Rumble while Accelling 2007 xc90
    Results 1 to 3 of 3
      Mar 2018
      Pennsylvania
      I have a low rumble seemingly from the back of my XC90. Any idea what it might be? It seems to be present when accelerating and more noticeable while turning. Thanks!
      Junior Member need4spd's Avatar
      Nov 2004
      one of your wheel bearings? They tend to make more noise when pressure is applied such as turning or acceleration.
      Make sure it is the back ones as noise travels, had to replace our front left (replaced both front) recently around 103K miles
      May 2017
      Chicago & D.C. Metro
      need4spd made a great suggestion that it sounds like the bearing. To rule out another possibility, rotate tires in case one of them has a hidden nail or uneven wear that could also cause the noise.
      2008 XC90 3.2 AWD - 150k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Strut Recommendations based on your specific XC90
      Why it's better to use synthetic oil instead of conventional
    Similar Threads
    1. XC90 2009 V8 developed a Misfire, rumble at 1400rpm to 1600rpm
      By bluebossa in forum XC90 (2003 - 2014)
      Last Post: 11-11-2018, 02:37 PM
    2. developed a low rumble/hum from the rear
      By OilAnalyst in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-16-2010, 06:33 AM
    3. New V70 "Road Rumble"?
      By V70pilot in forum General FWD & AWD
      Last Post: 08-11-2003, 03:34 PM
    4. loud rumble when braking
      By purple850 in forum General Volvo Discussions
      Last Post: 05-01-2003, 12:32 PM
    5. 2001 V70 T5 Road Rumble ( X-Post)
      By Roger Eastman in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 03-05-2001, 02:05 PM
