Rear axle/diff oil change
    Results 1 to 11 of 11
      Jan 2019
      London, UK
      Going to be changing the oil in the rear axle/diff of a 2013 XC90 D5.
      This video seems to explain how to do it pretty well:
      https://www.youtube.com/watch?v=aR0tAGcCUXs
      But I am pretty sure I need to remove a certain amount of oil once I've filled it so it comes out of the drain hole, but I cannot find this procedure in VIDA.
      PS I will be doing a mini flush by putting new oil in the diff, swirling it around so it mixes with any old oil I couldn't remove and then repeating this process until the oil comes out clean.
      Does anyone know how much needs to be extracted once it's filled up?
      Mar 2018
      Baltimore Maryland and Boone NC
      Quote Originally Posted by Blue_Dog View Post
      Double check but I thought was extract 100ml for rear and 50ml for front?
      2010 xc90 3.2 | 2008 xc 70 3.2
      2010 XC90 3.2 AWD / 2008 xc70 3.2
      Somewhere in space and time
      Junior Member generic_volvo_driver's Avatar
      Nov 2017
      British Columbia
      I just bought a case of Amsoil Severe Gear 75W-90. Going to do the whole fleet's angle gears and rear diffs.
      Also going to do the 300's diff, a family member's AWD Rogue and SH-AWD RDX. The SH-AWD unit in the RDX what's basically ATF in its rear diff interestingly!
      Me:
      2013 Volvo XC90 AWD Platinum (Caspian Blue Metallic, climate package, walnut inlays + wheel, BLIS, active bi-xenon headlights) 150k km
      2012 Volvo XC60 T6 AWD Platinum (Technology package, climate package) 30k km
      1988 Nissan 300ZX Turbo (2+2, T-top, Aztec Red, collector plates) 80k km
      Family members:
      2015 Volvo XC60 T6 AWD Platinum (Technology package) 96k km
      SwedeSpeed.com
      Nov 2017
      British Columbia
      volvosweden has a good series on all the fluid changes:
      There might be an updated TJ with the fluid amounts to remove IIRC.
      Me:
      Family members:
    7. #5
      Nov 2017
      British Columbia
      Another thing I remembered:
      I also found these work great: https://www.ebay.ca/itm/50pcs-18-x-2...72.m2749.l2649
      I didnt get a good seal on my XC90 with just a new OEM washer. I added some cheap thickness Teflon tape (not the good stuff) and the plug sealed properly.
      Me:
      Family members:
    8. #6
      Jan 2019
      London, UK
      Thanks for the info guys.
      @dyun1dyun1 Where can I double check the fluid amount, I couldn't find any info in VIDA ( it may be there but I cannot find it! ) ?
      Quote Originally Posted by generic_volvo_driver View Post
      I saw his video and it's great, but it doesn't show how much fluid to remove after filling.
      Sorry for the silly question but what does TJ mean?
      @generic_volvo_driver
      Thanks for the link, I found some of the same type here in the UK on eBay.
      Also when you say you didn't get a good seal, did you notice it leaking after driving for a while?
    9. #7
      May 2018
      I simply brimmed both the rear diff and transfer case with Genuine Volvo fluid. Genuine fluid is now a synthetic gear lube and prices out roughly the same as anything else.
      Only for the Haldex did I bother to suck anything out.
      -Ryan
      Current fleet:
      1987 Volvo 245
      1989 Volvo 245
      1991 Volvo 745 Dog Waggin' 2.0
      1995 Volvo 945 Turbo
      2011 Volvo XC90 3.2 AWD
      2013 Volvo XC60 3.2 AWD (Wife-mobile)
    10. #8
      Jan 2019
      London, UK
      Thanks.
      I finally found the answer in this video:
      https://youtu.be/2YFDpDk7gAw?t=344
      Front axle needs 100ml of fluid remove and rear axle 50ml
    11. #9
      Nov 2017
      British Columbia
      Yes, a little bit of seepage. The Teflon and another new washer did the trick.
      TJ = Technical Journal. Here's an old TJ that includes updated details on the differential fluid types for example: https://testing-public.carmd.com/Tsb...773-2014-03-20
      Thanks.
      Yes - this is the video I was referring to!
      Me:
      Family members:
    12. #10
      Jan 2019
      London, UK
      Thanks for the info, I had never heard of a TJ, lots of info there!
    13. #11
      Nov 2017
      Auckland, New Zealand
      do you guys do any maintenance on shaft ends at all? the bit that goes into haldex unit i think there's a bearing there as well?
      2011 XC90 B8444S R-Design 614 120k km RHD
    14. Remove Advertisements
    Similar Threads
    1. DIY rear diff axle seals and turbo seal, or not?
      By aRizona in forum R Forum (2004-2007)
      Last Post: 10-16-2018, 07:06 PM
    2. Haldex and rear diff oil change
      By Seamus in forum S80 (2007-2016)
      Last Post: 03-13-2018, 10:40 AM
    3. Angle gear and rear diff gear oil. Do you use oem or regular gear oil?
      By cs057 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-27-2014, 05:11 PM
    4. Rear diff axle seal.
      By Szia in forum R Forum (2004-2007)
      Last Post: 02-19-2010, 07:32 PM
    5. Leaking rear axle/diff?! Advice needed please...
      By S60R_Swede in forum R Forum (2004-2007)
      Last Post: 09-15-2008, 05:41 AM
