I thought early P2s with 16" wheels came with 305mm rotors!
    Results 1 to 11 of 11
      Jul 2018
      Toronto
      I knew I had some worn front rotors on the 01 wagon and so when I hit the JY the other day and found some like new rotors I nabbed them. Fortunately I also grabbed the calipers (and brackets) just in case my calipers were pooched. I was quite surprised to find my 2.4t with factory 16" wheels had the smaller 286 mm rotors! The ones I got were 305mm which is what I was expecting to be on the car. Anyhow brake job done, using original calipers (identical to the ones for the 286mm rotors) with the larger brackets and 305 rotors from the JY pull, but I thought early P2s with 16" wheels came with 305mm rotors!
      01 v70 2.4T
      Member thaxman's Avatar
      Oct 2009
      Emerald Coast, FL
      Not quite. AFAIK 16" wheels were standard and 286mm brakes too. The 305mm were reserved for T5s (correct me if I'm wrong) and as an upgrade. 16" wheel is the smallest that work with 305mm.
      2004 V70 T5M: Platinum Green Bob Villa mod | boost gauge | poly mounts | Snabb intake | IPD sways | Koni yellow struts | KYB monotube shocks http://imgur.com/a/0MRgX
      2005 Mazda6 Sportwagon in progress...
      2012 Ford Flex Limited
      2001 Subaru Outback H6 L.L.Bean/2000 Honda Odyssey EX recently passed (together!)
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Only T5 and most S80s.
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
      SwedeSpeed.com
      Jul 2018
      Toronto
      OK, good to know. Can't remember where I read that but it turns out to be a happy mistake as I should now have better brakes.
      01 v70 2.4T
    7. #5
      Dec 2014
      Connecticut
      Quote Originally Posted by The Director View Post
      Certainly not a bad mistake! P2s are so severely under braked from the factory its obnoxious
    8. #6
      Dec 2012
      E. ON
      I did the 305mm upgrade when I replaced the brakes on my former 02 2.4T. Even with sourcing a pair of JY caliber brackets, cheap and effective improvement over the pathetic 286mm stock units. I’m pleased with the Zimmerman/Akebono 305 set up on the T5M, but everyone here swears by their preferred component combo
      2001 V70 T5M
      2010 XC70 T6
    9. #7
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      Quote Originally Posted by Eric Green View Post
      336mm
      Centric rotors
      Pagid Pads
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    10. #8
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      I'm also a Zimmerman/Akebono fan. I just did the 305mm upgrade on mine as well. Running Tritons I neeeeed the low dust pads. I've been running them now for years with excellent results.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70 2.5T - Ice White - Oak Arena, (almost) bone stock daily driver.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    11. #9
      Jul 2018
      Toronto
      Was poking about online this morning looking for a local source for 305mm Zimmermans and found GermanAutoParts which using their car model selector suggests 302mm for my V70. Lloyd or Eric, do you happen to have a p/n handy?
      01 v70 2.4T
    12. #10
      Jun 2020
      Quote Originally Posted by ScottishBrick View Post
      I was really disappointed in the brakes when I first bought my P2 last month. The pads are still meaty, rear rotors need to be changed. After a month they're starting to squeal since owner didn't buy new rear rotors. Now the braking is even worse than it was when I bought it last month... Doesn't help that I'm in an XC70. Probably one of the worst brakes I've felt in a car in a while lol
    13. #11
      Dec 2012
      E. ON
      Best I can do is this. HTH:
      You can read the VOLVO OEM part number at the bottom of the packaging. [NB: in case the photo does not load, it is VOLVO Part No. 31262707]
      2001 V70 T5M
      2010 XC70 T6
    14. Remove Advertisements
    Similar Threads
    1. 305mm brake upgrade with 16” XC wheels?
      By bigtimemcalpine in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-27-2019, 04:26 PM
    2. 15 in. wheels w/new Michelins. Fits p80 and p2s- $300 obo
      By Shamak in forum Wheels & Tires Classifieds
      Last Post: 11-03-2018, 11:14 PM
    3. Front and Rear Calipers with oem lines S60 T5 01 (for 305mm front rotors)
      By volvos60t5x in forum FWD & AWD Parts For Sale
      Last Post: 04-15-2013, 08:55 AM
    4. Set of 18" Atlantis wheels for 850,X70,early S60 and early S80
      By yellow95 in forum Wheels & Tires Classifieds
      Last Post: 08-20-2012, 12:27 PM
    5. Strange notches in OEM 305mm S60 Brake Rotors
      By IS300M in forum S60 (2001-2010)
      Last Post: 08-19-2010, 08:42 PM
