rear brake drum nut torque
    Results 1 to 3 of 3
      Jun 2005
      Is there a recommended torque for the nut on the rear brake drum or is it just a matter of tighten it good and tight until you can get the cotter pin in? This is for my 67 1800.
      Thanks
      Jim S.
      Apr 2016
      Jim;
      No torque is specified, but the generally accepted process is to tighten to 80ft/lbs, then continue to next cotter pin alignment opportunity. I hope you applied the slightest film of anti-seize to the tapered axle shaft.
      See also: https://www.sw-em.com/Brake_Drum_Not...tening_Drumnut
      Cheers
      Jun 2005
      Thanks Ron, I haven't finished putting it back on yet.
      I know that using anti-seize is sometimes argued about. I think you are right, putting a little on there is a good idea. Unless you know you will not be the next one take it apart. Or if you know who will be the next to do that and you don't like them.
    Similar Threads
    1. P1800 Drum Castle nut Torque
      By Mathil in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 03-16-2012, 12:54 AM
    2. stripped lug nut - well, not the lug nut itself
      By trondp in forum S60 (2001-2010)
      Last Post: 12-19-2009, 12:37 PM
    3. 1959 volvo pv 544 rear brake drum key
      By mech-for-cars in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 04-09-2009, 10:26 AM
    4. rear brake drum torque
      Last Post: 04-09-2009, 09:41 AM
    5. Replies: 0
      Last Post: 02-22-2006, 03:41 AM
