S40 & V50 (2005-2012)
      Last Post: 03-18-2010, 04:54 PM
    3. Replies: 23
      Last Post: 03-04-2009, 06:22 PM
    4. Possible Cause/Solution to 4C
      By raycrx in forum R Forum (2004-2007)
      Last Post: 07-01-2004, 10:25 AM
    5. Possible Solution to Full Size Spare
      By XC90Cruiser in forum XC90 (2003 - 2014)
      Last Post: 08-13-2003, 02:49 PM
