Angle/Bevel Gear Oil Bolt Location?
    Results 1 to 6 of 6
      Jan 2019
      London, UK
      Tried to change the Angle/Bevel Gear Oil but couldn't find the fill bolt.
      The bevel box appears to be different to what I've seen here:
      https://www.youtube.com/watch?v=2YFDpDk7gAw
      And in Vida Diagrams and photos.
      The car is a XC90 2013 reg (2014 in VIDA) D5 AWD RHD.
      The differential and gearbox look the same as other cars.
      Does anyone know where I can find the drain/fill bolt?
      Photo of the bevel box here:
      https://u.pcloud.link/publink/show?c...sK6LsDhXiqVn1k
      Thanks in advance from the UK!
      Junior Member LukeFlynn's Avatar
      Feb 2019
      Knoxville, TN
      Looking at where the pass. axle comes out of the angle gear, right next to the output you will see a bolt, I wanna say it's a 13 or 14mm. You use that as both the drain and fill plug.
      '04 XC70 | Silver Metallic | Shimmed B5254T2 | K24 | M66 w/ SPEC single mass | IPD catback | Elevate sways | lowered on S60 AWD springs | Hilton Stage 3 Tune
      '09 S40 2.4i | Titanium Grey | Stock | 140k
      Junior Member generic_volvo_driver's Avatar
      Nov 2017
      British Columbia
      You can just see it poking out in the third and 2nd to last photo (if my orientation is correct).
      You'll see a bolt pattern that's symmetrical and then one bolt that's tucked inside that pattern.
      It's a 13mm tucked in the little alcove here:
      Me:
      2013 Volvo XC90 AWD Platinum (Caspian Blue Metallic, climate package, walnut inlays + wheel, BLIS, active bi-xenon headlights) 150k km
      2012 Volvo XC60 T6 AWD Platinum (Technology package, climate package) 30k km
      1988 Nissan 300ZX Turbo (2+2, T-top, Aztec Red, collector plates) 80k km
      Family members:
      2015 Volvo XC60 T6 AWD Platinum (Technology package) 96k km
      SwedeSpeed.com
      Jan 2019
      London, UK
      @generic_volvo_driver Your photo didn't load.
      Did you guys mean this bolt:
      https://u.pcloud.link/publink/show?c...xC2gKaBQPwHIJk
      If so could you please confirm to get the level right I need to fill it until starts dripping slowly out then remove 100ml of fluid with a syringe?
      Thanks all!
    7. #5
      Nov 2017
      British Columbia
      Yes, that bolt.
      I forget if there's a newer TJ that changed the amount. Search around to confirm it still is 100mL.
      I'll be posting some interesting research I've been doing on the fluid removal in the coming days.
      On a family member's 2015 XC60 T6 I serviced this weekend, it did not have the requirement to remove any fluid from the angle gear, the rear diff or the Gen5 Haldex vs my 2012 XC60 T6 AWD or my 2013 XC90 AWD. I'm going to be comparing part numbers and design notes to see if there was an actual design change to warrant the lack of fluid removal or if fluid removal is for CAFE ratings.
      Me:
      Family members:
    8. #6
      Jan 2019
      London, UK
      Quote Originally Posted by generic_volvo_driver View Post
      Thanks for the info, but I cannot find anywhere that confirms the fluid amount for this shape of design.
      where is the best place to look?
    9. Remove Advertisements
    Similar Threads
    1. Angle gear and rear diff gear oil. Do you use oem or regular gear oil?
      By cs057 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-27-2014, 05:11 PM
    2. Picture request - leaking angle gear or bevel gear
      By heus33 in forum R Forum (2004-2007)
      Last Post: 06-02-2010, 07:12 PM
    3. Which year/tranny has the Angle Gear (bevel gear) failed the most on??
      By Bigglezworth in forum R Forum (2004-2007)
      Last Post: 03-31-2008, 01:34 PM
    4. Replies: 1
      Last Post: 08-04-2007, 02:10 PM
    5. Angle gear/Bevel gear
      By pen61guin in forum S70, V70 & V70XC (1998-2000)
      Last Post: 06-26-2007, 09:44 AM
