How Cold is your A/C?
    Results 1 to 12 of 12
      Nov 2018
      Mississauga, ON Canada
      Hey Guys,
      We have been having several 30'-35' C plus days and I have noticed the A/C does not get really cold? Is this normal or should I take it into the shop for them to have a look?
      As a comparison, we also have a 2020 Hyundai Palisade and the air coming from the A/C when set to 22' is very cold.
      Thanks.....
      Mar 2019
      You should be able to register 21C out of the air vents when it's 40C outside, afaik.
      That said, it's been my experience that Volvo AC has never been "great". Mine certainly does the job, but going back to my first 850 in the early 90's, other brands have always had better AC. My wife's car, for example, has noticeably colder AC. It can be 40C+ outside and her AC will give you frostbite on your hands.
      Now the heater, on the other hand.... Volvo heaters could restart a dead star.
      Member BigBang's Avatar
      Mar 2018
      World
      Quote Originally Posted by spas1 View Post
      Hey Guys,
      Thanks.....
      I noticed this a long time ago and what is even more interesting is that Volvo does not offer a system for hot countries , such as the Middle East (40'-50' C ) or Africa, but has the same system for all countries.
      2018 XC60 T5 R-Design
      SwedeSpeed.com
      May 2019
      I just drive mine across the Utah and Mojave deserts for ten days. It was 110 degrees most days, with like zero humidity. I was comfy with the a/c. I didn't measure the temp coming out but I have no complaints.
      2019 XC60 T6 Inscription Pine Gray Ext/Maroon (brown) Int
    7. #5
      Member lamarguy's Avatar
      Aug 2006
      Austin
      It's been 39 - 41C here and the HVAC in my T8 is ice cold. I usually leave it at 74F (AUTO, ECO) and my significant other directs her vents away (too cold).
      I've noticed the T6/T5 loaners I've driven have to turned down to 70 - 72F (non-ECO) to get similar cooling performance. I assume it's a difference in programming (electric vs ICE-driven compressor).
      OSD '18 XC60 T8 Momentum - 22" 10-spoke wheels, lowered air suspension, strut tower bar, Stealth hitch
    8. #6
      Member Seti's Avatar
      Oct 2016
      Afrique du Sud
      Hey Guys,
      Thanks.....
      Check that eco isn't enabled
      Sent from my SM-G950F using Tapatalk
      T8 Inscription - With almost all bells and whistles, bar leather on dash and upper fascia - Regretting not having them
    9. #7
      Aug 2016
      Quote Originally Posted by Seti View Post
      I think eco can only be enabled in a driver profile?
      2020 xc60 "Polestar Engineered", crystal white.
      2019 xc40 T5-R Bursting Blue Premium & Advanced Packs.
    10. #8
      Nov 2018
      Excellent point! This evening I was out and had the driving mode set to the default comfort mode and the air was nice and cold. Come to think of it the last time I drove in the 35C weather I’m pretty sure I was in eco mode which would explain it.
      I will test this again....
      Thanks for the tip!
    11. #9
      Oct 2016
      Afrique du Sud
      Quote Originally Posted by xgman View Post
      When you select Pure (I don't know what non T8 equivalent Drive mode for Pure is. Eco?) Or when you've enabled eco on Individual drive
    12. #10
      Junior Member skibum50's Avatar
      May 2017
      Northern Kentucky
      Quote Originally Posted by lamarguy View Post
      Same here, although we've only had it up to 32-34°C lately. Ice cold.
      2018 XC60 Momentum T8 (OSD March 2018)
    13. #11
      Dec 2016
      Dallas, TX
      Check the auto fan speed, it'll go to 5 but likes to be 3. It'll get loud on 5 but it'll do a better job.
    14. #12
      Aug 2016
      I find that on a 90 degree day, ECO mode is useless.
    15. Remove Advertisements
    Similar Threads
    1. A/C cold, then lukewarm, then cold again etc.
      By T501 in forum General FWD & AWD
      Last Post: 04-29-2014, 08:51 PM
    2. Ac-- how cold is cold?
      By Masscomguru in forum XC90 (2003 - 2014)
      Last Post: 07-02-2013, 10:47 AM
    3. Rough cold start, and rough acceleration(when cold)
      By Body Massage in forum R Forum (2004-2007)
      Last Post: 04-05-2011, 12:57 PM
    4. Climate Control, hot, cold, hot, cold......
      By COGGS in forum S80 (1998-2006)
      Last Post: 12-27-2010, 08:34 PM
    5. "Cold oil flogging" how cold is too cold?
      By Britspeed in forum R Forum (2004-2007)
      Last Post: 12-24-2004, 09:31 AM
