P80 Parts
    Results 1 to 17 of 17
    Thread: P80 Parts
      Aug 2010
      Memphis, TN
      P80 Parts
      Some miscellaneous parts for sale, I'm saying goodbye to my 1998 S70 T-5.
      Waterfall Grille 20.00 plus shp
      Cross Country Grille 40.00 plus shp SOLD
      Lower Bezel pieces to match the Cross Country grille. I have all three. One tab is missing on each of the small ones. They still held fine in my bumper slots. 50.00 plus shp
      TME Sweden Strut brace 90.00 plus shp SOLD
      Contitech Timing Belt kit, CK252LK1. It's a new warranty replacement. It's all there. 120.00 plus shp OBO/pls make offer
      Black All Weather Mats in good condition (I forgot to take a photo, I will try tomorrow). 50.00 plus shp SOLD
      Black faded spoiler (w/oem hardware) with a hairline crack. Our Herculean son "slammed it shut" one evening while retrieving groceries. 60.00 plus shp
      I may have a few other things to part with, I have the driver's side headlight if anyone is interested. The passenger has a rock hole and the part that holds the bulb is broken. Both tail lights are in good shape but I figure that's a common item at junk yards.
      Please send me your zip and I'll get a quote for you.
      Paypal, cashier checks and money orders accepted.
      Thanks,
      Lydia
      watermom
      Here's my new wix photo hosting album. Goodbye to photobucket, also. If you want to see something in particular, let me know. I can always email a photo.
      https://watermom.wixsite.com/1998-s70-t5-3
      Member zmarshm1's Avatar
      Mar 2019
      Binghamton NY
      Do you have driver side knee bolster cover?
      ||1998 s70 t5m - Stock, future gambler 500 car | 140k? miles
      ||2001 v70 t5 - IPD Sway bars | Delrin subframe bushings | Transmission cooler & mounted inline filter | Rostra long snout transmission solenoids | IPD catback exhaust & Rolling Motors 3" downpipe | Simota Carbon Charge Intake | Bilstein B4 & Eibach prokit lowering springs | 124k mi
      ||2003 v70 2.4t - First volvo | SOLD! Still driving around with 190k+ miles.
      Kanjo!!
      Member Austin V70R's Avatar
      Jan 2012
      Santa Cruz, Ca
      Any chance you’ve got a manual trans shift boot?
      06 VR GT - daily driver ~18" TSW Nurburgring wheels ~Contrast Stage 4 ~Shimmed block ~EFR7163 turbo ~1050cc Injectors ~TorqByte PM3 fuel pump and CM5-LT W/M controllers ~track spec IPD Bars ~Ultra Racing front strut bar & VST rear strut bar ~SS brake lines~Innovate Boost & AFR fail safe
      SwedeSpeed.com
      Aug 2010
      Memphis, TN
      Quote Originally Posted by zmarshm1 View Post
      Yes, I do. Let me check the tab situation, I know my husband removed it several times. The color code is 3990. I do have two passenger ones, also. One is the plain and the other is with the map pocket.
    7. #5
      Mar 2019
      Binghamton NY
      Quote Originally Posted by watermom View Post
      Color and tabs don’t matter, I got a spot to just drill and put a screw. Anything’s better than it missing.
      Kanjo!!
    8. #6
      Aug 2010
      Memphis, TN
      Quote Originally Posted by Austin V70R View Post
      No, unfortunately it was automatic. I believe people on here call it "auto tragic."
    9. #7
      Aug 2010
      Memphis, TN
      Okay, let me take it out later tonight. Would you like a photo?
    10. #8
      Mar 2019
      Binghamton NY
      Yes please, i pm you too.
      Kanjo!!
    11. #9
      Aug 2010
      Memphis, TN
      I just replied, check your pms.
      Thanks
    12. #10
      Member DWBF1's Avatar
      Jun 2003
      SE MI
      I have one if the OP doesn't. Feel free to PM.
      2000 V70 R +M66 etc. | 2008 XC90 V8 | 2020 XC60 T5 | 1979 242 GT | 1995 850 T5R
    13. #11
      Jan 2012
      Santa Cruz, Ca
      Thanks.
    14. #12
      Oct 2017
      Would all weather mats work in a P80 C70? Heard the fronts are the same as 850’s etc, essentially
    15. #13
      Aug 2010
      Memphis, TN
      Quote Originally Posted by BoostMooseR View Post
      I'm not one hundred percent sure, can someone else chime in? There's one person ahead of you for the mats. I'll let you know if he doesn't get them.
      I've added photos of the mats here: https://watermom.wixsite.com/1998-s70-t5-3
    16. #14
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Yes. Same all P80. 850/S/C/V/XC. Thankfully
      2003 V70 T5 - Mystic/Graphite - M56LK - 206k - K24/Greens/Do88/Quaife/SMF/P2R Clutch/DW300C/H&R/Bilstein TC/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 299k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 243k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 218k - Sisters
    17. #15
      Aug 2010
      Memphis, TN
      Cross Country Grille Sold
      Black All Weather Mats Sold
      Driver's Side Kick Panel Pending
      Thanks!
    18. #16
      Aug 2010
      Memphis, TN
      P80 Parts
      I've got a Curt Hitch Receiver, 60.00 (plus shp). If you're local to the Memphis/Mid-South area, free pick-up. I can ship but it's probably going to be costly because of the weight.
      I've got a OEM Trunk mat, black, 50.00 plus shp. Actually, I have two, let me check on the second one.
      OBO on the strut brace and timing belt kit.
      Thanks!
    19. #17
      Aug 2010
      Memphis, TN
      TME Sweden Strut brace Sold
      Thanks!
    20. Remove Advertisements
    Similar Threads
    1. Parts Parts Parts and Parts
      By BlkT5 in forum FWD & AWD Parts For Sale
      Last Post: 11-29-2019, 11:28 AM
    2. Replies: 0
      Last Post: 07-31-2019, 10:55 PM
    3. V70R Parts and P80 Parts
      By Gage in forum FWD & AWD Parts For Sale
      Last Post: 12-04-2016, 12:06 PM
    4. P80 X70 Parts Lot, Selling my S70 T5M and its spare Parts
      By grega311 in forum FWD & AWD Parts For Sale
      Last Post: 03-17-2015, 10:52 AM
    5. Replies: 13
      Last Post: 08-08-2013, 11:28 PM
