fuel range
    Results 1 to 14 of 14
    Thread: fuel range
      Jul 2020
      Hell Paso Texas
      fuel range
      I see the V60 cc only has a 14.5 gal tank,
      what type of range are you getting per tank? Long trips, In Town Etc.
      only 2020 V60 CC please.
      Thanks
      Junior Member visualv's Avatar
      Feb 2019
      California
      San Francisco to L.A in one tank of gas, that's about 380miles
      Sent from my ONEPLUS A6013 using Tapatalk
      2019 V60, T6 R-Design Polestar Engineered, Osmium Grey
      Ragnarok
      Member Avboden's Avatar
      Apr 2010
      Michigan
      For highway the V60CC unless you drive with a lead foot or at 90mph sustained should get generally between 27 and 33mpg. So 390 to 480 miles theoretically. Add in a little mixed and should be fair to expect generally 330 to 380 miles per tank depending on your type of driving or more if pure highway.
      2019 S60 T6 Inscription
      1998 V70R. RIP Transmission
      1973 Volvo 1800ES which will someday get a T6 engine
      SwedeSpeed.com
      Jul 2020
      Hell Paso Texas
      Thanks for the reply,
      I live in Hellpaso Texas and travel to Fort Worth Tx every third weekend.. Speed limits are 75-80 So I cruise around 82-88 MPH most of the time to save on tickets
      and to drive past the 350 miles of nothing..
    7. #5
      Apr 2010
      Michigan
      Quote Originally Posted by Tundralag View Post
      Gotcha, *theoretically* you should make that on one tank but I could see those speeds with a headwind tanking mpg and cutting it close. Plan on likely filling up once on the drive to be safe.
    8. #6
      Junior Member Kamil's Avatar
      Nov 2019
      On highway at 70 mph you can get 450 miles to a tank, little more if you feel brave lol
      2020 V60 CC
    9. #7
      Jul 2020
      Hell Paso Texas
      Quote Originally Posted by Avboden View Post
      Thanks.. The whole drive is 580 or so miles.. the first 350 is nothing but brown landscape with a small town here and there..
    10. #8
      Apr 2010
      Michigan
      Ahhh gotcha, well yeah, one fill-up somewhere in the middle and you're just fine on that.
    11. #9
      Jul 2019
      USA, DE
      My data for a long trip is from Jan (pre lockdown) and it was 33mpg at 75mph on highways. I bet it is a little better now as it is “a lot warmer.”
      2020 V60 CC, Birch Light, Advanced PKG, 19" wheels, P*
      Past cars: Original Toyota 86, Subaru Legacy Wagon, Audi A4, V70, XC70, BMW M3, AMG SLK, Mini Cooper S
    12. #10
      Jul 2020
      Hell Paso Texas
      Quote Originally Posted by jaep View Post
      That's amazing.. I hope we can get somewhere close to that..
    13. #11
      Junior Member lflorack's Avatar
      Jun 2020
      Upstate, NY
      So, based on the data above and everyone's experiences, at what speed - during highway driving (i.e., steady speed) does the turbo kick in, and therefore kill your MPG. I'm used to interstate cruising at ~75 or so with my previous car and wondering if that will be fast enough to kick in the turbo.
      2020 V60 Cross Country T5 - Birch Light Metallic/Charcoal
      Advanced Package |Cross Country Pro Package
      Heated Steering Wheel/Rear Seat Package
      | Bowers & Wilkins
    14. #12
      May 2019
      Wayland, MA
      Quote Originally Posted by lflorack View Post
      You're thinking about it wrong. Turbos have a wastegate controlled by computer. It's a little flapper valve, when it's open exhaust bypasses the turbo, it's not making any boost. It's open until you command the power with your right foot, then the electronics close the wastegate and the turbo starts boosting. Over-simplified but that's the basics of how it works.
      Higher speeds kill the mileage because aerodynamic drag increases exponentially as you go faster. But going 20mph everywhere doesn't work out either. Now every car is different, gearing and peak engine efficiency vs aero properties of the body and all that so it would be hard to figure the ideal speed. But as a general rule of thumb, any car is going to get better mileage at 55-60 mph than it will at any speed higher than that. So you can experiment with your own results and decide for yourself where you personally fall on the "going fast" vs "saving fuel" continuum ;-)
    15. #13
      Jun 2020
      Upstate, NY
      Quote Originally Posted by Power6 View Post
      Ok, thanks. I guess I’ll take the car on some trips and see where the sweet spot is.
      | Bowers & Wilkins
    16. #14
      Apr 2014
      North NJ
      My daily commute is 15 miles each way. I usually fill up once a week.
      2019 Volvo S60 T6 R-Design AWD (Fusion Red Metallic) w. Advanced Package, Bowers and Wilkins, Heated Rear Seats and Steering Wheel, Polestar, Exterior Styling Kit, Sport Chassis, and 19" 5-Spoke Matte Black Alloy Wheels
      2018 Mercedes-Benz GLC 300 4MATIC AMG Line
      Past: 2017 Volvo S90 T6 Momentum AWD, 2015.5 Volvo S60 T5 AWD Platinum, 2015 S60 T5 FWD Platinum
    17. Remove Advertisements
    Similar Threads
    1. Replies: 6
      Last Post: 07-17-2011, 08:51 AM
    2. Replies: 7
      Last Post: 04-01-2011, 02:57 PM
    3. Help: OBC Fuel range misreading
      By T5on19's in forum S60 (2001-2010)
      Last Post: 02-11-2009, 08:44 AM
    4. Fuel Range read out 460 miles after fill up
      By 240_XC90 in forum XC90 (2003 - 2014)
      Last Post: 05-11-2008, 11:33 AM
    5. Fuel Tank Size on V8 and approx. range on highway
      By fosman316 in forum XC90 (2003 - 2014)
      Last Post: 04-25-2005, 05:52 PM
