Outside temperature ready 12 or more degrees too high. Common?
    Results 1 to 9 of 9
      Jun 2020
      I took my 2017 XC60 in for this issue for the second time 2 days ago. Both times their diagnostics said nothing was wrong. When I drove it in 2 days ago, the airport temperature was 89 degrees and the temp on the dash said it was 102 degrees. This dealership is next to the airport. Again their system said there was nothing wrong, but they replaced the sensor just in case.
      Is this common?
      They gave me a loaner 2015 V60 and it read almost 10 degrees high.
      I'm not driving much right now, but we'll see if it's really fixed soon.
      Jul 2008
      Quote Originally Posted by DavidEid View Post
      Is this common?
      I donít know off hand where the sensor is on the XC (know there were in the LH mirror, not sure if they still are), but mine reads a bit high too, especially when parked. So definitely not just you lol.
      Joe
      2013 XC60 R-Design Platinum - Ice White
      2006 XC90 2.5T AWD - Willow Green - Wife's, all stock
      Junior Member Azlkk's Avatar
      Jan 2013
      Phoenix, AZ/Morro Bay, CA
      Yep, apparently the sun is never out in Sweden in the summer. My car is consistently off wildly when it's sunny and over 70 deg F. It's accurate on colder days or on cloudy days.
      Volvo: 2015.5 XC60 RD Plat. arrest-me red w/ Climate, BLIS & OEM trailer hitch. Koni Special Active struts/shocks, IPD skid plate & rear sway bar
      Others: 2019 Merc AMG E53 Cpe, 1988 Merc 560SL, 1969 MGB GT, 1957 MG ZB Magnette, 1953 MG TD & 1935 Ford 5W Dlx Cpe
      SwedeSpeed.com
      Jul 2013
      Georgia
      The temp sensor is located in the bottom of the outside mirror - a little bump - mine are only close to correct when its cool/cold outside, perhaps they pick up radiant heat reflecting from the door skin below the sensor. Maybe a dark car holds/reflects more heat?
    7. #5
      Jul 2008
      Quote Originally Posted by hoonk View Post
      Mine is white, not sure of the OPís color. But yeah, I have noticed that hotter ambient temps do lend to more variation. Does seem more accurate when cooler or overcast.
      Joe
    8. #6
      Feb 2015
      The logic for updating the temperature requires some driving for it update. The temperature will always be high initially due to sun heat soak as others have mentioned.
      Maybe you knew that already, just a thought.
      2015 V60 R-Design - Onyx Black Metallic / Off Black
      2004 Mazda 6s Touring - 3.0 V6 / Manual
      2008 Suzuki SV650 - Pearl Novelty Black
      2002 SVT Focus Turbo - Dead and gone
    9. #7
      Jun 2020
      Quote Originally Posted by Azlkk View Post
      I'm finding this to be true, even with a replacement sensor. Though it's a little better with the sensor.
    10. #8
      Jun 2020
      Quote Originally Posted by jschaefer7406 View Post
      Joe
      Mine is white as well.
    11. #9
      Jun 2020
      Quote Originally Posted by emgrock1 View Post
      Yup, knew that. It was even further off when I first turned on the car.
    12. Remove Advertisements
    Similar Threads
    1. External Temperature - 10 degrees too high?
      By cab in forum XC60 (2010 - 2017)
      Last Post: 08-01-2017, 09:46 AM
    2. Replaced ambient temperature sensor, still 20 degrees too low.
      By ilovemud in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-11-2014, 06:43 PM
    3. Replies: 25
      Last Post: 08-16-2010, 10:02 AM
    4. Replies: 17
      Last Post: 11-30-2007, 09:29 AM
    5. A/C Compressor runs intermittantly when below 50 Degrees outside
      By dwehking in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-28-2007, 11:43 AM
