NAV system stuck in upgrade loop
    Results 1 to 7 of 7
      Feb 2020
      Hey guys,
      Got one I can't figure out and need some guidance.
      08 XC90 3.2, Factory NAV
      Bought an update disk, interested it, systems started doing it's updates. Went thru 2 or 3 reboots updating different things/firmwares. Came to the last part, updating the maps. It starts, saying 200 minutes remaining, few minutes later it switches to cannot read disk.
      If I exit out of the update it has updated some things as the screen and layout is completely changed, much more modern.
      Suggestion on getting the update to complete? I have already run a disk cleaner thru in addition to blowing out the unit with some compressed air.
      The disk is spotless, not a single scratch on it.
      If I cannot get the update to complete, is there a way to cancel it? Every time I start the card the NAV now turns on trying to complete the update even after I have shut the NAV down.
      Thanks,
      -Brian
      Jan 2017
      Cross Country
      Quote Originally Posted by ChopperMan View Post
      Hey guys,
      Thanks,
      -Brian
      Options:
      Connect a smart battery charger and try again. Maybe low voltage?
      If it doesn’t work, remove nav, clean laser lens gently with a cotton bud and isopropyl alcohol, and try again. Maybe dirty laser lens?
      If it doesn’t work, use a pressed DVD (Original) and not a copied DVD. Maybe weak laser?
      Note that a copied, burnt DVD reflects less light than a pressed DVD and is thus harder to read, requiring a stronger laser. If the laser is old and weak then you can get to a situation where the errors reading the copied DVD are too high, but a pressed DVD may still work (for a few years)
      I had this when I updated the software in my 2009 car, kept getting the "could not read disc error". I kept ejecting the disc, putting it back, it would be ok for anywhere from 5 to 20 minutes then the same error would occur and I would repeat the process. It was a major ballache but after 5 hours the update completed ok.
      2009 XC90 D5 185 R Design Geartronic-6
      Premium, Summer, Winter, Family and Comms packs.
      SwedeSpeed.com
      I had this issue also but ended up getting the disk replaced for resolution.
      2010 XC90 V8 - 140k miles
      2012 S60 T5 - traded with 177k. Lost compression on cyl 5.
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
    7. #5
      Feb 2020
      Thanks for the feedback!
    8. #6
      Feb 2020
      pulled the nav unit today, fully cleaned. Still experiencing same. Is there a way to roll back the upgrade? Cannot get out of the loop. Even tried a factory reset. Thanks!
    9. #7
      Jan 2017
      Cross Country
      You could try inserting the previous version, but you’d be better off trying with another DVD.
    10. Remove Advertisements
    Similar Threads
    1. headlights locking Pin is stuck stuck stuck!
      By garrett in forum S40 & V50 (2005-2012)
      Last Post: 05-29-2013, 04:56 AM
    2. Loop de loop anyone? (neat)
      By JRL in forum Off Topic Forum
      Last Post: 02-16-2010, 01:18 PM
    3. Ground Loop Isolator for Digital Jukebox
      By TarP in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 01-24-2010, 11:10 AM
    4. Replies: 0
      Last Post: 02-22-2006, 03:41 AM
    5. Question about usa-spec ipod adapter install..use of "ground loop isolator" (long)
      By kenmcl in forum Car Audio, Video & Mobile Electronics Forum
      Last Post: 06-13-2005, 08:57 PM
