Dash display that shows the speed limit of the road/highway I'm currently on?
    Results 1 to 6 of 6
      Mar 2011
      I've had my XC40 for about a month now (and love it) but am trying to figure out how to get back the nifty feature where it shows the speed limit on the road/highway I'm currently on. It would appear near the speedometer. It was there when I first got the car but in the process of fiddling with the car settings, I lost it and can't figure out how to get it back. Any help would be appreciated.
      Member Gary-16-Xc90's Avatar
      May 2015
      Twin Cities, MN
      If you are on the main / center panel of Sensus, just slide the panel from left to right.
      The left panel (Functions page) appears. Scroll down the page until you see Road Sign info. It could be below the visible screen initially.
      Just turn it on.
      If you have HUD and have calibrated its position, you can initiate that on this screen (e.g., HUD calibration).
      The individual tile(s) on the Functions page can be moved around. It is a bit like checkers.
      All the best from Minnesota USA,
      A fine MY16 XC90 T8
      2016 XC90 T8 Inscription | US 10/2015 Build| Crystal White | Blonde | Blonde | B&W | Air | HUD | Convenience Vision Climate | PAII + Mitigation Upgrades | Xpel + Gtechniq Ceramic | 3M Crystalline 50% Tint, 97% UV Rejection, 60% Solar Heat Rejection | 20" A/S & 22" Summer | Tow | Last TSU installed 02 Jul. 2020 | 46K miles | MPG 31.8 Lifetime including transcontinental trips, regional trips and towing
      May 2018
      Lewisberry Penn
      Gary is 100% correct. You can also make some adjustments the this setting under the vehicle settings.
      Swipe down from the very top of the screen at the two parallel lines.
      Select Settings
      Select My Car
      Select Intellisafe
      Select road sign information
      You can adjust a little about if and when it flashes for speeding, you can even make it beep at you for speeding (no one turns that on) and you can have it beep if it knows there are cameras on cars with Navigation.
      Volvo Sales Guy
      Overseas Delivery Specialist
      VCOA Member
      iRoll YouTube (looking for more helpful video ideas to kick start this channel)
      SwedeSpeed.com
      Mar 2011
      Thanks!
    7. #5
      Member
      Aug 2011
      Austin 'convection oven' TX
      Quote Originally Posted by LaMoora View Post
      Thanks!
      Take note that it is not instantaneous . I believe it actually reads signs; so turning from a 45mph road to a 65mph highway might take a while to register. I know ours does as we have such a transition on our way home. It goes blinky and crazy as I accelerate from the intersection to 65mph while it still thinks I'm in a 45 !!!
      Current: 2020 XC40 T5 Glacier Silver '13 C70 Caspian Blue
      Previous Volvos[/I]: '11 C70 Ice White;
      Polestar ,'10 XC60 T6 Electric Silver; '08 C70, '07 XC70, '04 V70', '04 C70, '01 S40, '80 242 GT '72 145
    8. #6
      May 2015
      Twin Cities, MN
      From the Volvo Cars US website....
      “Speed information may also be pulled from the map data if the Volvo is equipped with Sensus Navigation. The result of this will be the speed information may change without passing speed limit signs. For the best experience, please ensure your maps are updated by clicking here. “
      Sensus Navigation also retains speed information. I understood that Sensus also learns from the roads routinely traveled. I cannot find that info right now to verify.
      A fine MY16 XC90 T8
    9. Remove Advertisements
    Similar Threads
    1. DRL, Speed Limit display removal?!
      By aguita in forum XC90 (SPA: 2016 - )
      Last Post: 08-31-2019, 10:54 AM
    2. Speed limit not showing on Heads Up Display
      By VolvoPat in forum General Volvo Discussions
      Last Post: 07-29-2019, 02:46 PM
    3. HUD/center missing speed limit display?
      By Korben in forum XC90 (SPA: 2016 - )
      Last Post: 01-17-2018, 09:11 PM
    4. XC90 OEM Nav System - Display speed limit?
      By AlpineDrive in forum XC90 (2003 - 2014)
      Last Post: 02-15-2014, 11:37 AM
    5. Road Sign Info / Speed Limit Display for Digital Instrument Cluster
      By matt1122 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 08-07-2013, 03:47 PM
